Review : Astrolux MF-01 flashlight (18*Nichia 219C , 4*18650)
36 posts / 0 new
giorgoskok
giorgoskok's picture
Last seen: 1 day 7 hours ago
MF-01 review
MF-01 is a budget multi thousand lumens flashlight , with 18 Nichia 219C leds powered by 4*18650 , all this in a handheld flashlight
Overview/Specifications :
Features:
·Utilizes 18 x XP-G3/Nichia 219C LEDs, max output up to 12000 lumens
·Powered by 2x/4×18650 batteries.
·Max runtime up to 214 hours
·Max throw up to 450 metres
·One single switch provides access to all functions
·5 brightness levels and 3 special functions available
.Light off or Normal mode, click twice to enter turbo or click three times to enter tactical strobe
.High efficiency constant current circuit, Reverse polarity protection
.Direct thermal path(DTP) copper board
.Intelligent temperature control,over 60 degrees will reduce the power and output will stablilize in about 2500 lumens
.Breathing light and lockout design
.Breathing light displays battery voltage
.Integration and high efficiency optical lens
·Constructed from aero grade aluminum alloy with HAIII military grade hard-anodized finish
·HAIII hard anodising
.Standard 1/4 inch Tripod mount
·Waterproof in accordance with IPX7
·Tail stand
First Look :
Flashlight in it’s box , a nice , classy , white box :
Package Contains :
  • Flashlight
  • User manual
  • Lanyard
  • 2x O-rings
  • Tripod mount “thread adapter”
A closer look :
Below you can see the flashlight :
The body holds a carrier with 4*18650 batteries , and of course the head has the driver , e-switch and the LEDs .
Dimensions’ time ! Head’s max diameter is 72mm , body’s 53mm and length is about 126mm .
Flashlight in hand :
A better look at the head . On the side we have the e-switch visible :
It changes modes through the e-switch . E-switch cover is made from rubber and has the “On/Off” logo on it :
When flashlight isn’t in lock-out mode , the switch is used as a locator led :
Some cooling fins , not pretty deep , but the head has enough mass under them… :
Here is the tripod mount . It’s probably 1/4 :
With the adapter that comes in the box , it becomes 3/8 :
And the interesting part , the LEDs on the front , with 18x Nichia 219C on a big copper DTP mcpcb (i present the Nichia 219C version here , but an CW xp-g3 version is available too) , under one optic with 18 TIR’s (13mm each TIR) :
And the TIR’s under some light Wink Seems a blue due to my camera’s color correction :
Notice the nice SS bezel Smile :
The tube , doesn’t have a knurling but a diamond shape pattern :
The other end of the flashlight , with holes for lanyard too :
If we un-screw the head , we can see the head and the tube with the battery carrier inside :
On the inside of the head , we see the spring (+) and the brass ring (-) that make contact with the battery tube :
Driver , with the 3 screw mount visible :
I also tested if it would gain lumens by bypassing the spring , but it doesn’t ! Spring gets compressed fully when you screw the tube , and it doesn’t have much resistance :
Threads are “square” and well lubbed :
A close-up from the battery carrier . It is in 2S2P configuration , so output voltage is 8.4 Volts :
Again , nice brass on the contacts , it has the same interface on both sides :
In stock form , it accepts BUTTON TOP batteries :
Do not try powering the flashlight with higher voltage than 8.4V , because you will damage the driver !
How it works (&modes) :
Flashlight uses the e-switch at the side for on/off and mode change functions .
Flashlight has 5 modes , sepperated in 2 groups :
1) Low , Medium , Medium 1 , High , Turbo
2) Hidden Strobe , SOS , Location Beacon
Operation :
From OFF :
  • Single click turns the light ON , on the last used mode
  • Double click to enter Turbo
  • Triple click to enter Strobe
From ON :
  • Depending on which mode group you’re , single click advances mode
  • Long click (>1s) turns off the flashlight
Lock-out mode :
From OFF , operate a long click (>1.5s) , and you won’t be able to accidentally turn on the flashlight and locator led on the switch will be OFF . Long click again to unlock the light .
Battery Indicator :
Every time the flashlight has batteries in it , in ON or OFF state , and it isn’t in lock-out mode , the indicator/locator led on the switch shows the status of the batteries depending on the color .
When indicator is :
  • Green , voltage is over 6.8V (total carrier voltage)
  • Red , voltage is over 6.1V
  • Flashing red , voltage is less than 6.1V
When voltage is less than 5.8V flashlight shuts down . I tested and it stops right in time .
Measurements :
*Batteries used in measurements : Sony US18650VTC6 3000mAh *
Lumens on different modes :
  • Low – 3,5 lumens
  • Med – 580 lumens
  • Med_1 – 1257 lumens
  • High – 4272 lumens
  • Turbo – 9810 lumens
Intensity : 49,7kcd
My runtime tests :
Flashlight has thermal regulation , this means , that when temp on the head passes 60 degrees Celcius , output starts to reduce .
High mode :
Runs stable at 4200 lumens for the first 2.5 minutes , but then output reduces and about 30 seconds later it gets stable at 1700lm .
Turbo mode :
For the first minute slowly drops but it still produces 9000 lumens , then redusing for the next minute until it reaches 2150lm where it gets stable .
Beamshots :
Wall @ 12m
Mid :
Mid 1 :
High :
Turbo :
Road :
Lot’s of lumens , but isn’t pure flood ! Throw is really good , end of the road at 60-70m is easily illuminated !!!
Park :
Conclusion :
An awesome budget flashlight , with about 10k lumens max output (and more on the xp-g3 version). Runtimes are good in every mode , even on Turbo , with the thermal regulation working perfectly . Flashlight’s quality is super , without any imperfections overall or weaks spots on the anodization . Battery indicator feature is a nice feature , and the switch led that works as a locator led too .
More info can be found in my detailed review Smile
Comment if you want me to check something on the flashlight , or tell your opinion . Thanks !
Flashlight was provided by Banggood for review purposes . Be sure to check the flashlight HERE .
There is a very good discount , but for a limited time ! Code : 0410e9 , Price : 78$ (only lasts until Oct 21st)
Other discount code : e04bc8 , Price : 85.95$
Edited by: giorgoskok on 10/22/2017 - 18:58
giorgoskok
Reserved
hIKARInoob
hIKARInoob's picture
Last seen: 6 min 26 sec ago
My goodness. Reading this review really makes me fall in love with this light over and over… You have measured one gripe that I have with this light. I personally have noticed on my light that when it steps down, it does this all the way to about 1500~2000 lumens roughly according to my eyes. You have measured 1700 lumens from high and 2150 from turbo. The light should be able to put out more lumens. But then again, after a long period of using the light at this reduced output gives you sufficient temperature head room again for the next turbo output. This light is just awesome! Big Smile
giorgoskok
Well , thermal stepdown is really good for occasions like this , to maintain your hand in excellent condition Big Smile
Awesome budget super bright flashlight .-
FreeMagenta
Hmmm… 3,5 lumens on low? That means they have changed low mode, in mine it was ~80…
Also, I strongly suggest unscrewing the light when transported. Should something fail, having 4 high current batteries shorted won’t be pretty.
AllenT
AllenT's picture
Last seen: 3 weeks 4 days ago
Nichia 219C has good color rendering, very worthy. Good flashlight with good price
MSU, Go Green, Go White
giorgoskok
FreeMagenta wrote:
Hmmm… 3,5 lumens on low? That means they have changed low mode, in mine it was ~80… Also, I strongly suggest unscrewing the light when transported. Should something fail, having 4 high current batteries shorted won’t be pretty.
Hmm that’s interesting . I’ll check my notes and measure it again tomorrow…
JIGHEADWORM
Last seen: 1 week 2 days ago
Is this light the first batch ?
Nicolicous
Nicolicous's picture
Last seen: 1 min 31 sec ago
my only wish is that they regulate the output after 2.5minute drop down Shocked
Nico -.-
yuhsin91123
So glad that I picked Nichia, it looks awesome! In the very beginning I was leaning toward the XP-G3 because it’s brighter. And that is what most of new flashlight people are looking for. However, after sticking around BLF and found that a lot of people would rather pick high CRI over high lumens according to my observation.
So this is what I do… I have one big lumen light (HaikeLite MT03 in CW) and have one high CRI light (Astrolux MF01 in Nichia) just to balanced things out…
Plus, the holiday season is coming… if I really like this MF01 then I certainly will be looking for another one in XP-G3 and see if there are any specials going on during those holidays (Christmas, New Years/ Chinese New Years etc.)
chezz
chezz's picture
seems as though this may be a heavier flashlight (with cells installed) when compared to other comparable sized “pop-can” style lights that are currently on the market, yes ? just curious, thanks.
btw : would there happen to be any other sellers besides banggood (within the states) possibly carrying this model ?
kiriba-ru
kiriba-ru's picture
Last seen: 1 hour 24 min ago
“Here is the tripod mount . It’s probably 1/4”
I think 3/4”.
George, please fix the photos. They are too heavy and I cant download full page with 4G.
giorgoskok
Yes !
chezz wrote:
seems as though this may be a heavier flashlight (with cells installed) when compared to other comparable sized “pop-can” style lights that are currently on the market, yes ? just curious, thanks. btw : would there happen to be any other sellers besides banggood (within the states) possibly carrying this model ?
BLF Q8 weighs 588gr with batteries , while MF01 weighs 730gr with batteries . For me , it doesn’t feel a lot different when i hold both .
I think 3/4
Hmm , i have made a mistake . Flashlight has a 3/8” mount , and with the adapter it is 1/4” ? I think it is that way
Box
Last seen: 2 months 5 days ago
Thanks for the review George. Appreciate the runtime graphs!
Myers
Last seen: 10 months 3 weeks ago
It woluld be nice a 2-2,5K lumen mode. It can hold constantly.
chezz
chezz's picture
thanks very much George, appreciate all the great info, and all the hard work on your excellent review Smile
giorgoskok
updated
Tally-ho
Tally-ho's picture
Last seen: 3 hours 1 min ago
FreeMagenta, do you have a MF-01 with 6 wires to the MCPCB or a revised MF-01 with 2 wires. I don’t understand why you are saying that they changed the low mode since the MF-01 reviewed here is the old one.
Caleb
Caleb's picture
Last seen: 5 hours 34 min ago
I wonder if bypassing the springs on the battery carrier would result in any performance increase. Cool
JIGHEADWORM
I bypassed carrier springs and it made very little difference. If a a light isn’t fet direct drive it doesn’t help much.
ChibiM
ChibiM's picture
Last seen: 8 hours 55 min ago
kiriba-ru wrote:
"Here is the tripod mount . It’s probably 1/4" I think 3/4". George, please fix the photos. They are too heavy and I cant download full page with 4G.
+1 the pictures on the large/heavy size. And my take just a little too many as well Wink
giorgoskok
ChibiM wrote:
kiriba-ru wrote:
“Here is the tripod mount . It’s probably 1/4” I think 3/4”. George, please fix the photos. They are too heavy and I cant download full page with 4G.
Thanks for pointing out guys . I already fixed this in my latest review , and kiriba suggested another solution too Thumbs Up Thumbs Up
patmurris
patmurris's picture
Last seen: 1 day 2 hours ago
Thanks giorgoskok for the review. I agree with others about the heavy pics (15 Mpixels each it seems)…
I gather this is a first batch light and i noticed a couple differences from my second batch unit on the driver side.
- For some reason, on mine, the three screws around the brass ring are not properly counter-sunk and two of them do slightly protrude above the ring plane. Not sure whether the screws have bigger heads or the chamfer is narrower then on batch one.
- Mine has a double spring at the positive contact. Overall it is very stiff and i’m worried about the stress on the driver PCB each time i have to screw the body hard to make contact.
- Unless my estimates are way off, my second batch Nichia version barely reaches 8K lumen – on freshly charged BT 30Qs.
I do love the pure wall of light it produces for sure – especially in such a compact format. That satin black finish is a pleasure to handle too. However, the UI feels uninspired and the mode spacing is terrible IMO. I admit i’ve been recently spoiled by the D4 and the Q8…
JIGHEADWORM
Those screws sticking up could have a big impact and yes it does have dual springs now and i agree mode spacing is terrible. I don’t get why a lot of these companies can’t give their lights a configuration menu.
Box
I don’t have a problem with the image size. I like big clear photos. I’m using crappy Australian 4G
sovereignknight
sovereignknight's picture
Last seen: 5 days 8 hours ago
I’d like to see these tests done on the XP-G3 version of this light. Wouldn’t the XP-G3 version hold Turbo and High longer due to less heat? Honestly if that is the case, I’d opt for the XP-G3’s longer higher output duration.
https://en.wikipedia.org/wiki/John_3:16
Flashlights:
x6 Sk68 modded 3 Nichia 319AT, 3 Cree XP-G3 - x1 Solorforce P60 drop in custom XM-L2 U4 1C, Qlight Rev.A 7135*8 3.04A Driver - x2 Lumintop EDC05 CW - x2 Jaxman E2L tripple XP-G2 S4
x1 Jaxman Z1 Zoomie, w/ Cree MT-G2 Q0 LED - x1 Acebeam K40m thrower with MT-G2 Q0 LED - x1 Xintd SC-82 V5 Limited Edition C8, XM-L2 U4 1C, Qlight Rev.A 7135*8 3.04A Driver
x1 Convoy L6 moded with a Cree XHP-70.2 P2 1D LED - x1 Rare Olight x7 Maurauder with a Nuetral White LED - x1 Astrolux MF-01 Nichia 219c - x1 Astrolux MF-01 Cree XP-G3 - x2 Zebralight SC5w MKII
x6 Lumintop Tool AA - x1  x2 Lumintop Tool AA 2.0 - x1 Lumintop ODL20C - x1 Lumintop GT mini - Olight i3E EOS - x2 Zebralight SC600w Plus MK IV XHP 50.2 4500k 80 CRI - x1 Fenix CL30R - x1 Lumintop C01 Bike Light - x1 Lumintop Zoom 1 - x2 Zebralight Sc700d
giorgoskok
I think mf01 has a timed stepdown , not depending on temperature.
hIKARInoob
Perhaps it’s similar to Haikelite MT03 IIRC? There is a timer, and after a period it checks temperature. And depending on temperature it steps down or not. So it’s both timed and temperature controlled. An example of a light that uses timed step down solely is Manker MK34 which always steps down from turbo after 25 seconds.
FreeMagenta
I am pretty sure that in v2 there is no timed stepdown in High mode (tested it with fully charged 30Qs – http://budgetlightforum.com/comment/1222693#comment-1222693 ) Not sure about Turbo, though yuhsin91123 tried it – and looks like it is purely timed, always @ 1:30 http://budgetlightforum.com/comment/1212502#comment-1212502 . The High mode has temperature protection, but surely no timer.
sovereignknight
I am curious to know why the XP-G3 version of this light is putting out 5100LM on high and the Nichia 219c is pulling 6800. I thought the XP-G3 produces higher lumens over the Nichia on LPW?
Flashlights:
hIKARInoob
Output data is quite wonkey bonkey. This approximate output of 5100~6800 is only applicable to the first version which is not for sale anymore. The current version should have an output (level 4) of around 3000 lumens. The first version also did not have a low (level 1 of) of 70~100 lumens. Instead it was more like 1~5 lumens according to the majority of the people.
It’s an amazing light, but quite unfortunate that spec data is a sloppy mess.
