FreeMagenta, do you have a MF-01 with 6 wires to the MCPCB or a revised MF-01 with 2 wires. I don’t understand why you are saying that they changed the low mode since the MF-01 reviewed here is the old one.
Thanks giorgoskok for the review. I agree with others about the heavy pics (15 Mpixels each it seems)…
I gather this is a first batch light and i noticed a couple differences from my second batch unit on the driver side.
- For some reason, on mine, the three screws around the brass ring are not properly counter-sunk and two of them do slightly protrude above the ring plane. Not sure whether the screws have bigger heads or the chamfer is narrower then on batch one.
- Mine has a double spring at the positive contact. Overall it is very stiff and i’m worried about the stress on the driver PCB each time i have to screw the body hard to make contact.
- Unless my estimates are way off, my second batch Nichia version barely reaches 8K lumen - on freshly charged BT 30Qs.
I do love the pure wall of light it produces for sure - especially in such a compact format. That satin black finish is a pleasure to handle too. However, the UI feels uninspired and the mode spacing is terrible IMO. I admit i’ve been recently spoiled by the D4 and the Q8…
Those screws sticking up could have a big impact and yes it does have dual springs now and i agree mode spacing is terrible. I don’t get why a lot of these companies can’t give their lights a configuration menu.
I’d like to see these tests done on the XP-G3 version of this light. Wouldn’t the XP-G3 version hold Turbo and High longer due to less heat? Honestly if that is the case, I’d opt for the XP-G3’s longer higher output duration.
Perhaps it’s similar to Haikelite MT03 IIRC? There is a timer, and after a period it checks temperature. And depending on temperature it steps down or not. So it’s both timed and temperature controlled. An example of a light that uses timed step down solely is Manker MK34 which always steps down from turbo after 25 seconds.
I am pretty sure that in v2 there is no timed stepdown in High mode (tested it with fully charged 30Qs - ENEDED - #2094 by FreeMagenta ) Not sure about Turbo, though yuhsin91123 tried it - and looks like it is purely timed, always @ 1:30 ENEDED - #1860 by yuhsin91123 . The High mode has temperature protection, but surely no timer.
I am curious to know why the XP-G3 version of this light is putting out 5100LM on high and the Nichia 219c is pulling 6800. I thought the XP-G3 produces higher lumens over the Nichia on LPW?
Output data is quite wonkey bonkey. This approximate output of 5100~6800 is only applicable to the first version which is not for sale anymore. The current version should have an output (level 4) of around 3000 lumens. The first version also did not have a low (level 1 of) of 70~100 lumens. Instead it was more like 1~5 lumens according to the majority of the people.
It’s an amazing light, but quite unfortunate that spec data is a sloppy mess.
I tested my v2 on high several times and got around 2950 lumens . Hand held it doesn’t step down but tailstanding it lasts 26 mins then steps down to 1700.
My v1 had ~70 lm output (roughly the same as v2)… v2 on High has ~3000 lumens, which is really nice, because in most cases it won’t stepdown when used outside. And it is still ~1,5hr of pretty stable light on 30Qs…
Weird stuff with output indeed. Yeah the 3000 lumens is awesome. Combined with the new boost driver that is able to hold turbo longer with depleting cells made me get the V2 as well. Bummer is that turbo output on V2 219c is about 1000 lumens less than V1 219c,
