Basically this new MF01 needs to be tested again. M43 can push turbo with cell voltage as low as about 3.5V with GAs (my own test), and the TM38 can push turbo with cell voltage as low as 3.3V TM28 4x XHP35 HI Review Video. New TM From Nightcore
Of course different settings, but we’re talking boost drivers here. Curious, curious, curious.
Seriously, if this new boost version can push 10000 Nichia lumens with cell voltage less than 3.7V, I’m probably getting it (again)! :sunglasses:
LED lifetime in ultra-low/moon mode is in any case academic. Whether very low constant current, or PWMed at much higher current.
They will last forever, in our usage.
People who need to understand the detail are making e.g. streetlamps or warehouse lighting that must last 25 years plus, on for maybe 12 hours/day on average in the northern latitudes, where I live. Cree e.g. provide copious data for professional engineers to deeply understand, run the LEDs at their most efficient current level (lumens/watt), understand how the silicone domes can degrade due to environmental contamination, even incorrect choice of e.g. o-ring seals than can outgass degrading chemicals, this is more and more a precisely understood engineering subject, and the likes of Cree etc. are continuing to refine their products for their real markets, which is not us.
Worry more about our over-driven turbo etc. modes, where heat and current density kills.We are usually pushing these things way beyond datasheet parameters.
Except for things like the MF01, where the extravagant use of e.g. 18 decent LEDs to kick out e.g. 10,000 lumens i.e. 555 per LED is very modest indeed. This is one of the last “mega torches” that I would have any concern about over-stressing the LEDs, assuming good thermal protection, which by reports it seems to have, maybe even over-cautious.
10 minutes in turbo getting the torch roasting hot (who knows what LED junction temperatures, upper limit is melting point of solder, where the none-lead stuff is better) might be equivalent to decades in moonlight.
Interesting to discuss, academically, but of no practical relevance, IMHO.
Indeed. Everything has changed. And I have high hopes. Even if not perfect, I like the direction they have taken, it has so much potential beyond simply connecting a cell to an LED via a FET, or a buck driver.
yeah in reality you get at least 10000h to 50% in CC moonlight
what often people underestimate is thermal shock during reflow, it can make an LED fail after 30-50h
Yes, flow (not re-flow) is very relevant. Manufacturers will publish a profile for soldering, based on commercial equipment, starting with a pre-heat at 100+ C to bring everything up to temperature and dry out the solvents from the solder paste, then a sharp ramp up to melt the solder, even as high as 250C, then a sharp ramp down again to the safe 100+ temperature, then a gentle cooling. The best commercial equipment will even do all this in an inert atmosphere . The pre-heat phase and subsequent cool-down is very important, but not something easily done with DIY equipment, but it is possible to get quite close, if interested.
Pre-heat, and slow cool down reduces thermal shock immensely.
I was just getting ready to put the cells on the charger and noticed they where at 3.68v so i took it out and tested it.Started out at 9670 with 9220@30s.
Hold on… let me repeat what I just read here… 3.68V… You put them in the MF01 second gen (with one pair of wires to led board)… And you get 9670 lumens at startup, and 9220 lumens at 30 seconds? Cuz if this is so… then I’m so getting some more…
(P.S. With 3.7V I get about 6000 lumens from my first gen MF01 219C)
Wow, thanks a lot JIGHEADWORM for measuring. I believe level4/high mode is reduced from ~5500 lumens to ~3000 lumens as well. This means the light should run almost continuously on this level without stepping down as well. My concern is that another member here (patmurris) only measures about 8000 lumens instead of ~10000. So far things look really good though. :+1:
[quote=Tom Tom]
They will last forever, in our usage.[/QUOTE]
Unless someone keeps the light constantly in moon mode (in case of power outage it allows to find it fast…). Then that 20k hours - instead of 100 - lifetime can be important…
I’m getting pretty excited to upgrade my MT-01 with Lexel’s new driver and NarsilM. I pulled the trigger last night and it’s on its way to me as we speak!
First I got my D4. Then a pair of Q8 lights. Now I’ll add another ramping light with my MT-01. :sunglasses:
When you cant hold the light on the tube anymore and the head would burn you, then the LEDs will be still OK with junction temperature, but your hand cries ramp down
The good thing is that the LEDs are not driven hard, so even if the head would hit 80-90dC the LEDs would not be at their limit of 150dC
