With such flexible options in 16mm you donāt have much room left. You better use kapton, electrical tape, or epoxy to make needed insulation.
They look very attractive! I will surely be in for some, no matter what price they will be, more of course when they are affordable
Just when we though they couldnāt be more pricey, then the custom added some 40% more to the billā¦ā¦
Iām still trying to simulate your Djozz test here. The only datum to your test is the S3030 VirEnce board, 144AM sm653 R70, and the TASI meter test. Will report the test ASAP.
- Clemence
Amazing #1 test result! Check the OP
- Clemence
Theyāre so pretty. Canāt wait to order some!
Final touch by Texas_Ace
Awesome results, really excited to finally have a good option for 144A and E21A!
Great results!
These boards are also nice for an Oslon version, because the thermal pad of Oslon Blackās (that is connected to led-minus) can then be electrically insulated from the body of the flashlight.
Created many centering/positioning jigs, spent two VR16SP4 boards, some E21As (fortunately the R70), and one full day without success. Only later, I remember I didnāt stir the thermal paste after left in the fridge for weeks. Now the reflow works flawlessly. No gimmicks, just simple drops of solder paste and light tapping using flexible bamboo stickā¦ā¦and voila! The said to be difficult to solder E21A moved themselves to the correct position. The ultra thin solder mask do works. Perfect quadtrix board!
Many manufacturers gave up on E21A because it has very little to no self aligning behaviour during reflow. Thus requires very accurate PNP and solder dosing machine. But with very thin solder mask the self align effect restored back, even at very little solder paste applied. Thinner solder bond line, easier manufacturing, at the expense of fragile solder mask.
I use Sn96,5Ag3Cu05 (max. 260C @30seconds), with Sn63Pb37 reflow should be far easier.
I still have few hours before my flight, will post later.
- Clemence
OP updated with the latest test results of E21A
- Clemence
Iām still wondering how in parallel config those E21As performed significantly far more efficient. Iāve never seen anything like this before. Tested some XPGs 219Cs in single and quad parallel, but the difference between the parallel vs single config were never as high as E21A.
In parallel, the current divided into 4 lower current paths hence the boost in efficiency. But look at the chart below. Itās not lumen, just measured lux from my lux meter. At the same power level (near 3A), the output already doubled. My guess is E21A is super inefficient above 2A, while in low current its the other way around. To the eye 4p was indeed much brighter than the 1s config (at the same power).
The lower voltage also a good thing, most likely due to the lower resistance not only due to the hotter 4 cramped LEDs. The voltage reduced from as low as 100mA where heat is unlikely to affect the output.
Any idea?
- Clemence
I will have to read it all a bit closer (at work now) but that looks like a ton of good work! (it is not often that development work for new products is just published like this ) And the boards work very well, that should make them, regardless of the cost, at least worthwhile for niche aplications where performance is critical (flashlights! ), and who knows how cheap you can get them eventually. And these boards probably makes Nichia happy as well
Hi All,
Iām still waiting for the other testers to confirm about VR16SP4. This far no single complaints about the VR16S1. Looks like the VR16S1 prototype leftover is ready for sale. This board is ready to use for 144Ax, 233x, 119x. The next upgrade would be smaller pads gap to better accommodate E17A and E21A (after some scrap-mod). And perhaps better guide markings for any LED other than 144Ax. I havenāt measured the output with 233A/B Nichia UV LED, but judging from the 144A results, Iām more than sure VR16S1 is the best non DTP UV board available.
I see no strong reasons to use E17 and E21A in a single setup on VR16S1 other than they have very wide high CRI selection available. But hey, you can solder two E21As or three E17As on VR16S1 to get oval beam (2p or 3p config). If you interested in doing so then please remember to space the LEDs as far as you can to make the phosphors cooler. Unlike common flashlight practices, photon cross talk is a big problem here. Anything escaped from the side will heat the neighboring area. This problem is what actually limits E series from high power single LED use. I will explain this phenomenon later in the OP.
The VR16SP4 should work excellent with E17A. Paired with quadtrix E21A itās limited to only 20 watt before the phosphors start to burn.
VERY limited quantity working prototypes available for sale. PM me if youāre interested
- Clemence
It is interesting that 4p config starts to drop at just 1.2amps per led. The heat is still really limiting these leds. So in 4p it only gains the ability of 4 more watts but the efficiency is significantly better and results in much higher outputs regardless of the heat sharing.
Tested in 2s2p (6V) last night. Peaked at around 22 watt @3,8A. The lumen output was very close to 144AM up to 3,8A, only ~ 8% less at peak current. Not bad for such a domeless LED. I expect even higher efficiency and more total power in 4s config, would probably beat 144AM/AR. This is a strange breed of Nichia
- Clemence
Strange and interesting indeed
Now we just need the rest of the tint spectrum in E21A R9080. Iāll be picking up some of these boards and the 3 E21A tints currently available once everything hits your shop.
OPās chart updated with 2s2p test result for VR16SP4
Iām sure Iām not the only one curious about how this board performed compared to copper DTP. Am I correct?
Check the OP
- Clemence
I was, at least.
And they hold up very well! Thereās no real need for a DTP board with these. If this technology is getting a bit cheaper these type of boards can be a solution (for flashlight use) for leds without neutral thermal pads.
