What did you mod today?
8539 posts / 0 new
Nicolicous
Nicolicous's picture
Last seen: 5 hours 1 min ago
thanks man.
im going to convert all by black flashlights to white (without being racist) Big Smile
Nico -.-
MascaratumB
MascaratumB's picture
Last seen: 3 hours 29 min ago
Nicolicous wrote:
thanks man.
I’ll probably end up trying to make this in other lights as well!! Even my girlfriend said this light was prettier Blushing
Please be careful with the “needed” anodization, like threads or other important parts! Thumbs Up
OH: One thing I forgot to mention is that I made this in my kitchen and I kept the exhaust ON to help on air ventilation!! The smokes and vapour and smell is quite nauseous!!
[REVIEWS] ACEBEAM: H20 / TK16 /// AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 /// BLITZWOLF: BW-ET1 /// BRINYTE: T28 /// DQG: AA Slim Ti /// FIREFLIES: ROT66 GEN II /// HC-LIGHTS: SS AAA /// KLARUS: XT1C /// LIVARNOLUX: 314791 /// LUMINTOP: Tool AA V2.0 + Tool 25 /// NITEFOX: UT20 / ES10K / K3 /// ODEPRO: KL52 / B108 /// OLIGHT: M2R Warrior /// ON THE ROAD: M1 / i3 / M3 Pro /// ROVYVON: A2 + A5R / E300S / A8 /// SKILHUNT: M150 /// SOFIRN: SF14 + SP10A / SP32A / SP10B /// WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 /// XTAR: PB2 Charger ///
Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 /// TIR Lenses: 1 / 2/// Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 ///// My Collection ///// My Review's Blog (PT)
OL Contest 2019
GIVEAWAY: 1 / 2
DB Custom
DB Custom's picture
Last seen: 1 hour 10 min ago
I got my first BLF Q8 in yesterday. It looked fabulous and worked the same, making 5409.6 lumens right out of the box on a set of Sony VTC5A with copper buttons soldered to the top. But of course, I felt like 5000 lumens was too weak, so…
I started off with small changes and checked for the differences with freshly charged cells. Like, I swapped out the screws for brass ones. Boom! 328 lumens for a mere brass screw installation. So I tried an UCLp lens swap, not so much gain, only 41 lumens, not worth buying a lens for. Then I pulled the pcb with springs from the tail, removed the dual springs, and re-flowed them onto a copper sheet cut to fit the tube. That netted another 93 lumens. So then I put 22 ga wire bypasses inside the dual springs. Tedious stuff, that! And it made the single most difference, 1214.4 lumens gained for the effort! Big Smile
Then I decided to get real, I pulled the driver, replaced the leads with 18Ga Turnigy wires, removed the MOSFET and used a premium Vishay SIRA20DP, swapped the XP-L V6 3D emitters for new XP-L2 V6 1C. And a whopping 3000 lumens gain!!!
Yes, the Q8 started at 5409.6 and did 5213.64 at 30 seconds, now it makes an outstanding 10,212 lumens at start with a drop to 9,177 lumens at 30 seconds. I don’t have a way to measure amperage, but I don’t think I really want to know…. Wink (of course I know how, I just don’t want to!) [based on previous experience, amperage is going to have to be up around 28A to maybe 30A, ridiculous, I know]
bwings
Last seen: 2 days 3 hours ago
Nice Work MascaratumB Thumbs Up same as mine here, Stripped with Caustic Soda, I also shorten it a bit. Smile
____________________________________________________________________________________
Sorry for my poor English
MascaratumB
Nice work there, too Big Smile I guess I won’t shorten it due to batteries and springs, but thats nice Wink
I also thought about a illuminated tailswitch, I’m going to buy one for this and maybe for other lights Silly
And then, driver and LED modification!
Thanks for sharing Thumbs Up
OL Contest 2019
GIVEAWAY: 1 / 2
sac02
sac02's picture
Last seen: 2 days 22 hours ago
DB Custom wrote:
… replaced the leads with 18Ga Turnigy wires, removed the MOSFET and used a premium Vishay SIRA20DP, swapped the XP-L V6 3D emitters for new XP-L2 V6 1C. And a whopping 3000 lumens gain!!!
Swapped a V6 bin LED for a V6 bin LED and gained 3000 lumens… Crazy
Since you did it all at once, what is your gut feel on how that 3000lm breaks down?
18Ga Turnigy wires: x%
Vishay SIRA20DP fet: y%
XP-L2 LED (lower Vf): z%
DB Custom
DB Custom's picture
Yeah sac02, I kinda wish I’d followed what I’d been doing and done one thing at a time and measured in between. The 18Ga wires probably helped a little but I wouldn’t think that’d be a big jump. The FET made a difference, more so than the wires, but in the end I think the XP-L2’s were the major change. 700 lumens between a modded XP-L light (for each emitter) means 2100 lumens easily right there in the emitters. Tom had seen around 7100-7200 which was 1800 lumens per emitter, looks like we can attribute most of the gains to the next gen technology. Wink
bwings
Cheap USB 14500 light running NarsilM_1.2
I sacrificed the charging plug and add 10mm Neodymium Magnet Smile
Bought from AE for $5.19 each
i42dk
i42dk's picture
Last seen: 1 day 3 hours ago
Bought from AE for each
Got a link ?
Looks like a good mod project
TBone
Last seen: 2 days 20 hours ago
i42dk wrote:
Got a link ?
This one.
bwings
i42dk wrote:
Got a link ? Looks like a good mod project
I bought from this store http://s.aliexpress.com/bAJjQVN7 , price has gone up a bit.
i42dk
i42dk's picture
TBone wrote:
i42dk wrote:
Got a link ?
This one.
Thanks Smile
DB Custom
DB Custom's picture
Don’t know if you could call it a mod, exactly, but I’m very very happy with DBC-06.7… 24 hours of lathe work, then final assembly including building an A6 driver.
The emitter is a de-domed XM-L2 from MaxToch, clean job on the de-dome they did. It’s new gen, so it only pulls 4.61A but makes 1652.55 lumens. Final tuning it does 815Kcd for 1974.57M throw, which is 1.122 Miles!!! Big Smile
I made the tail cap (more of a plug) the body (from a single bar of 2.75” 6061) the reflector adapter (from a 4 1/4” bar of 6061) and the bezel (also from the bar of 4 1/4” 6061) The copper pill is 35mm dia and 35mm tall. Cell is the TrustFire 32650 by design, the plug in the tail has long threads to allow the use of anything from a 26500 to a 21700 or 26700, even the protected variation of 32650 works. Lens is a custom order 3mm thick 104mm UCLp from Chris at flashlightlens.com.
I went with an oversized variation of the small 18350 light I built last year where the battery tube looked like twin thread spools stacked, this allows cigar grip even on this 1234 gram light! Big Smile
Edit: PS, if you think turning a 4 1/4” bar of 6061 on a 5” chucked Grizzly 10×22 lathe is easy, you’re sadly mistaken!
giorgoskok
giorgoskok's picture
Last seen: 5 days 11 hours ago
Wow Dale , what a beast !
Did you use KD 86mm reflector ?
DB Custom
DB Custom's picture
The hot spot is actually smaller than what shows in that last pic, the tiles in the picture on the wall are 12” square, the hot spot is about 8” at this distance.
Not exactly sure where the reflector came from George, it’s bigger than that though. A friend sent it to me and laughingly said see what you can do with this! He said there weren’t any more and the mfr quit making them. I was planning to build this light already, had the battery tube bored for the 32650 and was intending to use the reflector out of my Olight SR-90 Intimidator since I have the Lum 5-90 in that light. I think that’s what inspired my friend to send this one, going big go all the way… lol
I was talking with another friend with machining experience about the sheer size here, I only had the 4 1/4” bar and it wouldn’t be big enough to machine a head for this 98mm reflector, so he said why not just use it as a stressed member, like Ducatti does their engines? And so I did, threaded the reflector to fit the machined body part and bezel. Out of the ordinary, but then, it’s no ordinary light. Big Smile
So I guess I modded 2 bars of 6061 into a flashlight. hahahahaha
Edit: This pic should show how it all started, the full sized bars are pieced together for testing of an emitter inside the reflector. I used my power supply for this test, but you can see the sheer mass of aluminum I had to carve away, hence 24 hours on the lathe…
CRX
CRX's picture
Last seen: 59 min 44 sec ago
Very nice
DB Custom
DB Custom's picture
Thank you CRX, appreciate it.
Sure has been a black hole for my time. lol
KawiBoy1428
KawiBoy1428's picture
Last seen: 45 min 26 sec ago
That’s pretty neat there Dale! Your machining skillz are off the hook!
KB1428 “Live Life WOT
mizou51
Last seen: 6 months 1 week ago
i love that thing ! well done!
DB Custom
DB Custom's picture
Thanks Kawi, appreciate it, coming from someone that knows real lathes!
Venom
Venom's picture
Last seen: 5 months 9 hours ago
Excellent machine work!
The last picture kind of remind me of the Statue of Liberty torch.
DB Custom
DB Custom's picture
Couple of beamshots from DBC-06.7
DBC-06.7 at 610 yds to the barn, 1st shot is at 28mm 1/2 sec exposure at f/5.6 ISO1600, second is same settings, but zoomed in at 112mm.
giorgoskok
Just look at that big spot… Awesome !
DB Custom
DB Custom's picture
George, look at how the hot spot throws a shadow onto the building from the tree between me and the barn…. the tree is 296 yds from where I was standing and 315 yds from the barn!!
The hot spot probably looks larger than it really is because I couldn’t hold the light steady in the 1/2 second exposure. The meds I’m on for nerve pain make me shaky. It is what it is.
Here’s a shot where I mounted the light on the tripod, same settings. I don’t like the lower light position as much as the overhead shot, but it is more stable for sure…
giorgoskok
That was interesting . I guess it will light this barn even from 1000yds . Wink
What is the diameter of the reflector ? I would guess it’s over 85mm to give such a throw on a xm-l2 !
DB Custom
DB Custom's picture
97.5mm, opening.
giorgoskok
Massive ! Always handy to have spare reflectors when you own a lathe…
Tally-ho
Tally-ho's picture
Last seen: 3 days 13 hours ago
DB Custom wrote:
…I only had the 4 1/4” bar and it wouldn’t be big enough to machine a head for this 98mm reflector…
DB Custom
DB Custom's picture
In retrospect, I could probably have used the 4.25” bar and threaded the end for an internal bezel, more of the retaining ring variety. Wish I’d thought of that when I was figuring out how to go about it as I’d like to have had the reflector encased inside a head as usual. Oh well, little to late to do the right thing now…
giorgoskok
I don’t think you will make anytime soon another bezel Dale , haha !
