In - Amazon
I’ll take 4 of them. Christmas time is just around the corner.
amazon
In
in please
In!
Any info on the capacitor added to remove the pre-flash?
Problem fixed, later I will try to add something in the OP.
Problem fixed. We have manually fixed the drivers, made 3 samples. Video here.
No pre-flash. OK.
Starts at moon after 3 seconds off. OK.
Will make a new batch of drivers and then assemble.
I could send you new drivers . But the driver is press-fit into the alu pill, it might be hard to pull out. I might send the whole assembly. Easier to swap.
Driver = 4$, assembly = 6$
Amazon.
Any chance of getting the new driver or assembly through Amazon as well?
Light from amazon, driver from me later.
Mine is on the way from Massdrop — thank you for the partial refund, WWEFANS.
Once it gets here I’ll see how much the pre-flash and memory bug me. Who knows, maybe the refund/rebate will just go to subsidize another order from Amazon
Right on. Thanks.
in.
amazon.
thank you.
edit: with assembly, please.
Rey, mine with assembly, please. Thanks.
Rey, My unit cheap as possible! thanks.
(I am 30 in the list)
Mine with assembly please. Thanks.
In.(Amazon).
Thank you.
It really doesn’t bother me in everyday use. Hardly noticeable unless I look at the LED closely.
Seems there isn’t many MD users here.
In for one, thanks.
In for one, please.
