ReyLight Pineapple mini (copper) AAA/10440 flashlight (OP Updated)
I’ll take 4 of them. Christmas time is just around the corner.
amazon
In
in please
In!
Any info on the capacitor added to remove the pre-flash?
Problem fixed, later I will try to add something in the OP.
Problem fixed. We have manually fixed the drivers, made 3 samples. Video here.
No pre-flash. OK.
Starts at moon after 3 seconds off. OK.
Will make a new batch of drivers and then assemble.
I could send you new drivers . But the driver is press-fit into the alu pill, it might be hard to pull out. I might send the whole assembly. Easier to swap.
Driver = 4$, assembly = 6$
Amazon.
Any chance of getting the new driver or assembly through Amazon as well?
Light from amazon, driver from me later.
Mine is on the way from Massdrop — thank you for the partial refund, WWEFANS.
Once it gets here I’ll see how much the pre-flash and memory bug me. Who knows, maybe the refund/rebate will just go to subsidize another order from Amazon :slight_smile:
Right on. Thanks.
in.
amazon.
thank you.
edit: with assembly, please.
Rey, mine with assembly, please. Thanks.
Rey, My unit cheap as possible! thanks. :smiley:
(I am 30 in the list)
Mine with assembly please. Thanks.
In.(Amazon).
Thank you.
It really doesn’t bother me in everyday use. Hardly noticeable unless I look at the LED closely.
Seems there isn’t many MD users here.
In for one, thanks.
In for one, please.
In - Amazon
