I thought continuously variable was too much to ask for and now I hear itās built in? Thatās great! I thought that the term, ārampā on the cheat sheet meant moving between the discreet levels in the chart below. Now Iām really excited for this light. And I promise to keep quiet.
Having 150 levels in the ramp means that it dials up as smooth as a rotary dimmer, very nice! Once you use it, it makes most everything else obsolete.
Thanks for that story HarborSeal, very interesting and informative. Weāll have to plan our freefall traps better from now on, knowing youāre armed with 4500.
As for the XP-G3, I donāt like em in anything Iāve tried. And Iāve tried em a LOT of ways. So, no worries, Iāll just pull em and file em.
Whereās the ālikeā button? So many good replies here and I donāt want to clutter up the thread.
Iām no expert but I thought the green/purple separation was only on 4000K CCT and went away with a very mild diffuser. Now I know that a diffuser is the opposite of what some people want from an XPGn but I thought a lightly diffused XPG is still going to throw better than a Nichia - is that right?
Iām a huge fan of continuously variable (which I now understand is essentially the same as the Narsilās ārampingā) but it never seemed to get much traction on CPF. My favorite small lights are the Sunwayman V11R and its 18650 counterpart; both modded to 4500K and bumped a bit by the justly famous Vinh Nguyen. My favorite headlamp is the Nitecore HC90, also modded to 4500K and bumped at the top end. The green light is great when insects are swarming you and youāre breathing in moths.
Harborseal, take a look at the Nitecore SRT6 Night Officer, itās a rotary dimming light that is really sweet. On/Off or lockout at the tail, full function in the rotary dial so it can be pre-set before turning it on at the tail, youāll know pretty much exactly what yourāe gonna get when you click the tail on. You can leave the tail switch on and itās got a power on indicator, sleep through the right position on the rotary. Left from sleep is SOS, full right is Strobe.
They said it makes 900 lumens on an XM-L and I checked it at about that, pulled the XM-L and used an SST-40 going back in and it makes nearly 1500 lumens now. Only thing I changed was the emitter. Pretty neat light!
Would you put me down for another one please. 2 total
Thanks
Please put me down for another as well. Thank you. :+1:
Well sign me up for one moreā¦
Yes will do
Thanks for saying it is not the first, makes me add ā2ndā and such for better overview (it is impossible to remember all on all the lists )
Please add me on the list for 1 FW3A.
Yes will do
Miller, my first is 158 and my second is 488 if you want to put a ā2ndā after it.
Please put me down for 1 of these amazing lights! :)
Many thanks,
-Ben
Could you please add me to the list for one?
Will update listlater, ha and of course Peabody will do that too!
If the list is still open then sign me up for 1
The list should be open for a few months at least. This is definetly a 2018 light.
Yes welcome and will update list later!
Could you add to tge list please.
It seems that my post from May never made it. Please sign me up for two.
Oops, yes will update and correct list later, today.
EDIT MARK and lis updated
