Where’s the “like” button? So many good replies here and I don’t want to clutter up the thread.
I’m no expert but I thought the green/purple separation was only on 4000K CCT and went away with a very mild diffuser. Now I know that a diffuser is the opposite of what some people want from an XPGn but I thought a lightly diffused XPG is still going to throw better than a Nichia - is that right?
I’m a huge fan of continuously variable (which I now understand is essentially the same as the Narsil’s “ramping”) but it never seemed to get much traction on CPF. My favorite small lights are the Sunwayman V11R and its 18650 counterpart; both modded to 4500K and bumped a bit by the justly famous Vinh Nguyen. My favorite headlamp is the Nitecore HC90, also modded to 4500K and bumped at the top end. The green light is great when insects are swarming you and you’re breathing in moths.
Harborseal, take a look at the Nitecore SRT6 Night Officer, it’s a rotary dimming light that is really sweet. On/Off or lockout at the tail, full function in the rotary dial so it can be pre-set before turning it on at the tail, you’ll know pretty much exactly what your’e gonna get when you click the tail on. You can leave the tail switch on and it’s got a power on indicator, sleep through the right position on the rotary. Left from sleep is SOS, full right is Strobe.
They said it makes 900 lumens on an XM-L and I checked it at about that, pulled the XM-L and used an SST-40 going back in and it makes nearly 1500 lumens now. Only thing I changed was the emitter. Pretty neat light!
Yes will do
Thanks for saying it is not the first, makes me add “2nd” and such for better overview (it is impossible to remember all on all the lists )
Here’s a triple XP-G3 Wuben light with the AR lens removed. Supposedly 90 CRI. Not bad if you ask me, as long as Lumintop doesn’t put AR glass on it. Looks quite nice outdoors.
The driver is a FET+N+1 design, so it should have regulated output up to around 3 amps, IIRC, and the ability to go much higher than that for turbo modes. Output will mostly be limited by ability to dissipate heat.
The driver itself is custom-designed for this light.
