Nice review! I just got my D1 yesterday. But I know I need a D4 but I don’t know to replace my UT02 with the D1S or not. I want to reduce my flashlight quantity and I became a big fan of side E-switch form with ramping firmware since my Q8 came to me
Please make some outdoor beamshots with the D1 and D1S!
Great review. If the lumens and throw aren’t that much different and the battery tubes aren’t compatible with the D1/D4 I probably won’t buy this light. Give us a bigger battery and at least twice the throw and I will jump on it!
Do you use it in high and turbo only?
I do mostly on low-medium.
Anyway, I guess Emisar ramping is not perfect for you. You’d be better off with a ramping UI that starts high and goes up from there.
You are probably talking about your D1 that is a flashlight with throw, not a thrower for me.
Was talking about the D1S with ramping UI.
I don’t see the point of using a pure thrower in low mode, except if you have only 1 flashlight, because for close range there is better type of flashlights, generally speaking.
