I think you are referring to thermal regulation... Active cooling does not exist in any of lights. From Maiden666's review https://budgetlightforum.com/t/-/47092 you could see X80 is above 50Ā°C @1min which Astrolux MF-01 is not programmed to go beyond this mark. To be honest, 70Ā°C in 2min is pretty insane.
I think comparing this light to an acebeam x80 is ridiculous.You could buy 2 mf01ās, a BLF GT,and aemisar d4 to throw in your pocket for what it costs.
Once again.
Nobody is talking about pid regulation with turbo return after temp goes down.
One guy just supposed that there is no real thermal step down in MF01. I.e. step down time do not increase when heat spreading abilities increased (by any external factor).
I feel the MF01 does a good job protecting its light, it does drop the output depends on temperature. Remember, I was running on high mode for almost 35mins so the light is already hot. I go from high to turbo without cooling it down.
When the light steps down I can choose to turbo it back on. But the light would just step down again to protect it.
The temperature isnāt really that bad to my hand at all to be honestā¦ I can still grab the light by the head on turbo.
And I just tested turbo mode on MF01, it runs about 1 minutes and 37 seconds before I see the step down.
And test my HaikeLite MT03 (over 9000 lumens) runs on turbo over 3 mins and I see no stepping downā¦ the head is no where near the temperature of the MF01 on 1 minutes turboā¦ I guess Nichia is just a high heat light. Maybe XP-G3 has lower heat?
V1 of the driver didnāt reduce for a few minutes (Nichia version, Samsung 30Q, used outside 8deg C/44F, ~20mph wind, light rain; the head was ~40 C / 104F). I stopped the test after 4 minutes, no brightness reduction.
My turbo test was done indoor with no wind and at room temperature, I wounder if I keep the light cool would make a difference on stepping downs. I guess I can throw my light in the freezer on turbo and see what happens lol
However, it was a V1 driver. And the light suddenly turned on and stayed on (couldnāt turn off, one bank of LEDs on full power) shortly thereafter, so possibly it was just a symptom of faulty driverā¦
Is your light from first or the second batch?
PS. Still no further info from BG - they gave me an order number for the MF-01 head but I canāt find it anywhere.
