Go get em old lumens ,lol. Yes disassemble the entire light , only cook or torch the aluminum parts that are anodized, burnt rubber stinks;)lol
Sorry, I wasn’t talking about the rubber parts, but about the tailcap itself,
without the rubber/plastic parts.
I suppose that heating up aluminum will let it expand a bit
And I thought that 2 parts could get a little different afterwards and not fit anymore.??
Tailcap and body, or head / bezel and body
I am also concerned about change in the aluminums properties.
There is a chance they could lose strength isn't there? Or deform in some way?
I had some pricey cast aluminum rims and just the heat used to bake them after being powdercoated took away alot of their strength. I know its just a flashlight, not a critical automotive part, but I just think bad things when I think of heating aluminum now lol.
I was worried about the tolerances being off after 'broiling' my tight-tolerance built flashlight haha
I don’t think that should be an issue unless u heat it to a melting point , which I don’t recommend I and it seems many here now haven’t had a part not fitting back issue yet but again just my two cents , I’m no pro ,I’m just a person that likes to experiment ,lol
No issues here. The melting point of aluminium is 660C so we aren't even close to the point where dimensional changes will matter.
The alloys used in lights will melt at a lower temperature than that 6061 melts at around 600F
Dimensional changes may matter a oven temperatures but I've not seen them to be an issue.
probably worth mentioning, I'm stripping the ano from aforementioned D1 (w/ super clean) and the parts that I heated VERY hot w/ the torch are much more difficult to strip. Probably doesn't imply the coating is more resistant to mechanical wear, but it is definitely more resistant to alkali
From what I could glean from the interwebs, it's likely due to a contraction in pore size.
During anodizing, it's recommended to rinse with COLD water before applying dyes, as hot water will close the pores in the metal, inhibiting dye penetration.
I bet that once the reaction starts, it comes off with extended soaking time.
I plan on doing some selective ano removal, then off to the broiler. Orange/silver, anyone ?
Well this is funny , u will never guess this nor wouldni, my wife and I were cooking some shake and bake pork chops and she saw me playing with my dry the other nigh and asked me to do hers, lmao so while oven was hot I stuck it in there , but I have to have one of the coolest wives ever ,hahaha I’ll post pics when done
The Sipik looks very nice after the trip to the spa.
Do you happen to have any good stock picks or lottery numbers you'd like to share?
Bet the house on the giants Sunday ,lol I’m kidding
the fact that she even owns one proves that!
so, the ano wouldn't come off the bezel at ALL - 2 or 3 hours in super clean - I even took it out once and heated the super clean in the microwave. for comparison, all the ano came off the tailcap in less than 15 minutes.
I just sandblasted the whole thing because on other parts where some came off, but not all of it, the exposed aluminum was fizzing from reaction with the super clean
I also tried scraping the spots the super clean wouldn't remove - the heat definitely made it MUCH tougher than the original finish
YMMV...
Cool so now we have HA 2.5 lol For Free
Btw when I bought the first 2100 ,she said quickly she wanted one , she liked it better than her surefire and it was brighter ,lol
I had no idea . . . definitely gonna try this tomorrow.
agentorangeFoy
I had a brand new oven installed last night. Should I hmmmm. yes- no yes- no yes- no. Maybe I need to start a Poll. hmmm. ah- no. But I do have a heat gun. lol
I just blowtorched my kdc8. Took only 2 min per piece. Photo is pending
Aren't you supposed to run a new oven on HI, to burn off any manufacturing residue?
You would actually be doing your wife a favor by doing that step for her.....
she already did that- otherwise I could have got away with it.my blowtorch is much quicker though it pays to heat it evenly.
I ended up cooling the parts in water. warning it takes a while to cool. Notice the colour variation. That was caused by heating one side too much.
I actually like the two tone look , I did my dry on purpose , possibly the oven heats the parts evenly so u get a closer match , but I think some parts may have been anodized at different times and u get a variation in color changing ,maybe?
I think thicker aluminium heats up slightly slower too but then cools slower so more time to change the color. I should have immersed it quicker. Great idea. Next time I will try my heat gun instead.
