I believe the numbers may be OK.
You just need to focus 2 (3?) flashlights at the lux meter.
Looks like a Convoy C8 rebadge.
with BLF A6 driver, and a bit pricier
I want a triple LED C8 like Sofirn did too.
BTW, what’s the best throw one can achieve with an XP-L HI and a FET driver in a C8 ? Like 100kCd ? less ?
They could mount it with XP-L HI and Bistro or even better with Narsil
125kcd must be possible, perhaps not 150. My clear Convoy C8 (AR-coated lens, good reflector, direct driver, dedomed XP-G2 S4 2B) does 180kcd.
it will be great if u colud make ur own design and then buy it, nobody do that, what a pity
120-125kcd is possible with xp-l hi & fet driver
Even that seems a tad high. Apparently the Emisar D1S was tested at around 1300 lumens and 120 kcd (TK’s review reported less, but it seems her testing equipment always runs lower than most), and that is with a larger reflector. Hard to believe a C8-sized reflector would be able to match that, much less beat it.
The Convoy C8 with XPL-Hi and smooth reflector seems to clock in at around 1000 lumens and 70 kcd. So I would guess this thing, with an extra 30% more lumens, will clock in somewhere around the 100 kcd mark.
My C8 with xpl-hi, blf a6 driver, spring bypass and ar coated lens does about 87k lux.
Build the same one, but with xp-g2 (dedomed in gasolin) and unfortunately it had around half lumen, 2/3 throw and 3000k tint afterwards
I thought D1S had a C8 sized reflector , are there it’s dimensions in any post ?
Haven’t seen a teardown to confirm reflector size, but the head diameter of the C8 is about 44mm, compared with 50mm for the D1S.
My measurement.
C8 XML2 U2 + AMC7138 x 8
850-LM 30,000-cd
C8 silver + new firmware 12 modes
850LM- 60,000cd-
C8 XHP35 Hi + H2-C
1400LM- 70,000cd-
Nitecore P30 spec 100,000cd
my measure 1000LM 85,000cd
C8 SST40 dome + A17DD
LV7 : 2300LM± 84,000cd
LV6 : 1400LM
LV5 : 750LM
Utorch UT02 CW
1000LM 90,000cd
C8 silver + A17DD
1400LM- 110,000cd- best focus
C8 XML2 U4 dedome + A17DD
1500LM- 120,000cd-
C8 SST-40 dedome + A17DD
2000- LM 130,000cd-
I have XML2 U4 50+ pcs. , XPL Hi 50+ pcs , SST-40 from KD 40+ pcs.
Some are high Vf but I choose lower Vf with my test.
Interesting development. Always wanted a low cost >100kcd 18650 thrower, and now there will be a choice soon!
My measurement.
850-LM 30,000-cd
850LM- 60,000cd-
C8 XHP35 Hi + H2-C
1400LM- 70,000cd-
LV6 : 1400LM
LV5 : 750LM
Utorch UT02 CW
1000LM 90,000cd
C8 silver + A17DD
1500LM- 120,000cd-
2000- LM 130,000cd-
Did you mod a c8 with a xhp35 hi?
I think a done up C8 with an XPL-HI would get around 90-100Kcd from my testing. My XPG2 and XPL dedomed C8s both do nearly 150Kcd i am not sure if my number are low. I have never been able to beat this number in a C8.
Looks like they may have updated the product page.
Now claiming 102kcd, which seems intuitively reasonable. If the Convoy C8 hits 70kcd at 1000 lumens, and the Emisar D1S hits ~120kcd at 1300 lumens with a larger reflector, 100kcd at 1300 lumens in the Astrolux C8 seems believable.
My stock Sofirn C8T does 80kcd, and that is as far I know the best stock performing C8 . For 15$ you get original XPL-HI V3 (2B/3B)tint not sure , 17mm copper DTP board, and bridged springs from factory….
With full battery 4.2 Amp at tail, so that Astrolux C8 must be driven up to 5.5-6 Amp to achive 120kcd
Nice! You get stock what used to be a proper mod. But 30 dollar is a bit too much for it, a Convoy C8 that basically has the same production costs, costs half of that.
