Test/review of Sofirn AA 2600mAh (Black-Blue)
7 posts / 0 new
HKJ
HKJ's picture
Last seen: 1 hour 18 min ago
DSC_0968
Official specifications:
  • Capacity: 2600mAh
  • Voltage: 1.2V
  • Chemistry: Ni-MH
  • Rechargeable: Yes
  • PCB Protected Board: No
Sofirn%20AA%202600mAh%20(Black-Blue)-info
Maximum temperature raise at different discharge currents: 1A:+1,6°C, 2A:+4,1°C, 3A:+7,0°C, 5A:+13,9°C, 7A:+19,6°C, 10A:+24,7°C
This is low capacity NiMH for the Sofirn brand (But high capacity for all other brands), how good are they?
DSC_0967
DSC_0969 DSC_0970
DSC_0971
DSC_0972
DSC_0973
Sofirn%20AA%202600mAh%20(Black-Blue)-Capacity
Discharge curves are not nice, but acceptable for NiMH and capacity is around 2600mAh.
Sofirn%20AA%202600mAh%20(Black-Blue)-CapacityTime
Sofirn%20AA%202600mAh%20(Black-Blue)-CapacityTimeHours
Sofirn%20AA%202600mAh%20(Black-Blue)-Energy
Sofirn%20AA%202600mAh%20(Black-Blue)-PowerLoadTime
Sofirn%20AA%202600mAh%20(Black-Blue)-CurrentTest
Sofirn%20AA%202600mAh%20(Black-Blue)-Charge
Conclusion
These cells are much better than the 2800mAh from Sofirn, this time the rating is correct and the cells has acceptable performance.
Notes and links
Compare to other AA/AAA batteries: Alkaline/NiMH/Lithium
kiriba-ru
kiriba-ru's picture
Last seen: 3 hours 38 min ago
Could you please add LSD rating some time after?
HKJ
HKJ's picture
I do not know the rating.
kiriba-ru
kiriba-ru's picture
I mean you can make your own rating.
I think you have some brand LSD AAs, just charge them and this Sofirn and leave for a year or near. And then measure voltage.
Maybe Im asking too much, but otherwise I cant compare them with enerloops and without LSD rating test is not so usefull IMO.
HKJ
HKJ's picture
kiriba-ru wrote:
I mean you can make your own rating. I think you have some brand LSD AAs, just charge them and this Sofirn and leave for a year or near. And then measure voltage. Maybe Im asking too much, but otherwise I cant compare them with enerloops and without LSD rating test is not so usefull IMO.
I will not do that.
To do that I would like some automatic equipment that logs battery voltage once a day on maybe 16 channels and I do not have time to make that just now.
EagleShield
I think he means a easier test like recharge the cells then put them where you store your batteries and take them out maybe once a month to check the voltage so you can make a fairly estimated guess how much they have selfdischarged per month or something.
HKJ
HKJ's picture
I will let other do that type of easy test.
What I describe about is fairly easy to make and do not need to be expansive, but it will probably take me a few days to build and that is the problem.
