[Oshpark] BLF SRK FET v3 (46mm / LFPAK56 / Dual+Triple Channel / ATtiny13A+85)
HQ/anyone! I hit 27K lumens with this v3.4 driver in a MT03! Wow!! Great job on this. Dunno, maybe the Hyperion FET helps a little. Never expected 27K, than means 9K per XHP70.2 in a NW tint! It's totally insane!
I added spring bypass's of 22 AWG wires on all 4 battery springs, and left the double spring on the driver as-is, just transferred them to the v3.4 driver of course. It ripped the 60C temp setting at like 15 seconds - ouch.
Oh! The Humanity!
Tom. Are you going mad? Blinded by the light maybe? Nice work. :slight_smile:
Any pictures of install or beam shots?
WHAT! That has to be 55-60 amps your pulling! :open_mouth: :+1:
Way to GO!! :beer:
My MT03 is almost here and I would like to do what Tom E did. Any details would be appreciated.
I haven't been able to repeat that reading, but I was seeing 24K-25K, same cells full charge, etc. Still it's pretty awesome.
Ohhh - just thought of it - I swapped the FET to a SIR404DP, think'n it might fix the 7135 problem, but it didn't. It blows the single 7135 - haven't had luck fix'n it. I changed the firmware to do blinks with the FET instead of the 7135, so the blinks work. The 7135 seems to work fine in ramping and mode sets, just would be do any blinks.
I ordered another MT03 II so it's on the way. Gotta check now if I have a spare driver... Hhmm... I did order 3 XHP70.2 P2's from Arrow to use for it - just don't want to take the chance on the XHP70.2's shipped with the new MT03.
Do I have pics? No beamshots, but must have some build pics...
Full set here: photobucket.com Haikelite MT03
Awesome!
So who do I need to talk to about getting one of these drivers made for me, I can solder the led and switch wires but dont think I trust myself to do the whole thing yet. Also would I be able to have “Narsil” or Toykeepers new ramping FW flashed on it for me? I have nothing to do that with.
One last thing, will I be able to do lighted switch?
I know Lexel is making some of the T_A drivers for sale. Maybe you could talk him into this?
Hhmm. Think I'm out of drivers, so if I order some, they come in 3's so I'd have extras. Yes - I got support for the lighted switch - actually mine is using the stock blue and it's a bit too bright, just haven't got a chance to tweak it. If you can wait a few weeks, I'd be able to build one up - doesn't take much more time from doing 1 or 2, or 2-3, etc.
Gentlemen,
long time no see
Tom, I knew this driver was in good hands with you. I’m truly impressed.
I implemented DEL’s C3/C4 and refined the design, see next post.
Have them in my hands already, looking very good, just no time for building…
Lexel, the temperature sensor is a direct implementation from RMM’s v2. I never used it myself, just kept it in the design. As far as I understand the sensor itself has 3 pins: T+ and T- are its power supply (hence T+ to the output of the LDO) and Tin is the sensed value. Tin is fed into the Attiny Pin3 through a 2-resistor voltage divider (Rt1/Rt2) to get the voltage down to a level the Attiny can evaluate (probably below 1.1V as for the LVP input at Pin7).
But now let me introduce you to v5.
I heard Photobucket is not the same anymore… Interestingly all my pics still show. I keep my fingers crossed, but I need to get a different hoster.
BLF SRK FET v3.5
Added C3 and C4
Rearranged LED+ vias
Still focus on High Current :wink:
https://www.oshpark.com/shared_projects/BFX7d296
Great to see that it’s still being actively developed! It looks good!
Del wrote place C4 as close as possible to the FET
I did that in my designs
Ah, hadn’t seen that he wrote that, thx.
Fortunately that is an easy fix.
I'm ordering as soon as the updates are ready . Glad I procrastinated on ordering the next batch of 3... I already got in another white MT-03 and don't have a driver for it yet.
Between the Infinion or the SIRA20DP, either is a great choice for these boards in a high performance light.
here you go :slight_smile:
BLF SRK FET v3.5A
https://www.oshpark.com/shared_projects/LZhFeMG8
Schematic:
Pin5 is hardwired to the single 7135 (Q1) for the low modes.
Pin6 and Pin3 can, using the fancy 4-pad-connector (aka QuadPad), alternatively be connected to Q2-11 or the FET.
For the Attiny13A: use Pin6 for the channel you want to PWM, be it the FET or Q2-11. Use Pin3 for the channel you want to just switch on/off.
Component list:
- 13A/85: MCU ATtiny13A or 25/45/85; 8S1 (SSU) or 8S2 (20SU)
- R5: series resistor between VCC and MCU pin1; 0805
- FET: n-channel MOSFET at Pin3 or Pin6; LFPAK56
- (Rgate): series gate resistor; use the QuadPad (FET-to-pin3 or FET-to-pin6); 0805
- Rpldn: pulldown resistor (gate to GND); 0805
- Q1: single AMC7135 at pin5; SOT-89
- Q2-11: up to 10 AMC7135 at pin3 or pin6; SOT-89
- D1: schottky diode (~0.25V) for 1S (4.2V); SOD-323
- LDO: low dropout regulator for 2S (8.4V) [LDO needs C1 and C2]; SOT-23-5 (Vout is pin5)
- C1: input capacitor between VCC/LED+ [behind R5] and GND; 0805
- C2: decoupling capacitor for MCU; 0805
- C3: additional capacitor between VCC/LED+ and GND; 0805
- C4: capacitor between drain/LED- and GND; 0805
- R1: voltage divider to VCC [before D1 / behind R5]; 0805
- R2: voltage divider to GND; 0805
- Rb: bleeder resistor from VCC to GND; 0805
- SW+: pad for momentary switch to pin2
- SW-: pad for momentary switch to GND
- Tin/Rt1/Rt2/T+/T-/Ct: temperature sensor
- I3/Ri3/I-: indicator LED at Pin3
- I7/Ri7/I-: indicator LED at Pin7
  • OTC: offtime capacitor for clicky firmware [using SW+]
Notes:
- Q1 can be used as Nanjg star 2
- Rt2 can be used as Nanjg star 3
- OTC can be used as Nanjg star 4
- a zener can be placed on Ct, which is MCU+ to GND
  • a momentary switch at Pin3 can be soldered to the QuadPad
Ordered! Thanks!!
Ooooohhhhhhhhh.
A first look at the next version.
Goal is to implement programming while maintaining high current capabilities. I will go with the “jester” design, simply because it’s more space-efficient.
In v3.5 the MCU was much more below the center and I really don’t want the cells to short with the ground via of the programming pad…
So the MCU had to go up, while the BAT+ vias should as well be out of reach for the cells. Really don’t want the cells scraping these vias. To keep as much BAT+ vias as possible, they needed to be distributed sideways… and the rest just fell in place.
Advantages are really fat current paths, be it from the ground ring to source, from drain to LED, from the cells to LED and for all AMC7135, where the route widens with the amount of 7135s. And having the output path of the 7135s not under them allows for larger ground pads of all 7135s.
Some finetuning needed and it should be ready.
could we please agree on one programming key standard?
why now make a 2. with different footprint and pin orientation?
2 examples of course depending on driver minimum is 2 viases and total of 6 pads and if possible no conducting parts left and right in the upper row, even if on latest I insulated on the key those pogos from ground
you can use your key on my footprint without any modification, reverse it does not fit
