Iām not sure if the C12 finning is the best possible design, but Iām sure they do something, they are increased surface area and near the heatsource. And to me they look like they significantly add to the heat shedding to the air compared to a C8.
No air flowing inside fins.
Any heatsink made to use without fan should have 5-8mm between ribs. Otherwise air flows same way as there is solid surface.
It is hard to explain. I hope somebody from forum have equipment to take thermal image - X6 is good example to show what I am saying.
Also, usually people think that ribs surface is smth special and more important than solid flats and curves. This is not so, in most situations ribs surface have half less air flow. This means thay you need to take just half of ribs area to calculate heat spread increasing (i.e. 200sq.cm + 20sq.cm/2=5% increase, all numbers are random). In most situations you need hundreds % to feel difference (modern leds quad/triple light have 20-30w power with 5-10w host abilities).
To avoid anyoneās confusion with what wstrachan wrote above, I wanted to point out that, although the name is the same, the KD C8.2 has the traditional C8 body style and looks nothing like this light, the Manta Ray C8.2 is a completely different looking light, and fits 26650 cell.
Somewhat similar to KD K5S but with knurling and no stainless bezel, thereās also an SST-40 version:
Seems that getting a decent budget oriented XHP50.2 1x26650 light is not an easy task. Would like to see a comparison between the KD K5S and the Manta Ray 8.2. Both have precisely the format Im looking for (C8 size reflector and 1x26650) but both have kind of deal-breakers for me.
The K5S offers steel bezel, OP or SMO reflector and also your choice of tint. However I find it really ugly, especially when compared to such classic designs like the Convoy M2. Not to mention the cheesy looking red O rings, green tailcap and smooth body with no manufacturer engravings.
The stock Manta Ray C8.2. has only SMO reflector by default, no choice of tints, but it looks better in my opinion. For some weird reason the manufacturer had to make one of the cooling fins thicker than the rest, ruining the looks somewhat.
Does anybody know how they differ performance wise, and which one dumps heat better? Manta ray says it has integrated design, does also K5S have it that way? Which one comes with better driver?
It seems you and I both have been around the forum lately looking for input on the Manta Ray C8.2 and so far we havenāt found much, probably just going to have to take a chance on it. I also like the looks of the Manta Ray better for the same reasons, but that one thicker fin doesnāt bother me, in fact I never even noticed it until I saw it pointed out in this thread.
Iām surprised you find the K5S ugly compared to the M2, to me the K5S looks like an M2 that takes a 26650 cell. Personally I donāt like either too much because of no knurling. Also the green tail switch boot is just a small cheap rubber part that can easily be swapped out with a black one, but you would have to remove the switch from the tail cap to do that.
The only things Iād like to see on the Manta Ray is a SS bezel and NW & WW tints, L4M4 pointed out in this thread (post #15) that a convoy bezel will fit, so when I get it Iāll try the convoy SS bezel, but it does look good all black too. It wouldnāt be difficult to swap the LED with a different tint if you can solder.
Iām probably going to get the host version and build it my way. L4M4 also noted it has square threads, which Iām happy about, and it I see the tail threads on the tube are anodized, so mechanical lockout will be possible. I recently ordered an F13 for a host but now Iām kind of sorry I didnāt get this host instead.
One difference in drivers was pointed out in this thread by L4M4 (also post #15), that it doesnāt have a flash going into Low that caused some complaints for the KD: āDriver UI is very useable (no flash like the KD driver at low mode)ā
Hereās some info on the drivers, I suspect theyāre pretty close to the same, maybe someone that knows drivers better will chime in and let us know more.
Drivers:
KD K5S uses the KD H1-A
I believe the Manta Ray C8.2 uses Manta Ray LC-15 because itās the only driver they sell that matches up with that light/specs.
Iām in the same boat; I am also looking for a 26650, and noticed the K5S and the C8.2. I wish the K5S had a host version available. I just impulse clicked the Acebeam EC50 gen III on Amazon as I wanted to try a XHP70.2 light. Thanks to this forum, I have purchased my first 4 LED lights in the last month!
Thrunite TC20 back in stock and shipping now, smaller size/lower cost than EC50 II.
I think the discount code is still active (not sure though) Thrunite TC20 - XHP70 - 3800lm
I've been playing with the C8.2 host recently. Very nice host, capable of taking a lot of heat. First I used it with XHP50.2 - nice, but I didn't like the tint shift at corona edges. Then I swapped the emiter to XHP35. O yeah - this is it. Very nice throw with on OP ref, led driven at 1,5A/12V makes the host barely warm after 10 minutes.
The picture shows Manta Ray C8.2 with SMO ref and XHP35 driven @ 1,5A (4000K, 80CRI)
