13576 posts / 0 new
The Miller
The Miller's picture
Last seen: 3 months 17 hours ago
Oops, yes will update and correct list later, today.
EDIT MARK and lis updated
RobertB
RobertB's picture
Last seen: 20 hours 35 min ago
Here’s a triple XP-G3 Wuben light with the AR lens removed. Supposedly 90 CRI. Not bad if you ask me, as long as Lumintop doesn’t put AR glass on it. Looks quite nice outdoors.
Daylight/XP-G3 Wuben
dekozn
Last seen: 2 days 15 hours ago
What I’m missing in the OP are driver details. Is there already a choice made except that it’ll run NarsilM?
Idiot proofing something only creates improved idiots.
ToyKeeper
ToyKeeper's picture
Last seen: 5 hours 8 min ago
The driver is a FET+N+1 design, so it should have regulated output up to around 3 amps, IIRC, and the ability to go much higher than that for turbo modes. Output will mostly be limited by ability to dissipate heat.
The driver itself is custom-designed for this light.
The Miller
Yes last details are put on paper for LT to make it and create the first prototype
The double tube for the e switch in the tail is unique and that alone requires custom design.
Then it is ready for TK and others to play with software to use the FW3A leds as receiving light flashes from a screen to allow programming of the driver without opening (only the hardware is in place and TK made a testsl setup to prove it can work, this needs a tremendous amount of work but if that work is put into it the hyis ready. (And it is logical new projects take this into account as well))
joechina
Last seen: 6 days 4 hours ago
Yes Robert high CRI would be nice for this lamp.
Do you know the colour temperature?
RobertB
RobertB's picture
joechina wrote:
Yes Robert high CRI would be nice for this lamp. Do you know the colour temperature?
Wuben doesn’t say what the color temp is. It looks to me around 5500 or so. Maybe a little more.
krazypoloc
Please add me to the list. Thank you.
The Miller
Welcome to BLF!
Will do!
djozz
djozz's picture
Last seen: 1 hour 55 min ago
Having used my D4 and other 10+ amp pocketable lights for a while I feel the need for setting a different ramp ceiling (I’m not the first to come up with this, but now I experience the need myself). The regulated 3A is a great and logical ceiling because it is regulated and because (from own measurements on a S2+) a light this size will not self-destruct at 3A (by just).
Would two ramp groups be an option for the FW3A? One to absolute max and one exactly the same but going to 3A.
(that would be simpler and more precise for the user than a user-settable variable ramp ceiling, as has been discussed as well)
ZozzV6
ZozzV6's picture
Last seen: 12 hours 20 min ago
Please remove me from the list. I will buy soon an Emisar D4 and I hav too many multi led pocket rockets.
Thank you!
JasonWW
JasonWW's picture
Last seen: 59 min 43 sec ago
No need to remove yourself. Your not obligated to buy anything.
Besides, by the time the light is ready for sale, you might have changed your mind and want one again. Lol
ZozzV6
ZozzV6's picture
Like with the Q8 Big Smile I wanted to remove myself because I wanted the UT03 more but that stopped. So now I have a Q8 and I’m happy. Big Smile
tui2004
Last seen: 10 months 4 days ago
Please sign me up for one, Thank you.
garrybunk
garrybunk's picture
Last seen: 8 hours 18 min ago
Add me to the list for one please. I need a new EDC, one that is shorter that my current Convoy S2.
Thanks!
-Garry
My Bike Lights Thread, Optics (TIR) Comparison Beamshots, Diffusion Techniques
NOTE: Moving my photos from PhotoBucket to Flickr. PM me or post in the thread if you can’t see my images and need me to fix or send a gallery link. PhotoBucket images should remain visible until November 2018.
The Miller
Yes will update the list later!
Big Smile
bunnicula
Last seen: 1 week 3 days ago
Wishing that it would use a 5000K 90CRI XP-G3.
Please add another one for me. Thanks.
JasonWW
JasonWW's picture
Does that exist? I don’t recall ever seeing it.
bunnicula
I don’t know if it’s on the market but at least it’s in Cree’s datasheet.
EDIT:
https://www.mouser.com/Search/m_ProductDetail.aspx?Cree-Inc%2fXPGDWT-U1-...
EDIT:
Checked mouser and digi-key, they “carry” the product but have no stocks on hand.
EDIT:
This model on the other hand, is in stock:
https://www.arrow.com/en/products/xpgdwt-u1-0000-00fe3/cree
https://www.mouser.com/Search/m_ProductDetail.aspx?Cree-Inc%2FXPGDWT-U1-...
ToyKeeper
ToyKeeper's picture
djozz wrote:
Having used my D4 and other 10+ amp pocketable lights for a while I feel the need for setting a different ramp ceiling (I’m not the first to come up with this, but now I experience the need myself). The regulated 3A is a great and logical ceiling because it is regulated and because (from own measurements on a S2+) a light this size will not self-destruct at 3A (by just). Would two ramp groups be an option for the FW3A? One to absolute max and one exactly the same but going to 3A. (that would be simpler and more precise for the user than a user-settable variable ramp ceiling, as has been discussed as well)
Hmm, a ramp with a factory-set limit which isn’t user-configurable? Hadn’t thought about that. What do people think?
I was originally thinking maybe three operating modes:
  • User-configurable smooth ramp
  • User-configurable stepped ramp
  • A smooth-ramp “muggle mode”
That last one would perhaps go from 10 lm to 3 Amps. Perhaps it could still be configurable, but only when muggle mode isn’t active? Even 3 Amps could still be a bit much for sustained use. In any case, it’d be kind of like momentary mode, where it’s a one-way trip and requires a special action to exit. Probably cutting power or maybe some sort of click sequence.
The regular ramp modes would have safe factory defaults, but still have access to turbo and the ability to change the ceiling and floor if desired.
If a factory-hardcoded one is desired, exactly like the regular ramp but with parameters set in stone, I think it’d be relatively easy to add. Much easier than a separate muggle mode… but it would still have access to everything else too, like blinkies. Is that a thing people want?
Bam35
I am already on list for one at #30 but please add me for another. Thanks
el_duderino
Last seen: 14 hours 11 min ago
Personally I’d be interested in something like the second option (don’t have a ton of use for a muggle mode), something like an “edc” mode that still has a moonlight, but only goes through the regulated ramp. That way, I could avoid starting any fires in my pants during daily carry, but still change to the retina searing fun mode on occasion.
aggillator
aggillator's picture
Last seen: 4 weeks 1 day ago
Hey, can you add me to the list. Thanks y’all for your hard work and commitment. We are all very grateful.
joeangi
Please put me on the list
garrybunk
garrybunk's picture
I like the idea of ramping ending at 3A, with option of a separate Turbo at direct drive. What is muggle mode?
-Garry
Wieselflinkpro
Wieselflinkpro's picture
Last seen: 2 hours 35 min ago
-Garry
Something like this you are wishing. Its a mode for someone who has no experiences with high-power flashlights.
The name comes from harry potter. A muggle is a non magican or normal person.
ToyKeeper
ToyKeeper's picture
FWIW, the default settings will probably be for a ramp ceiling of 3A,with direct-drive turbo accessible by a double click. But it should be configurable to raise or lower the ceiling if desired. And the floor too, for that matter.
I don’t know if muggle mode is a thing people want or not, or how exactly it should work. Could be a ramp with safe limits, could be a simple low/med/high, not sure which is more muggle-friendly.
Zulumoose
Zulumoose's picture
Recent experience with a muggle grabbing my A6 and trying to use it would suggest that On/Off medium is the only fool-proof muggle mode.
Muggles expect a light to turn on immediately into a useful beam which never gets hot.
Beam me up!
The Miller
Yes this makes sense, also normal people struggle with more then one mode a lot of the time
rizaoztop
Last seen: 7 months 1 week ago
please count me in
