Yeah I’ll do that.
The reason I made a metric version was because I originally had only made an imperial version, because both optiforms and phoenix have all their reflector specs in inches.
For people who plan to order reflectors from them it is really easy to take the values straight from the data sheet and put them in without having to convert to mm
I guess I could have also built in a “mm or inches” option into the calculator to choose between the two. Maybe in a future update.
I have also started to play around with the lens calculator. Have you thought about how the Wavien collar impacts otf Lumens? sma calculated here is collects 75% of the light and 25% goes through the hole. Since you assume 2.19x the luminance using the collar, the lumens coming out of the hole would be 2.19 x 25% = 54.75% of the LED lumens. After this you would multiply, as before, with the lens transmission rate to get otf lumens.
Yes, the OTF lumens also takes into account whether the wavien collar is on or not.
The only thing is that I do not set the limit for emission angle for when the wavien collar is activated, so if the green lines are going through the collar then that will give incorrect numbers.
I just read this over, and the problem with this method of calculation minimum hotspot diameter is that the point on the edge of the reflector, depending at what angle from the LED it is, will give a different “reflection” image.
For example, if your reflector has the furthest edge at ~60 degrees to the side from the LED, the LED will no longer be square (when viewed from that point)
Which means the reflector will be projecting an image like this:
And not like this:
As the angle gets bigger, this effect increases, up until your reflector point is at 90 degrees to the side of the LED and only reflects a line, making the theoretical spot size the same as the reflector diameter.
Then when you add all these ‘lines’ together you end up with a circle, which is why reflectors make a more circular spot than lenses.
So this “minimum spot diameter” would only be accurate for a lens/reflector directly in front of the LED.
Since a lens usually does not collect at large angles from the LED, this would be an OK approximation for the spot size with a lens.
For a type-1 reflector it would only be accurate for a deep reflector, and for a type-2 reflector it would only be accurate for long focal length and small diameter (large F-number).
What get-lit did on CPF is make a program that brute-force calculates this by taking many points and then adding up the projected images:
AFAIK this kind of calculation isn’t possible using a simple calculator like desmos, this would require a coded program.
I can probably do that in matlab, but it will take a lot of time which I currently do not have, and I’m not sure if there is a way to make the program available online for anyone to use.
Can you explain in more detail why it is inaccurate and how so?
A nice example are lights with incandescent bulbs. The filament of a typical halogen or xenon bulb is just a straight line. Typically you can get a standard spot that doesn’t seem as small as the width of the filament would make you think.
There must be a reasonable way of calculating this.
Because the red square in the first picture is actually smaller than the red square in the second picture.
The points at a larger angle from the LED will be reflecting the image of the LED die at an angle, not straight on.
There are an infinite amount of points on the reflector reflecting light, which is why a thin line from a filament gets reflected around 360 degrees and creates a circular spot.
Remember the post I made about this?
Now just imagine an infinite amount of those squares around in a circle.
But for large angles, such as in reflectors, instead of squares they look like this:
Which causes the “hotspot” to actually be smaller.
Just imagine multiple of these rotated around a circle.
The diameter will be less than if it was a full square.
I get your point, I just never thought about that it might make the hotspot even smaller.
So we basically need to find a way of calculating the reflector angle at the rim to the be able to calculate the size of the visible LED die from that point. This should be possible with standard triangle geometry. More importantly we need to find a formula to calculate the reduced apparent size of the DIE based on the angle.
I found an omission in reflector type 1 calculator.
When calculating throw, it includes only intensity of light bounced off reflector, but not of that coming from the LED directly.
It is surely trivial with the sizes that you care about and very small in nearly all cases, but I think it’s at least worth being aware of.
Without having looked into the calculations, here’s my thought. The light rays bounced from the reflector are all parallel, and this contributes to throw/intensity. From all the rays that are emitted that are not hitting the reflector, there is only one ray that travels parallel to all the other rays from the reflector. This means the contribution of that single ray is infinitesimal = 0. Hence this is absent in the equation.
Nope, the LED is not a point source. It is a flat surface of a specific size. This surface contributes to the total surface of the light source as seen from the hotspot. How much of the surface it contributes depends on the size ratio of the reflector to the LED, of course. What also needs to be noted here is that the luminance of the LED is higher than that of the LED reflected by the reflector. Only the losses of the lens need to be acounted for.
You guys are right, I need to add the LED die area times the lens transmission to the intensity equation.
Thanks
It will make a significant difference when dealing with reflectors not much bigger than the LED itself.
Enderman, in your Lens calculator I see that for working area you take clear aperture.
At the same time I notice that in the inside the part of the lens that passes light is CA while on the outside - it’s the entire lens area.
I’d like to understand that better. Could you give some pointers on why is CA the correct value here?
Clear aperture is on the outside (curved) surface of the lens, not the plano side.
It is not 100% of the lens diameter due to manufacturing processes.
I have contacted optics manufacturers asking if it would be possible to have a lens where 100% of the diameter is aspherical for collimation, but the closest they can do is 95%.
The size of the entrance pupil to the lens on the LED side is smaller than the diameter * CA.
So…the outer portion of the lens collimates lights the same way as the center but does so with less precision.
If the goal was to produce the sharpest projection - it would be the best to black it out.
If the goal is to produce throw - leaving it normally is a better choice.
Also: collection angle does not actually depend on clear aperture but rather on back focal length, edge thickness and refraction index.
Although now you made me think, since the LED is not a very small point source the outer portions of the lens may still contribute to total lux even if they don’t collimate perfectly.
Another thing to add to my list of stuff to test haha
