I recently ordered another one for $9.99 and i hope it’ll be good too, but after reading the recent posts here, i think i can expect some trouble…
Juts to be sure, aren’t the 14500 problems you guys mention due to the limited length of the battery compartment?
I modded the tailcap of mine to gain space for protected button top 14500s, otherwise i couldn’t get the tailcap to screw on all the way.
But the problems i just read sound like they have a different cause…
I ordered one today for $10, OK $12 somethiing with priority line to get it faster and tracking. Hope the SW is good. I will certainly put a few switches in my cart for the next electronic order.
I don’t believe that to be the case for me because I am using unprotected, flat top 14500 IMR (efest purple). So they are as short as possible, and at no point do I get the feeling there is excessive pressure.
I dont use protected cells, but that would really be the only way for me to confirm.
As near as I can tell, my problem seems to be something in the driver
I forgot I uploaded a video on the programming aspect of these lights:
The lowest output is about 2 Lumens with either chemistry. As near as I can tell the only difference is in the brightest turbo setting. Where 14500 gains the full ~750 OTF. On an eneloop the brightest turbo is around 375 OTF.
IIRC these lights have a low voltage protection… so you can’t run dead alkalines (or any battery for that matter) completely dead. Someone please correct me though.
The light does have lvp but it’s not voltage based alone as it will run fine from 2.5v-3.2v without problem as long as the battery can provide the power. If the voltage sags too much and fails to deliver the expected current the driver shuts off.
Re problems: reviewing back through the thread does not confirm wether or not the problems are switch related. The problems are all related to using the switch and in some cases changing the switch solved the problems. But there has not been enough reports to indicate what is the status after changing the switch to confirm for certain that it is the switch.
One theory I have is that the problem may be related to how the driver handles reading denouncing of the switch. Different switches have different response images even with the same switch model so if the driver is not calibrated to a wide enough variance there may be problems even if the switch isn’t technically faulty. If this is the case, changing the switch may help or it may not
Well, light #3 has arrived this morning and this one is misbehaving. Fortunately I have the two good ones to compare to, and I may have learned something.
The drivers on these lights have two solder points showing on the battery+ side. On the two good lights, the solder points are precisely horizontally perpendicular compared to the external ‘flat’ on the head housing that the switch is installed in. On the third (misbehaving) light, the solder points are slightly off the perpendicular, being rotated a few degrees clockwise.
Now this third light does work, sort of. I did manage to get it through the programming cycle, and that seems to have remained in the drivers memory - but it’s sometimes reluctant to come on, and reluctant to shut off. Sometimes it gets to ‘low’, one level above moonlight, and then stay there. It’s definitely not working perfectly.
I’m wondering if others might check the alignment of the solder points on their drivers. It could be that the drivers need to be exactly perpendicular to the switch aperture to function properly. Unfortunately I cant seem to rotate the driver - there are no pinholes to twist by, and I can’t tell if it’s glued in or not.
thats interesting…
on both of my lights the solder points are all squared up and parallel with the flat of the switch.
My driver boards are also loose fitting and not firmly attached. I can rotate them a little and when I touch them there is some rattle. So the battery tube needs to be tight and secure… FWIW. I think its always been this way, I never paid much attention though.
Yeah its lowest program mode is brighter with a 14500, although in person its not as pronounced as my pics above make it appear. I really don’t believe its 10 Lumens.
I have a Ssurefire E2L Outdoorsman, its low mode is rated 3 Lumens otf.
On a ceiling bounce comparison the E11/UT01 14500 program-low is visually about half as bright as the SF.
the E11 you see in the pics above is a neutral white, but its by far the warmest “Neutral” tint I have ever seen. Not a bad thing mind you.
