If you already have an analyzing charger like the Lii-500, this makes a good 2nd. I have both the Zanflare C4 and this. If you are stuck between them, my main points of comparison are this:
Function:
Zanflare has full capacity test function
Both have resistance function
MiBoxer can charge faster and will automatically select charge current (may be a negative if you prefer charging slower by default)
Both have dedicated power adapters included
Zanflare can use all 4 cells for the powerbank function (MiBoxer only C4)
Ergonomics:
MiBoxer is wider and deeper. It’s much easier to get cells in and out, also less likely to knock cells out accidentally
Neither have inset notches on the positive terminals that help hold cells down (Xtar does this and it’s very helpful to prevent knocking a cell out)
Appearance:
MiBoxer is “right-side-up” (Zanflare is “upside down”)
Overall construction quality and appearance is similar
Display:
MiBoxer has better display overall IMO and I like that I can view a lot of information for a single cell at once
Zanflare allows you to view info on all 4 slots at once but you have to click on the display for each slot to rotate
Thanks very much for the detailed breakdowns of the differences between the two chargers. :+1:
I see from your signature you have done reviews of both chargers too, so will check out your reviews later. At this stage, I am leaning towards the MiBoxer C4-12 mainly because of its ability to fast charge at 3A over all 4 slots. Will have to keep an eye out over the next week or so. Hopefully GB will do a good deal on it during the 11.11 shopping festival. Not sure why BG is not carrying it?
Thanks for that. Just read it. A bit concern about the sporadic reboots. And that it won’t revert back to the last saved charging current (3A), so you could end up with 3A of charging for a small time only. You didn’t mention this on the 2A charging, so sounds like 2A charging is more reliable? I haven’t read the Zanflare review yet but my guess is its max charging current is probably the same as the Liitokala 500, ie. 1A?
_Charging Li-Ion at 4×3A
Here is a graph of charging current when charging a Samsung INR18650-30Q button top using a manually selected 3A rate. All four channels were being charged at 3A while data was being logged on Channel 1. As can be seen, my unit is not capable of sustaining 4×3A charge throughout the whole cycle. It will reboot after some time and will restart using lower charging rates. Once finished, when removed from the charger, cell voltage was 4.18V._
Yes, 4x2A charging posed no issues for me. Possibly even 4x2.5A may have been OK - I have not tested that yet.
In all honesty though, I don’t see myself needing to use 4x3A much if at all. I don’t own any cells larger than 18650. A typical high drain 18650 has about 3000 mAh capacity. It’s not going to be that much quicker to charge it using 3A vs 2A or 2.5A. Now, if you own large 26650 cells with 5000+ mAh capacity, that difference in charging speed will become more noticeable.
I recently purchased this charger and haven’t had any re-booting problems when charging at 3A. It looks like they may have fixed the re-booting issue as you mentioned in your review:
“However, what I have is a first version of this charger and Miboxer told me they tweaked it since and that in the newest version, the charger will better control temperature and will not reboot.”
Also, based upon battery level and resistance , the current rate will drop even if you set it at 3A - so those are additional things that will lower the charge rate. The next time I have 4 batteries pretty well depleted I will keep an eye on the current rate to see how it behaves.
Good to hear. What was the highest temp you observed during 4x3A charging? Starting with fully depleted cells, how long were all the cells at 3A before current started ramping down?
Because of the rapidly cycling current/voltage/IR display in your video, I can’t tell when it started ramping down. I also can’t see what the other 3 channels are doing… what level of charge they’re at.
But your temps are much lower than mine. Mine reached 53C, and that’s when the reboot happens.
I looked at the pictures
to 4208 is last with 3A
start picture 4101 with 30 seconds pause
so at 4116 12,5min I switched to 3A manual
54minutes till current ramp down
charge for a 3000mAh high drain cells took 86 minutes
Is there an “advised amps” list for cells? Is it a percentage of the peak discharge or just a fixed number for a certain cell size?
I even saw a charger that does 4A.
So before I start cooking my cells I would like some advise on 18650, 20700, 21700, 26650, 32650
