Testing the “10% off site-wide” code in GearBest, but doesn’t seem to apply for me.
Maybe could clarify for which countries it works?
For AliExpress, I believe the $10 off for $60 refers to AliExpress Select coupons (usable only on the 24-hour period of 11/11/2017; not sure which time-zone is used). The “Select” coupons are more restrictive as to where they can be used — usually only applicable to the AliExpress stores that specifically stated to accept them (usually big-brand stores accept them).
Exactly!
about the Coupon from GearBest , I’m not sure about the Countries that are not supported But if there is a Discount on the Item you want to order then the Coupon won’t work!
Banggood also does not accept coupons on discounted items!
