If this are aff links you must post in : BLF User Negotiated Deals
Here the thread appear for people that have marked “Not Comercial”.
Regards
Regards
Sorry if this was posted in the Wrong Section, I’ll try to move it, Thank you for the Nice reply
These are affiliated links , but you don’t have to click on them , Simply Copy the Coupon Code and use it on checkout .
What is the coupon code on Aliexpress?
Aliexpress.com: 10$ off from 60$ orders with Aliexpress Coupon on 11.11
Aliexpress does not give Codes, they only Give Coupons and it’s only available on 11.11, for now you can use select coupons on the App.
Regards
OK
Thanks
Testing the “10% off site-wide” code in GearBest, but doesn’t seem to apply for me.
Maybe could clarify for which countries it works?
For AliExpress, I believe the $10 off for $60 refers to AliExpress Select coupons (usable only on the 24-hour period of 11/11/2017; not sure which time-zone is used). The “Select” coupons are more restrictive as to where they can be used — usually only applicable to the AliExpress stores that specifically stated to accept them (usually big-brand stores accept them).
Exactly!
about the Coupon from GearBest , I’m not sure about the Countries that are not supported But if there is a Discount on the Item you want to order then the Coupon won’t work!
Banggood also does not accept coupons on discounted items!
Regards!
Same for Uruguay
Fasttech’s THANKS15 has expired.
