Talk about future projects and donation topic
There is a light that I’ve been dreaming of for a while:
  • zoomie
  • good throw, OK (or better) flood
  • big-edc size (think B158 or a little bigger). 45-50 mm lens, 21700 battery.
  • e-switch
I spent quite a lot of time thinking through several obstacles. Today I made the fist sketch. It uncovered other ones.
First, some numbers. A focused zoomie with a lens that has f-number of 1 collects only 20% of light. All the rest hits the flashlight body.
I wanted to improve it and I evaluated several options.
#. Mirror adds rings to the beam around the emitter image.
#. TIR lens should be similar
#. Precollimator lens increases the projected emitter size without significantly affecting throw.
It also greatly narrows the flood beam. Maybe it should be defocused together with the main lens to get rid of that effect…
It’s relatively cheap. It can recycle nearly all of the lost light.
#. Waiven collar. It makes the image of the same size, but brighter. It’s less good at improving efficiency, can recycle only about a third of collected light. The rest is wasted either by not being reflected (as far as I understand it reflects only the most promising frequency) or not re-emitted (and probably ending up as heat). It also reduces beam width, though slightly less than a precollimator.
#. 2-stage collar. A part of the collar is mounted on LED PCB and a part near the lens. It should collect slightly more light than a regular one, but the main advantage is that it has smaller effect on the flood beam. Since the near-led part doesn’t have to collect a lot of light, it can have wider opening and thus:
  • block less light from the lens
  • be slightly lower, allowing deeper de-focus
    2-stage collar acts funny when zooming. It comes out of focus very quickly, making the beam lose a lot of intensity in the initial zooming stage and much less later.
2-stage collar seems like the best option as it allows a fairly wide beam and extreme throw distance in the same light. Though the legal challenges may make it infeasible. Legalities aside, it’s going to be costlier too. For the budget we can have either a good thrower or a good flooder. Or neither. But I see no way to do both (though maybe some precollimator defocusing would help).
When it comes to the emitter / driver I see 3 good options:
1.Dedomed SST-40 with buck-boost driver to keep it exactly at the current that we want. FET won’t work because 21700-30T will blow the LED.
Very high throw, good efficiency, the highest price.
2. XHP35 HI with a boost driver. Less throw, less price, easier to manufacture, better efficiency, better flood. But throw is much worse and there’s the dark cross in the middle of the focus beam.
3. XP-L HI. Oldie, but still a good option. Paired with FET+1 for a good price.
Now, my drawing:
For the purpose of drawing, I used a 50 mm lens. I guess a 45 mm would be better really. And I certainly made some parts too thin. And tolerances too tight. It’s a sketch, you know. Also, the drawing uses a 2-stage collar where the moving part is Fresnel style. Being Fresnel style is not important, I just liked to draw it like that.
Problems:
  • I failed to account for the threads for battery insertion. Easy fix.
  • There is no switch. And the only sensible way to put an e-switch that I see is to FW3A it.
  • Cooling is bad. I mean really, really bad. And I see no way to fix it.
At the end, I’s also point out one potential obstacle. Collar needs to be positioned very precisely. Will various abuses that EDC light will endure make the collar lose focus over time?
Thoughts?
For zoom to flood, you can’t really beat led lenser’s optics.
Can’t use a collar with it though, but it does collect 100% of the LED light when zoomed, which is the main problem with normal zoomies.
It is half TIR and half aspheric.
A precollimator makes the beam diverge more and create a bigger spot, it does not make it narrower.
A wavien collar does not change the beam divergence, it slightly more than doubles the lux and lumen output, increasing the efficiency from ~25% to ~50%.
(assuming the lens collects all 60 degrees of light coming out of the collar)
Two stage collar is an interesting idea, that would give you basically two different lux measurements and spot sizes.
Only problem is that it would cost at least several hundred dollars to get the small collar made, and probably ~1000 for the secondary one.
Agro:
For better heat management I think you need to make the tube much thicker where it contacts the zooming part. IMHO this is the only option to make it better. Thick tube like 5-6mm walls and bigger diameter for zoom threads. The light’s thickest point still will be the head so I think it is acceptable.
Or to make it even better The tube can have 3mm holes in almost full length and we can insert 6-7 3mm thick round heat pipes in all length and those will send the heat to the tailcap part. Also at the tailcap it can be some fins to help the heatpipes.
Yes…it’s an interesting optic. But I’m yet to see a light with good throw (per size) and this type of optic.
Even if it can’t compete with collar, it still may be a great option.
The way I understand is:
Before the main lens, precollimator narrows the beam significantly. After the main lens it becomes wider.
That’s in focus mode.
In flood mode, the narrowing means that light hits only a small part of the main lens, creating a narrower beam. I actually did some basic ray tracing of this and that’s where it made the beam narrower than blocking the light directly (with collar) would.
I guess you mean a custom collar made from glass and custom coating tuned to reflect the desired frequency, right?
A regular aluminium reflector already reflects ~90% of light. May lose some more by being less smooth. But the price in volume shouldn’t be a problem.
Being tuned to the light will help recoup some of the loss. If it captures more light than the stock collar would, it’s likely to be a win.
Thanks for the suggestion. I’ll look into it.
BTW, Enderman, do you have an idea how much would a top-notch collar cost in volume?
isn’t it just a reflector with a very large hole and a specific wider curve?
I don’t see why such thing would be very much more expensive then a reflector
OK, did some tweaks:
  • added a switch
  • added threads for battery insertion
  • enlarged zooming threads a bit
  • switched lens to 40 mm EFL one. This is a big change. It freed a lot of space all over the light.
    Not done: I should redo the collars as now one blocks the other. This would lead to redoing the head. Outside dimensions wouldn’t change much, so I skipped this step for now.
A note about collars vs. other techniques:
Collar is the only optics that actually improves beam intensity over a simple lens. Otherwise, to get the same effect you would have to increase lens diameter. The zoomie above has a 50 mm lens and does 400+ kcd with SST-40. If it was collarless we’d have to scale it up to 70 mm to achieve the same effect. Body length would increase by nearly 20 mm as well.
I haven’t found any 14500 or smaller flashlight that can do 250m throw for 4h on max like my P5r.2 can do.
If you put a more powerful LED in it you can probably get 500+m throw out of that tiny thing :slight_smile:
It’s not really a beam until it exits the light, the precollimator just reduces the output angle from the LED.
The spot created by the flashlight will always be larger when using a precollimator.
It collects more lumens, and makes the spot larger, essentially leaving the same intensity.
There are other things such as glass transmission and surface quality that will affect the performance though, so you can probably expect less lux when using a precollimator.
Adding a precollimator essentially reduces the focal length of the dual-lens system (this can be mathematically calculated), and as you probably already know a shorter focal length will mean more lumens collected and a bigger spot.
It’s called a cold mirror, and they typically reflect 99% of light in the visible range.
Some people were discussing in PMs about getting some aluminum ones machined.
A typical aluminum reflector like you see in flashlights is 75% reflective, not 90%.
If you want to get 90% you will need an electroformed reflector, which is also expensive, especially since nobody produces them at the size that would work for a collar (yes i’ve checked).
A custom job will cost several thousand dollars because they need to produce a mandrel for it.
No idea, it would depend on what manufacturer you go to, and how many you want produced.
A single one will cost about $1k.
Thanks, I need to get some basic optical design knowledge…
Where did you get this number?
> where …
Lots of instances: typical aluminum reflector like you see in flashlights is 75% reflective - Google Search
click/tools/verbatim to limit the search results
I checked all the first links.
I did not find any statements regarding this except an older post from Enderman where he claims the same thing because he thinks that normal flashlight reflectors are polished. From what I can tell the majority are coated (after first being polished). Every standard flashlight reflector in good lights has a coating of vapor diposited aluminium. Even the plastic maglite reflectors have this in some form (maybe not aluminium, not sure). It’s nothing special and not very expensive.
I have never seen anyone do actual measurements with a high degree of certainty and low possible error which prove that standard flashlight reflectors only reflect 75%, never.
It also has nothing to do with electroforming. Electroforming is the process of creating the actual shape of the reflector. This shape (made of nickel) can then be coated using different methods. It’s mainly needed for higher accuracy!
Sere here for an interview of the ceo of 4Sevens where he explains how they produce their reflectors: How LED Flashlights Are Designed And Manufactured
4sevens offers a 30$ regulated EDC light with bluetooth functionality and such a reflector. It can’t really be that expsenive to use such coating if they can do it at this price point!
Here post from Ra (optics engineer) also agrees with this. He says that aluminium reflectors reflect 88% of the light (the total efficiency he talks about is referring to how much light actually goes into the hotspot compared to a TIR lens, which he prefers).
Or here:
First 2 results I see include the 75% figure. But Google does not show identical search results to everyone for the same query.
More turns up with a focused search:
(I try not to get caught up in arguing over there, some of those threads get a bit snarky)
http://candlepowerforums.com/vb/showthread.php?106790-bLu-vs-tLu-IS-confirms-65-conversion-factor
The reason it seems like less than 25% loss when you measure the flashlight lumens is because not all of the light is actually hitting the reflector, about 1/4 to 1/2 of the light exits the flashlight as spill, unaffected by reflector losses.
Maybe newer technology has changed this since then, like with the new nitecore reflectors and stuff like that.
It’s not going to be anywhere close to 90% though, you need electroforming for that.
Maybe like 80-85% at best.
The only real testing being posted so far.
But even their test is not perfect. They didn’t actually test the bulb without the reflector. Bulbs have manufacturing tolerances like everything else. Also, they are using a potted bulb. The base that it is pottet into obviously absorbs some of the light that the bulb reflects towards it’s legs.
So in general it doesn’t make much sense to compare the values the way they did. The should have tested the potted bulb without the reflector first.
Their 65% factor is probably accurate, but only for flashlights with bulbs and uncoated lenses! The lumens of lightbulbs are reduced more compared to LEDs.
Concerning Nitecore:
I would be rather suprised if they actually did something special. To me it sounds like they invented nice marketing terms for the same processes that 4sevens uses (aluminium pvd coating and afterwards a clear coat to prevent oxidation).
EDIT: I found another test. He tested a regulated, modded LED maglite with different reflectors, lenses, with and without bezel. He also tested for a baseline value. His numbers seem a bit off though. Borofloat glass should be around 94%, he measured 98.
The problem here is that one really needs to use a rather accurate luxmeter-sphere (if one doesn’t have access to a real calibrated IS) to get meaningful results. Otherwise you just never know if you measured something useful.
Point is, the reflectance of the reflector is not anywhere near 90%, it’s closer to 80 I would guess.
Electroforming doesn’t only make a more accurate shape, but a lower surface roughness also increases the reflectivity.
Absorption and scatter depend on how accurate the surface is, to fractions of a wavelength of light.
No matter what the actual values are, I think this topic deserves a more in depth Look.
Agree.
