Does that exist? I don’t recall ever seeing it.
I don’t know if it’s on the market but at least it’s in Cree’s datasheet.
EDIT:
EDIT:
Checked mouser and digi-key, they “carry” the product but have no stocks on hand.
EDIT:
This model on the other hand, is in stock:
https://www.arrow.com/en/products/xpgdwt-u1-0000-00fe3/cree
https://www.mouser.com/Search/m_ProductDetail.aspx?Cree-Inc%2FXPGDWT-U1-0000-00FE3%2F&qs=e4fOZ%252b9ijA8gHQ4deMVyLA%3D%3D
Hmm, a ramp with a factory-set limit which isn’t user-configurable? Hadn’t thought about that. What do people think?
I was originally thinking maybe three operating modes:
  • User-configurable smooth ramp
  • User-configurable stepped ramp
  • A smooth-ramp “muggle mode”
That last one would perhaps go from 10 lm to 3 Amps. Perhaps it could still be configurable, but only when muggle mode isn’t active? Even 3 Amps could still be a bit much for sustained use. In any case, it’d be kind of like momentary mode, where it’s a one-way trip and requires a special action to exit. Probably cutting power or maybe some sort of click sequence.
The regular ramp modes would have safe factory defaults, but still have access to turbo and the ability to change the ceiling and floor if desired.
If a factory-hardcoded one is desired, exactly like the regular ramp but with parameters set in stone, I think it’d be relatively easy to add. Much easier than a separate muggle mode… but it would still have access to everything else too, like blinkies. Is that a thing people want?
I am already on list for one at #30 but please add me for another. Thanks
Personally I’d be interested in something like the second option (don’t have a ton of use for a muggle mode), something like an “edc” mode that still has a moonlight, but only goes through the regulated ramp. That way, I could avoid starting any fires in my pants during daily carry, but still change to the retina searing fun mode on occasion.
Hey, can you add me to the list. Thanks y’all for your hard work and commitment. We are all very grateful.
Please put me on the list
I like the idea of ramping ending at 3A, with option of a separate Turbo at direct drive. What is muggle mode?
-Garry
Something like this you are wishing. Its a mode for someone who has no experiences with high-power flashlights.
The name comes from harry potter. A muggle is a non magican or normal person.
FWIW, the default settings will probably be for a ramp ceiling of 3A,with direct-drive turbo accessible by a double click. But it should be configurable to raise or lower the ceiling if desired. And the floor too, for that matter.
I don’t know if muggle mode is a thing people want or not, or how exactly it should work. Could be a ramp with safe limits, could be a simple low/med/high, not sure which is more muggle-friendly.
Recent experience with a muggle grabbing my A6 and trying to use it would suggest that On/Off medium is the only fool-proof muggle mode.
Muggles expect a light to turn on immediately into a useful beam which never gets hot.
Yes this makes sense, also normal people struggle with more then one mode a lot of the time
please count me in
Thanks for the responses. I don’t need a muggle mode then, but I’m ok if it’s there hidden or in programming.
-Garry
On/off 1-mode medium is easy. Really easy. Is that what people want in a muggle mode?
I gave it a try and it only took about 5 minutes to add.
Yeah like that, when prototype is in we an see what brightness can be sustained without heat issues, and I cn se it even become a very much used mode in the end
Super idea.
Please add me to the list.
Agreed!
Add me to the list for 1 please.
