What did you mod today?
Had a quad board with xp-g2 S4 3D left over from my other D4 so I moved them over to one of my stock S41S that came with 219b. I also bypassed both the springs. Much brighter and great tint. It doesn’t have the high cri anymore but I’d rather get more output.
Modded a Shadow JM-26 but have an issue with the switch it seems, I stripped a stock driver for the contact board and glued a switch onto it. Used an FET driver that I had in my bench stuff that was marked TK Ramping, it was already Zener modified so I just ran with it. After a lot of tedious work getting the switch on the stripped driver and piggybacking in the FET, it works ok except the switch seems to be glitchy. I can click and hold for moon and it might bump right back off upon release. Scroll up to high and it might stay, or it might jump to low or it might jump to off. The level control is not reliable, so I’ll probably be going back in to replace the switch (which will be a bear but oh well)
I have an MT-G2 in this one, with the reflector opening cut into a square to clear the substrate of the big emitter. The emitter itself is sliced and diced, bare minimum of dome left above the phosphor and all phosphor trimmed off the substrate around the array. It’s a warm white variant, makes a decent beam, just have to get the operation reliable.
Using a pair of 26350’s in the stock single cell tube. :wink:
Edit: Fixed! :smiley: I had a solder spike from the switch wire to MCU touching the bottom of the emitter shelf. It works great now, 3381 lumens from the pair of half cells. (26350’s)
I tried to open my Olight X7R to swap the emitter with the sweet 80 CRI 4000K XHP70 that I bought from kiriba-ru… and failed
I’’ve already opened quite easily both of my X7, the bezel is simply screwed on, and you only need to press it against some rubber sheet and twist to open it… but that didn’t worked with the X7R :frowning:
I put the rubber flat on the floor, pressed the bezel against it, put nearly all my weight on the tail with my left hand and turned anti-clockwise with the right hand… no success.
I’m stuck there, with a monster flooder and nice emitters to put in :cry:
possible the X7R is glued
heat helps, but on such a big light it is not easy to heat up all of the bezel to 120°C
I tried running it on Turbo mode for some time but it never reached enough heat to soften an eventual glue… no success
I don’t want to ruin the U-ring that keep the glass in place by heating it too much :frowning:
With such a big diameter, if it’s really glued I will need some big torque to break it !
You can try to put it in the freezer for some time first. Doesn’t soften the glue but the shrinking and extending could help.
:smiley:
Let’s not waste chicken sacrifice, let’s thank him for this fine pencil beam shots :sunglasses:
I modded two new P60 drop-in's today. 4xSST-40's FET drivers. Just luck that these old sinkpads happen to work perfectly, the quad lenses I had on hand fit just right over top of them. I did one with a "perfect" de-dome and one with the slice technique. The bottom pic is the drop-in installed in a 502b with the attack bezel filed down and sanded smooth. On the "perfect" de-dome I wanted it cooler so I actually took the corner of a razor blade and scratched off a tiny bit of the yellow coating on the emitters, it's now very cool white. I wouldn't do this with a single emitter light, but with these multi-emitters it works nice because it all blends together. Just a little bit though or you end up with a very nice royal blue emitter. Just scratch one little spot and lightly at that. Yep, it gets hot fast on turbo but on high it's still very bright and can be run for a good long time. the copper ring is from a 3/4 inch copper pipe cut into about a 3/4 inch piece with a pipe cutter. I then squished the end a little bit in my vice and it actually threads onto the pill perfectly. I used a small round file to file the holes in the pipe and disc before putting the pieces together with good thermal epoxy.
Interesting. I just swapped out the sliced SST-40 in my D1 for an XP-L2 V6 1C. I’m seeing 2387.4 lumens from the little D1 now.
Those SST40’s can really pull some amperage, I tested one in my thrower that made 8.82A at the tail from a 26650, 2397 lumens. They gobble up a cell really well! lol
Edit: Checked the amperage on this single XP-L2 on a 20700A and it’s pulling 9.51A!!!
Are you slicing SST-40 when it’s warm/hot or you shave cold dome?
8.82 amps, Wow.
Yeah, that will eat up the batteries all right. But for 2400 lumens it’s kinda worth it. I have no idea how many lumens these P60’s are putting out. Pretty bright though. Brighter than a lot of the SRK’s I’ve seen.
“Are you slicing SST-40 when it’s warm/hot or you shave cold dome?”
These I did with them cold, and then (after the pic) took some sand paper to them and took them down further and finished them off with some super fine grit to really smooth them out. I actually like the soaking method better but I thought I’d give this a try just to see what difference it would make. And honestly, to the naked eye, it’s pretty hard to tell the difference, except the “perfect” ones are cooler now after taking a little phosphorus off of them. If I had to keep one and only one I’d keep the one done with the “perfect” de-dome.
The SST-40 is problematic on de-doming, so I’m told. Tend to take the bond wires with them when the dome comes off the phosphor. I cold sliced mine in a jig I made, honed a scalpel to a mirror finish to reduce marking in the silicone and then applied silicone o-ring grease so it’d slide through easier without binding. The slice is so clear it’s difficult to tell there’s silicone left.
When I tested the SST-40 in my thrower it was with a 6000mAh 32650, my D1 is using a 3100mAh 20700. Single cell in either case.
I have no problem de-doming them now but it was a process figuring it out. I put them in a jar with the Toluene and soak it in almost boiling water. It takes about a half hour or so, any longer and it will kill some of them.
It’s good to know how to do the slice tech too because sometimes it’s a better application. Like on this one, I was worried I’d hit the bond wire with the lens. (I can’t tell you how many times I’ve done that.) Thanks for the tip on the silicone grease I’ll give that a try next time I do them.
Here’s a shot of the sliced SST-40, far left, and a couple of XM-L2’s, the middle one is hot de-domed and the far right is chemical de-domed.
Nice!!
Anyone know how to get inside this, to access the LED / Reflector, etc? It has a XP-G3 in it, and smooth refector. Large end doesn’t appear to be threaded on.
looks like press fit
So, cold slicing for SST-40, thanks guys, I will give it a try, I am not satisfied with my hot liquid dedome results.
DBC, I think you are using too much flux! There is too much gunk on and around the emitter for my taste.
When reflowing I am only using solder paste, after that I clean the led with 96% alcohol, that I do hot chemical dedome process,
when it’s done one more time alcohol bath, then distilled water bath, compressed air to blow off tiny droplets. Thats my workflow.
I don’t use flux at all. Kester solder paste. All of those emitters have been in and out of different lights, especially the middle one, it’s several years old and has seen a lot of abuse. I didn’t see any point in cleaning up anything before they get installed in the next project where they’ll get dirtied up again. For the record, the XM-L2 on the far right was not my doing. It accidentally got left in some serious chemicals for a couple of months prior to being sent to me. :wink:
