Something like this you are wishing. Its a mode for someone who has no experiences with high-power flashlights.
The name comes from harry potter. A muggle is a non magican or normal person.
FWIW, the default settings will probably be for a ramp ceiling of 3A,with direct-drive turbo accessible by a double click. But it should be configurable to raise or lower the ceiling if desired. And the floor too, for that matter.
I don’t know if muggle mode is a thing people want or not, or how exactly it should work. Could be a ramp with safe limits, could be a simple low/med/high, not sure which is more muggle-friendly.
Yeah like that, when prototype is in we an see what brightness can be sustained without heat issues, and I cn se it even become a very much used mode in the end
Muggle on off med sounds perfect! I learned the hard way…more than once. Many people just expect light with a turn on. Zero bells and whistles. They will destroy!
Muggle thing seems confusing. I thought it was some super advanced setting, now that I have seen some explanation, it seems to be just a protect someone who does not know how to use a flashlight mode. I don’t see a need for that myself, but maybe there is enough interest.
That’s the way I see it too Tixx. Muggle mode is for folks who shouldn’t have the light or for those who can’t understand the words “hot coffee”.
My $.02 worth. Has there been a problem with the Emisar D4? If so, then muggle mode is needed, if not then I don’t see the problem.
Heck, the Q8 with multiple cells was sold to folks with just an inkling as to the potential danger of Li-Ion cells (IMO) and this light is not that level of danger. But if it needs to be added go for it. We can ignore it as long as it’s out of the way and doesn’t restrict useful features. But if it’s added and reduces useful features it’s not worth it. It’s a light for light nerds (of which I consider myself one) and it’s not a hardware store light intended for the masses.
