I did a board with a MOSFET to eliminate the extra resistance from the external switch
size 16-17mm, for 16mm the battery holder fins need to be cut a bit
Ordered 9 boards from Oshpark
Will take some time to get here to Germany and assemble them
Annoyed with the low output with remote pressure switches for flashlight?
I use a MOSFET with a low gate voltage which gets full output down to 1.8V
The MOSFET is powered by a CR1225 Lithium battery with 36mAh should run easily hundreds of hours on
^ wow, nice job Lexel, if it works as planned I guess you will have quite some customers for it. And the switch will be as good as silent too I presume.
I’m still stuck with the bezel of my X7R… it has been freezed in the freezer, then heated with the hairdryer but nothing seems to free it
I was frustrated so instead I put the 3*XHP70 in my X7 :
Thanks DB and Geuzz.
Just a heads up there is a silver plating under the Black (PVD?) I literayy had to hand file it off the entire light where the Copper is exposed. Sanded with 220 on up to get it to polish as seen. Was a lot of work but looks neat.
Cut a small piece of copper sheet into a disk and put that on the end of the spring facing the battery. Having a bit of copper there helps protect the solder from friction. The spring bypass tends to last longer.
The Bezel and E-sw ring were the Blue. I tried the warm sodium hydroxide solution and no joy. They are Brass. To my suprise, it wasn’t till polishing it that the blue came off. The Lye may have actually helped a bit. The original emitter MCPCB is copper but super thin. To get the thicker Sinkpad in there I filed the bottom of the optic shorter and reamed out the bottom hole with a 60* reamer to fit over the XM and sit on the pad. Bad thing is that changed focus and the Smini now has a Square Spot. Like a zoomie but big. Mostly only seen on turbo.
This thing will be coming apart again. Change some things and mostly larger guage wires.
Thanks djozz.
Yes the black is the original coating, pretty hard stuff. The flats polished again after getting sanding scuffs.
Waiting for Patina….
Here’s my first LED project in a long time. It’s a 50W automotive light bar I purchased from Amazon that I’m modding into a UV inspection lamp.
Luckily when I opened the light up it used what I think are Cree emitters with the 3535 footprint. This made it easy since I was able to remove all of the LED’s and the 5 buck converters and reuse the MCPCB with the Lite-On 365nm emitters. Some jumper wires had to be soldered down to run the LED’s in series, but it wasn’t a big deal.
Here I was testing out the LED’s. My power supply maxes out at ~31V, so only 8 of them could be tested at a time.
The datasheet shows a Vf of 4.0 @ 500mA, but here it shows it to be closer to 3.45V.
9 of the LED’s have a consistent color, with one of them being noticeably “whiter”. This whiter LED still appears to fluoresce objects as much as the others, so I won’t bother to swap it out.
I mounted an aluminum project box to the top of the lamp for the dimming pot. It looks a bit ugly, but it’s good enough for this project.
The heatsink is more than adequate. At roughly 17W for an hour the temperature only reaches 33° C.
The only thing holding it back now is the window. The one that came with the light bar was made of polycarbonate and blocked nearly all of the UV. I have a piece of Starphire glass at a shop right now being cut to the appropriate size. I should have it back this week and the lamp will be complete.
Just thought if you go for sapphire glass why not a ZWB2 filter glass installed?
The SST 10 UV may be also promising with XPL footprint and low thermal resistance
just the important thing would be to see what kind of Wastelight the SST has, like the Lite-On or no like the Nichia
Thanks! This one will be fixed to a printing press. Often clear coatings must be applied to the labels which is difficult for the press operators to see and register to the images. A small amount of optical brightener is added to the coatings formulation (usually less than 0.5%) allowing it to glow when viewed under UV. This lamp will be an upgrade over the fluorescent blacklight lamps that we’ve used in past. Those tube lamps don’t produce enough UV to make some colors of optical brighteners to fluoresce.
The bandpass filter would be a nice addition. I looked at filters briefly a few weeks ago, but wasn’t able to find one with the correct dimensions or one that wasn’t outrageously expensive. Maybe there’s a ZWB2 film that can be applied to the glass window? I haven’t looked into that yet.
If this lamp does works well, I’ll have to assemble several more. Next time I can mix it up with the SST-10 LED’s and do a comparison. I’ve been wanting to play with the Luminus UV emitters since they starting releasing these less expensive variants.
