Introducing Ceilingbounce - flashlight testing and runtime graphs for Android
https://www.dial.de/en/blog/article/luxmeter-app-versus-measuring-deviceare-smartphones-suitable-for-measuring-illuminance/
Seems the situation is pretty bleak. Even if you calibrate you can have factors of 3 errors across the dynamic range. And if you think establishing detailed calibration curves for various devices will help, nope.. they found no consistency across identical devices. I'd strongly suspect there are wild variations depending on the color distribution of the source too. Seems like these smartphone meters are kind of toys.
Oh didn't notice the OP is the writer. Ok great, maybe you can dispute that then?
I can’t dispute it. I have two smartphones and no real calibrated light sources. I have a couple lights that maukka also has, and maukka has a real integrating sphere.
I do note in the readme that “lux” readings from the phone’s light sensor are absolutely not lux. It is necessary to calibrate using lights with known lumen and candela values. No attempt is made to calibrate the raw sensor “lux” value to real lux, but I may add the ability. As the article notes, there’s no difference from one app to another in terms of the reported lux value; we all just report what the sensor says.
I wish the testers you linked had tried multiple samples of the same Android device like they did for iPhones. As the article notes, iPhone apps are using the camera rather than the light sensor because some jerk at Apple decided apps can’t use the light sensor. There’s bound to be some variation in that approach.
Somewhat problematic is that the test shows a non-linear ratio of lux to sensor values in all the devices tested. With most devices, it’s not huge, but the Samsung S5 at 500 lux is an exception. Everyone needs to test their own device with different lights on different modes for which there’s reasonably reliable data in order to have a reasonable calibration. If it jumps around as much as the S5, it may be impossible to calibrate accurately.
would it help you if the app users were able to submit different light source values to you some how?
I would think something along the lines of phone type. light value and light source, the light source would need to be entered manually?
i’m sure there would be a number of people on this board willing to test all there lights to create a sort of reference database
I’m planning to make a database website and integrate it with the app. Just haven’t gotten to it.
For this to be even remotely comparable, wouldn’t it require that everyone uses the same measuring environment/integrating device?
If my shoebox is different from your shoebox… :slight_smile:
I wouldn’t say it is all that unaccurate.I originally made a shoebox and used my sony z3 to measure with.I have since gotten a luxmeter and built and calibrated a pvc pipe measuring device and the reading i get from the phone app is always very close to what readings i get.
Having consistency across poor light boxes doesn't help. The point of the shoebox is to make sure that one beam profile of 100 lumens reads the same as another beam profile of 100 lumens. If that's not the case everyone having the same shoebox will still not get comparable readings across different types of lights. Consistency fixes overall calibration, not profile dependence, but that can be fixed just by dividing by some determined value, possibly by using a standard light as a rough calibration. Could be a GE 36watt halogen even, something everyone can buy for a couple of bucks at a hardware store.
Hi Zak, this is a very useful APK, thanks a lot for the app again.
Only one thing. I think it would be useful and cost very little to add a quantity to know how many lumens over time the flashlight/battery has produced.
For example:
Average lumens x seconds÷10.000
This can give info about efficiency.
Thank you very much for creating and sharing this app. I find it super useful to quickly analyze how a specific light steps down from the highest setting and great for evaluating relative output over runtime.
:slight_smile:
Good ,work.Thanks!
Thanks for this App.
It turned out it’s not easy to find the apk for first time github visitors.
Please add this in your README, under FAQ as second bullet point:
• You find the *.apk in the releases section of github:
And you have “CPF and BLF” in your text. My pal didn’t know what that means.
I would change this in “the flashlight forums Candle Power Forum (CPF) and Budget Light Forum (BLF)”.
JOE
I saw this thread when it was first started, but never thought I’d use the app, so just now downloaded it. I have to agree, you need a direct link to the /releases folder in your Readme file.
Also, just saw this in the OP:
If you’re serious about that, I may have to take you up on it in the future. :wink:
I’ll seriously code for money. As for payment in literal food or lights, I might consider it if the value was high enough.
Bump for this thread... I'm using it for my runtime graphs!
Just wanted to say thanks again for this app. Just ran my first little runtime graph to see the turbo step down on my TR20 with Note 10 - worked great!
Thanks too for the app. I’ve never used it but plan to try it out. I can try it out on a S7 or Note 5, any one tried either or suggest which may be best?
Anyone know how to install the app? It’s not an APK file, but a bunch of smaller files which I can’t download to my phone. I tried downloading all the files on my pc and transferred them to the phone, but that didn’t really get me anywhere. Is there something I’m missing? I’d like to use this app if possible. Thanks
Sirstinky, the apk is here to download: https://github.com/zakwilson/ceilingbounce/releases
Under each pre-release section there is an Assets section containing the source code zip and tar.gz files and the apk file. Tap/click here to download too (0.2.2-alpha version).
Awesome! Thanks for pointing me in the right direction. I was able install the app. Seems like a cool deal.
