Yes, the 20M1 package, but I use the tiny25v, and they seem to be rev E and F (85°C and 125°C versions) at mouser
if this driver works well with 5-6A this would be definitely worth building
BTW, that is the parts cost?
The parts cost for this buck or boost driver is likely 10€
Makes more work to place the parts on it
The tiny pins of the parts require to get a stencil for the solder paste
This would bump the price quite high
There is high and there is high. If we want near-Zebra efficiency, double output and on top of it better firmware I don’t think it’s going to be a bad deal.
I was using the 841 before but got tired of always having to optimize my code to fit into 8kb. I’ve also found the 1634’s power down modes better, for OTSM and E-switch only drivers. However, the 841 had en advantage that I miss, the PWM channels could be configured and assigned to any IO pin. The 1634 has the PWM pins fixed.
Ultimately I chose the 1634 because it’s currently the only 20 pin 4x4mm package with 16kb programming space that is easily available to me. I find 20 pins in 4x4mm to be as small as I want to go for hand mounted hot air soldering. I don’t want to go down to 3x3mm or 24 pin 4x4mm, the pins are tight enough as they are and I’ve had a few issues with shorts so I’m not all that interested in the 1616 or 1617.
I didn’t find porting the software painful, it was just something that had to be done. I’ve been using it for a few projects and am happy with it: Project Gemini: Yet another headlamp mod. Not a cheapo this time though. and Mike C drivers: v8 series, ATtiny1634 based.
The parts cost more than 10€. I sometimes bought more parts than I needed (for example 4 MP3431, or 4 of each tiny25v version with the right package, to hopefully get rev E parts), and it cost me around 58€ (for 3 to 4 drivers). If you just buy the necessary parts for the driver, and more sets, it will be cheaper. Idk, maybe 15€ less (so 43€ for 3 drivers, without boards).
And 3 boards cost 5$, I will make it a little bit smaller for less sanding.
If you only use those, the MCU has to come off the board if you later want to update the firmware. I still think it’s better with vias on the board for acupuncture style flashing, providing that you can fit the vias. As a driver and firmware developer I make sure to fit them myself:
hmm sometimes these quotes won’t die after a link.
PWM's aren't even fixed on the attiny25. See my bistro-HD code, especially the timer interrupts. Ok, of course hardware PWM is fixed, but you can do whatever you want with interrupts. Only issue is I may recall those chips can do hardware PWM in some nice sleep modes, and that wouldn't work so well with software PWM. Mostly though I don't mind clocks being tied to pins. There's a point where there's too many options. That many pins in that small a space doesn't sound too easy. 8kb not enough for a flashlight? Wow. You must have run with that plan to accept data through light from the led and setup a TCPOFL network. If you want to do a lot of dynamic stuff like better regulations of various types I suppose I can see it though. Narsil is about maxed out now.
The vias are nice of course but on this boost driver, I'm not sure there's a way. Really though flashing a bunch is mostly for development, on my EDC I'd prefer not to keep flashing it (but then I don't have much else for development). I'd take a boost driver like without easy flashing if that's what's required. Seems like a nice driver.
If you have the programm socket you can flash the driver before soldering
Saves time
For reflash later instead viases small solder spots take less space
There are also 2x3mm small SMD. Onnectors, but then the wiring gets more complex
Those drivers are 4 layer so more expensive right?
I hit the 8kb limit because I have multiple UI types and everything configurable by button presses. That could all fit, but I had very little room left for a bunch of experimental stuff and found myself having to take code out for it. As the 841 uses the same footprint and is (for me) the same price, there really was no reason not to switch. But yeah, in normal end user firmware 8kb is enough by margins.
I managed to fit vias on my GXB17 rip off design. I have the boards but haven’t built one yet:
I’m quite sure I can squeeze the vias in on a new board modified with the boost circuit discussed here as it appears to use less components. Updating firmware is of coarse not needed for everyone, but as I’m always coding something I like to be able to.
Mine are 4 layers but that’s not a problem because in terms of community interest, my boards and firmware don’t really have any. A saving of $0.82 per 17mm board is for me really not worth the hassle of trying to squeeze everything into 2 layers. Of coarse the additional copper thickness option isn’t available for 4 layer boards, but I don’t see that as a show stopper.
Your boards look pretty cool and your firmware likely better. But isn't your work all closed source? (which is cool,but not what this project is I guess) and I suspect this will stay open, and in that spirit 2-layer as you point out, and at least for this proto it's getting bistro-HD which fits on this attiny25 and is open, and is an incremental continuation of the previous community project. Of course people just buying a driver would likely buy yours. I would have a year ago. A lot of the "community interest" (not that bistro-HD has so much either) does it to build up the open source toolbox though, because that's fun, maybe even more than to make our own lights work.
Do you think it's possible to get the vias on a 2-layer board? What about with the attiny25 (it's also only 4 mm)?
You are correct Flintrock, my involvement in this has been primarily to expand the open source driver options. If someone wants to rip it off and make or even sell their own closed source version, please do! More options, more better in my book.
Yeah, and well it's not even all about open source but about the community path. I've seen some probably really great open source code too that still gets ignored. I'll gladly admit that I "took advantage" I suppose you could say of bistro popularity with HD, or you could say I supported the popular thing. People don't generally like too much change and too many choices and like to stick near something they know for awhile. The main thing HD did was just fix one big issue with previous bistro boards. You can keep using bistro over some fancy new thing, but it's hard to keep using old bistro when there's a new bistro that's basically the same but fixes one clear problem in your light. Even that though has probably been used by less than 50 people, maybe less than 20. Of course there really aren't that many people building and flashing their own boards.
Jesen, I haven't seen your work, will have to check out. Sorry if I stepped on anything here. Schoki asked about getting HD for this in PM, and it's basically already done, just not released (it's just a config anyway). Anyway, as you say, more options=better.
As for "ripping off" I kind of agree. Bistro was already gpl3 though from TK. I figure I own completely copyright to large parts of the stuff I've added and so could open those bits up to BDS or MIT or such but I'd consider if somebody asks. Of course in a world of Chinese flashlights, you have to figure it could happen without asking too, so whatever.
And MIke C I wouldn't say your work doesn't have community interest. Certainly your early testing and discussion of the OTSM concept inspired me to figure out how to get it working on existing less-efficient hardware (another big focus of HD, wide existing hardware support) and there's been a bunch of talk about your use of these newer chips and even skewer flashing (which I like because it's back-side accessible and probably easier to secure than clips). There's some discussion of possibly some HD commercial boards on attiny25 in the short term, but moving toward these newer chips long term, so you've been inspiring things. Not sure if any of it will materialize exactly in that way.
For a lower power buck/boost I found LTC3119. Has 5A switch current, 2.5V to 18V input, 0.8V to 18V output, will run down to 0.25V after startup.
Sense resistors are a hurdle with regards to efficiency and power handling. MOSFET VDS feedback is a far more reasonable way of sensing. It seems that there already are some commercially available noRSENSE controllers. Look, for example, at this little beauty: LTC3785 - 10V, High Efficiency, Synchronous, No RSENSE Buck-Boost Controller
Cheers :-)
P.S.: that sh1t owns!
I did share some 85 firmware for boards some time ago and shared a couple of boards for it because there was interest, but the problem is that my firmware is locked to my boards. I spent quite a bit of time writing instructions so that people could use it, and in the end it turned out that no one was interested enough to actually read any of it. I totally understand that, most firmware here is compatible with boards from multiple designers, but after that I just don’t bother because it takes too much time to do write ups that hardly anyone will read.
Sure, once the boost circuit discussed here is tested, I can attempt to make a two layer version in Eagle with the vias. If I succeed I can share it with some basic firmware, but as I only work with the 1634 and assign pins to my liking, I kind of have a feeling that a Bistro compatible 25 version will be much more of interest to the community.
In terms of new chips, I think there are a few that are waiting on the 1616 and/or 1617. I didn’t want to wait. They aren’t easily available to me, no AVRDUDE support and higher pin density than the 4x4mm 20 pin package. The 1634 is available, package size is as small as I want to go, 16KB programming space, AVRDUDE support, 17 usable I/Os and has 0.1 uA parasitic drain in power down sleep mode. That’s all I’m interested in really. I don’t use the Full Duplex USARTs, QTouch, I2C interfaces and all that other stuff. If anyone wants some help migrating to it, I’m here, but for my own boards and firmware I’ll just carry on as usual.
