Indeed. But in the Q8 the contact between the tube and the driver is also rather ephemeral. After a little adjustment mine is contacting OK all the way around the edge of the driver, but that’s not saying much, barely half a mm, and the driver PCB surface is showing signs of wear already after a week, despite polishing the end of the tube.
I think I am going to have to come up with a mod. to fix this, if I want it still to work this time next year.
Meanwhile I am not cranking the tube down hard, nor loosening it for lockout, the less wear and tear the better I think.
For this particular light, the Q8, The Miller is handling any problems. He will try and get you fixed up if you have any issues.
When it comes to Chinese lights in general, the warranty is not really there. It’s usually too expensive to ship a light back to China to get a replacement. Typically the warranty stuff will be directed at the store you bought it from. For instance, Banggood, Gearbest, Aliexpress, etc… Each company handles things their own way. If it’s a tiny problem they may offer you a $5 store credit. If you persist it may increase. Sometimes they may offer a replacement driver if that is what broke. A cracked lens from shipping might get you a replacement lens sent to you. It all depends.
You basically have to go into a Chinese flashlight purchase with the idea that there is no warranty and hope it is all working properly when it arrives. If you do have a problem and the store fixes it for you, consider yourself lucky. Lol
This is why it helps to know how to solder and how to take lights apart, etc… I think most folks here know how to fix a broken light themselves. So they don’t care about warranties.
1/2 a mm for the full circumference is actually a lot of contact - plenty to support 24 amps, and more, as it does now. The noticeable wear is not something to be concerned about in the near future, since the ground ring is extra thick. I prefer using the electronic lockout. The mechanical lockout is only as good as the anodizing on the threads, which will wear with time and use, and it's not perfect on many Q8's from the factory to begin with.
So you can choose between wear&tear on the switch, or wear&tear on the threads and ground ring. If you do couple/several lockouts per day, then maybe, just maybe it might be an issue within 2-3 years. I personally tested the mechanical lockout on a Q8 about 275 times or so and saw no "significant" wear on the ground ring. Posted bout it earlier somewhere in this thread: https://budgetlightforum.com/t/-/39069/5597,
I was quite concerned at first, particularly as mine started off with very partial contact around one driver screw, hence me taking it apart, sanding, polishing and lubricating.
Now I do have 360 degree contact, but it continues to “bed-in” evidenced by the indexing of my tube continuing to shift.
I hope this settles down soon.
I remember that the copper layer was specified to be heavy on the driver ground ring, for wear resistance, but I also recall that that is maybe not what we have ?
It certainly works well, as you say, the tail springs and screws etc. are clearly the bottleneck.
Just came across a Q8 batch 2, just came in, that had a solder blob on the driver ground ring, but on the inside (component side). Really caused a significant tilt of the driver. Used an Xacto to cut/scrape it off. Though they improved the screws and threaded holes (no more glue/contaminants or burrs on the edge of holes), it's still worth giving the light a good close inspection.
I just measured and ran some calculations, battery tube to driver ring contact is approximately 208 mm^2. Assuming contact around the full perimeter. There will be bedding that happens, and making sure that the driver board is flat should certainly be done, but I agree with Tom, it should last a good long time unless you are mechanically locking out or swapping batteries multiple times per day.
Finally got it!
Getting more “messed up” in my opinion/personal experience with Postnord lately here in Sweden for the final delivery on gods from China.
Anyhow,
Very high finish, extremely happy with functionality and super a value for my money so just very pleased with it.
I would have ordered another right now, but currently out of stock but thanks Tom E for the heads up.
And once again,
BIG Kudoz to all involved with the project, and glad to read there where a few bucks over to some of you.
V1.1 had some life to it, can't recall details, but think it was a temporary release for the GT buck driver. So to avoid any confusion I bumped the rev number.
It's been common practice for me that if a release "leaves the building", then if in doubt, bump it out (up??). Out rhymes though
