[PART 1] Official BLF GT Group Buy thread. Group buy officially closed! Lights shipping.
Okay, then that seems fine to me. :+1:
Matt (Vesture of Blood, VOB) recently flashed NarsilM v1.2 on his prototype. Maybe you 2 can compare notes?
Ah, you probably already knew that.
All good news and thanks for the update Texas_Ace
Surely the reflector is being turned, not milled, no? Even with a ball end mill, milling would require a huge number of steps to get anywhere close to a smooth surface. If it’s turned, the surface finish will depend more on spindle speed and tool feed rate.
A CNC lathe will still approximate the curve with a series of steps in the radial and axial directions, but the machine resolution should be more than enough so that the steps aren’t visible.
Yeah, we have been talking. I have the hex file lined up, just got to wait till I get home and have time to mess with it to flash it and try it out.
Correct, it is indeed turned.
Slowing the feed rate more then they have now would start increasing the price with very little to any tangible benefit. So we have struck a good balance at this point of performance and cost. Besides the specs I am very happy with the results.
Even the specs would not technically hurt performance as they are so relatively small but cosmetically they don’t look good.
Specks = Like specks of dirt.
Specs = Short for specifications.
Texas Ace thanks for all of that work writing that up. It was awesome and informative.
Thanks for the review TA. Looking good. :+1:
[quote=Texas_Ace]
In fact, the difference is not perceptible. Then I wonder if the throw of this torch will be distinguishable from that of the TN42vn with throw of 1940m.
Well, the difference between 1.25 and 1.3 miles is also not perceptible.
Actually, the difference between 1.2 and 1.25 is also not perceptible, let’s save some money and make it just do 1.2!
Oh wait, the difference between 1.15 miles and 1.2 miles is not perceptible.
And neither is the difference between 1.1 and 1.15.
Hmm, what if we saved some money to make it do 1.05 miles since the difference is not perceptible from 1.1?
Or even 1 mile, which is not any visually different from 1.05!
Wow!
[quote=Giancarlo]
The difference would be noticeable in that giggles has ~2300 lumens, a much larger hotspot and better tint. How noticeable? That I don’t know.
I do know that my wallet will notice the extra $200 in my pocket!
[quote=Giancarlo]
What exactly is the TN42vn that can do 1940 meters, or in kcd: 943 kcd? Is it still using a XHP35 HI or a dedomed XP-G2 or something else? I sure would rather have 1300 kcd over 943 kcd any day.
1300 kcd = 2280 meters (1.4 miles)
943 kcd = 1940 meters (1.2 miles)
In this case, a 38% bump up in kcd produces a 17.5% bump in distance.
Ohh, ok. The TN42vn that can do 940 kcd is a dedomed XP-G2: (i.e.: pencil beam), hotel room window vs. the entire hotel at a distance, as a rough difference.
There's no comparison in my book.
Probably this has already been mentioned, but I would add a crenulated steel bezel for several reasons:
1 - the flashlight would be nicer! :slight_smile:
2 - When working I often put the torch upside down on the ground and a steel bezel would avoid risk of scratches.
3 - If the torch drops on the ground by the edge of the head it gets not dinged. The steel bezel distributes the impact on the whole circumference of the head.
4 - A crenulated bezel can used to break a window glass if needed.
[quote=Tom E]
I mean the Acebeam TN42vn modded by Vihn (SkyLumen.com): https://skylumen.com/collections/v54-lights/products/tn42vn-throw-king-pre-order-only
Of course you are right, but I am not sure that a throw of 2280m is very distinguishable from a throw of 1940m as the difference is just 15%. Look at this comparative test between the Acebeam X65vn (1,575m) and the Thrunite TN42vn (1940m):
Giants of the throw in the sky of Rome!
The big difference in numbers is not so visible in the real world. Also, The X65 keeps a larger spill that makes you to understand what you are lighting. Look at the top of the dome: the X65 allows you to see the tower bell behind the Dome and the trees around. With the tight spot of the TN42 you need to explore here and there to understand the environment. I would like if the the BLF flashlight would have a beam pattern like that of the Acebeam X65.
The GT is so large and heavy that even a titanium bezel won’t stop it from breaking in a fall.
So just don’t drop it.
You also don’t want to be using this to break windows, the circumference of the head is so large that all you will do is just damage the flashlight and scratch the glass because of force distribution.
Also, the design is finalized, a steel bezel would add cost and manufacturing complexity.
Thanks for the detailed update about the new prototype, TA! :+1:
Are the emitter wires long enough to allow access to the driver without desoldering them from the emitter board?
I plan to reflash my GT, but I’m a bit nervous about opening the head and exposing that huge gorgeous reflector to the outside world! :heart_eyes:
From the photos I’ve seen, the reflector looks beautiful. It’s not hard to imagine rapidly diminishing returns from slowing the feed rate.
I’m of course looking forward to the light this thing will put out, but the reflector alone will be a part worth admiring.
Any chance you can get some beam shots of the new prototype? Like nice throwy beam shots at distance. The new improvements look amazing love the side led and how well they did on the battery carrier’s. Looks like a nice light. I’d notice the difference in 1.3 miles and 1.1 miles because I actually light up object’s in the distance. Might be using binoculars with this light this is crazy.
I think you mean the ThruNite TN42vn - again, it's a thin beam - no comparison to the swath of coverage by the GT.
