I looked at good P-FETs and I found one Vishay, the thing is it costs more than the battery with holder for the N channel, also the battery increase the overall thickness of the board so it is more compatible to regular switch boards with the switch taking a few mm extra space
I have ordered 3 remote switches
9 boards
10batteries
not ordered the Mouser parts yet
if there is demand here to buy this board please respond if you want it with switch or just the board assembly
1. luminarium iaculator
one board?
or all parts to mod your tail cap?
size 17 or 16mm?
Well I canāt remember where I posted it years ago but I made my own FET remote switch with some air wiring and random parts I had laying around. Currently on my 12-gauge pump switching an XHP50 in a C8 fed from a couple 18350s. Iāve been meaning to teach myself Eagle so I could design a neater solution, but I havenāt. So Iāll be in for a few if these turn out well. Iām actually really interested in a PFET version if it saves space as the 2S 18350s are a bit of a squeeze. Plus Iām considering boring a C8 tube to take a 21700 and need the length there too. Additionally, Iād feel more comfortable not relying on the coin cell connections in a high recoil application. Though my hack job homemade setup has done surprisingly wellā¦
Sure put me in a list for one with cableā¦ If I will like it I will order more.
I thought that 20mm boards are more standard ones? 90% of Uniquefire flashlights, Brinyte, Mitkos Supwildfires etcā¦.
Let the reference of Omten or Kan 28 switch guides youā¦ Flashlight who has them installed must have at least 20 mm switch board because their size is 18mm(cube) and 19-19,5 at contacts below.
But of course I am still in cause it is no problem for me to piggy back it to 20mm board
Yesā¦ Contacts must be solid and I think it wont be problems.
How to simulate recoil? Take flashlight in one hand while holding pressure switch turned on with other hand and then take your best and hardest twitch with a hand like youār gonna throw it to floor. Do several of āsimulating throwsā in a row and if flashlight will not loose a contact you have good setup.
I have probably misled myself, and you, about the PFET implementation, It isnāt really any different from the N version, i.e. still needs gate drive, which isnāt available at the tail, once the FET is turned on.
Sorry about that. I was mis-remembering a design for a gun torch, where the ādriverā, actually just a FET, was in the head, and the remote switch hardwired into it at the head, not the tail. A PFET was used to switch the positive, it was a modified incandescent torch being used, not LED, and this seemed the easier way at the time.
I found the old CPF article where a similar method was used to replace a mechanical clickie tail switch, which were not so robust at high current in those days.
The replaceable coin cell seems the best way, but if wanting something permanently soldered in, even potted, perhaps e.g. a Panasonic VL series, recharged through a bleed resistor and some simple method to maintain the correct 3.4V.
Another application for this switch is to allow the use of longer cells in some clicks lights or as a tool in many homebrew builds. Iāll be waiting for the final parts list as Iāve too been waiting for something like this:) itās been talked about a number of times but nothing ever really came of it. Looks like youāre making it happen. Yay!
Iām running a boss head with 2x IMR 16340ās so probably well over 2,000 lumens. Using a stock SF tape switch and have had no issues. I would certainly be interested in looking at this for a different build Iām working on.
Iām still fairly new to BLF, hope a cut-down image of a rifle forend is allowed
Wonder how much resistance it would lower if u make a battery free (the coin battery) remote FET switch.
Like the remote switch is connected to the flashlight AND the FET.
Doesnāt current like to flow where there is least resistance?
Like when you press the switch the current flows thru the remote switch to the flashlight but at the same time activate the FET in the tailcap so the current flows thru there to the flashlight and this are lowering the resistance?
The FET IS the switch for the flashlight, in this case. The āremoteā switch activating the FET is so that the total current of the flashlight doesnāt have to travel through the tiny wires of the āremoteā switch. Itās like having a relay for the ignition switch in your automobile so that the full starting current for the car doesnāt have to flow through the tiny wires of the ignition switch.
you have to use a coin battery to activate the MOSFET,
you may choose a rechargeable one or super capacitor with a bleeder on driver, but a 25 cent battery will last for over 100 main battery cycles at high level output and 10 years
If you want a coin cell free tail FET variant you need an additional wire from the driver to the tail
the external remote switch has only the coin cell current flowing through it
It is possible to mod the tail cap and board to have a conventional switch and the external switch
Yeah. I donāt really know how I was thinking, but since Iām not a electrician the idea was great in my head.
My idea was to use the cells in the flashlight to power the FET since the remote switch is powering the flashlight also and it could steal some of the current to activate the FET.
And if the FET gets broken the flashlight would still shine but with the extra resistance from the remote switch.
Like the FET is connected in parallel before the remote switch.
Thinking about its still feels like a good idea but since Iām not an electrician I calculate my idea to be 99% wrong since I donāt know how those FETs work.
also another member said, you could use a P-channel FET without battery
the problem is you can switch the light on, but then you have not a positive potential to switch it off again
the resistance of the FET is 4-5mOhms at 2.4-3V, so probably less than a conventional switch, I see no problem add a normal switch in the tail and connect it to the 2 pads for remote switch and use the light that way
you will need 3 mm additional length in the tail cap assembly to make it fit
I received the FETS and battery holders today, but still waiting on the boards
Once you're bothering to do this, what about just placing an mcu there and doing PWM from the tail FET and be done with it all? One less fet, even less resistance. Less space for 7135s though but really fet+1 is fine.
Of course if someone wanted to just design a light from scratch just for this, placing a small hole down the length of the battery tube and passing a wire through it for an e-switch connection from the tail with a standard driver in the head would work but that's getting a bit tangential to the already very nice improvement.
