18350 Battery Compartment For Convoy S2+ Blue/Red-led Flashlight
It’s now in flash sale foor only $2.19. Offer expires in 4 days and 18 hours.
Update: Price drop:scissors: to $29.69 (same coupon code).
Fitorch P20R XP-L2 1180Lumens Rechargeable Tactical Mini LED Flashlight
Old private coupon codes expired. New one: 11P20R lowers the price to $34.09 (-$20.90)
AMUTORCH JM70 XPL HI 1200Lumens Brightness 1027m Long Range Searching LED Flashlight
It’s now in flash sale for only $38.99 !!!
Convoy C8 Xp-l Hi 7135*8 Integrated Head Long Range LED Flashlight
It’s now in flash sale for $15.99 ~ $18.99 (depends on selected tint).
Available tints: U4-7A, U6-3A, U6-4C, V2-1A
Offer ends in 3 days 17 hours.
HaikeLite MT03 II Devourer XHP70 2SPS 8760LM CW/NW High Power LED Flashlight
Use coupon code 11MT03 to lower the price from $109 to $65.40
HaikeLite HT35 XHP35 HD CW/NW 2300LM 3Modes Zoomable LED Flashlight 1000M
using coupon code 11HT35 price drops from $65 to $39.00
Code took price down to $79.57
petemer - so the MT03 II deal is only as good as GearBest at $79? Is it supposed to be $65.40? I'll order one or two at $65... Let us know.
Astrolux S42 4xNichia 219C/XP-G2/XP-G3 A6 2023LM Rechargeable Mini LED Flashlight
It’s now in fash sale for only $24.95
Offer expires in 2 days.
For use with high current 18650 cells to achieve full light potential additional 18650 body tube is available here: Astrolux S41/Astrolux S1/BLF A6 LED Flashlight 18650 Body Tube for $3.29 or with BG points for:
VIP0/1 |
VIP2 |
VIP3 |
VIP4 |
VIP5 |
$2.80 |
$2.76 |
$2.73 |
$2.70 |
$2.63 |
the details I got fom BG said that the code should take price down to $65.40 and it’s valid for 11.11 promo festival.
I asked them to check the price and I will let you know here when I get the answer.
Pete.
Astrolux MH10 XPL HI 18650 1000LM USB Rechargeable Outdooors LED Flashlight
It’s now in flash sale for only $21.69 !!!
Flashlight can be directly charged via micro USB port. Holster, standard micro USB cable and spare orings are included in the package.
Short tube available here: 1pc Astrolux MH10 Flashlight 18350/16340 Battery Tube for $2.59.
Astrolux S41 4x Nichia 219B/XP-G3 A6 1600Lumens Mini LED Flashlight is right now for only $23.00.
Offer ends in 3 days and 4 hours
Additional 18650 body tube to achieve light full potential with high current 18650 cells is available here(now in black, blue and red):
VIP0/1 |
VIP2 |
VIP3 |
VIP4 |
VIP5 |
$2.80 |
$2.76 |
$2.73 |
$2.70 |
$2.63 |
New Fitorch coupon codes with even better discounts!
Only valid for 11.11 promo festival.
Model | Coupon code | Original Price | Price with coupon | Discount | Link |
Fitorch MR35 | 11MR35 | $76.25 | $39.65 | 48.00% | Fitorch MR35 XP-L2 1200Lumens 5 light colors Rechargeable Portable UV LED Flashlight |
Fitorch P20R | 11P20R | $54.99 | $29.69 | 46.00% | Fitorch P20R XP-L2 1180Lumens Rechargeable Tactical Mini LED Flashlight |
Fitorch P26R | 11P26R | $103.29 | $49.58 | 52.00% | Fitorch P26R XHP70 3600Lumens FCD Rechargeable Portable LED Flashlight |
Fitorch ER16 | 11ER16 | $50.99 | $27.59 | 46.00% | Fitorch ER16 XP-L2 1000Lumens Magnetic Tail Rechargeable Mini LED Flashlight |
Special 20% off discount for all flashlights using coupon code 4fdb18
Valid: November 11-13
Coupon will not work if the flashlight is already in other promotion or flash sale(promo tag is visible in cart).
Ok, it's still only getting the $79 price.
Astrolux S42S Stainless Steel 4xNichia 219C/XP-G3 2023LM Rechargeable Mini LED Flashlight
It’s now in flash sale for only $29.99
Offer expires on Novenber 12.
To get maximum light output and runtime from this light you should use high drain 18650 battery with additional tube available here:
Astrolux S41S/S42S Flashlight 18650 Extension Tube Body Tube for $9.00 or with using BG points for:
VIP0/1 |
VIP2 |
VIP3 |
VIP4 |
VIP5 |
$7.65 |
$7.56 |
$7.47 |
$7.38 |
$7.20 |
BLF A6 XPL 1600Lumens 7/4modes EDC LED Flashlight 18650
It’s now in promotion for $18.99.
Offer expires on November 12.
All tints available: cool (1A), neutral (3D) and warm (5A).
LUMINTOP Worm 4.0 XP-G2 110LM Mini LED Keychain Flashlight
It’s now in promotion for $10.99
4PCS Samsung INR18650-30Q 3000mAh Unprotected Button Top 18650 Battery
It’s in promotion for $17.99
Astrolux C8 XP-L HI 1300Lumens 7/4modes A6 Driver Tactical EDC LED Flashlight 18650
It’s now in preorder for $19.99.
This is tried design based on prevalent C8 host with XP-L HI LED (1A and 3B tints available) and BLF A6 FET + 1xAMC driver.
This means this light will offer best throw from any C8 host as in turbo mode it’s essentially direct driven - so use high drain battery like Samsung 30Q above for maximum light output (stated 1300lm, spring bypass may be needed).
And of course same great UI as BLF A6 :+1:
