[PART 1] Official BLF GT Group Buy thread. Group buy officially closed! Lights shipping.
The drain is actually right in line with what I would expect. The LM3409 uses a fair amount of parasitic power. The prior drivers tested out at around 140-150ua according to these posts, I got similar results in my tests IIRC.
So that is only around 75ua for the LED’s and they have to drop a lot of voltage to get there, so everything lines up with what I would expect.
I would not complain about them being a bit brighter but it takes 4x as much current then normal (due to 4x the voltage) to make them brighter, so not sure it would be worth it.
LOL, I know the feeling. It is 60% humidity right now but it feels so dang dry. Most of the summer was spent with 80-90% humidity and 95f+ temps INSIDE the house and we didn’t have AC for any of it (well excluding a small window unit in the bedrooms so we could actually sleep at night). This was a fun summer lol.
Yeah, I will try to get some shots later, I should at least be able to get a whitewall shot.
Some beamshots in the tent to show the tint.
Wow, 4000K has always been my favorite tint going back to XM-L2's, maybe XM-L's, not sure. But that one seems to have no hint of yellow at all.
I've had various tints in mods, intentionally, and every time I'd compare, the "5X" would be my favorite. 5B1's or 5D1/2/3's are real nice. Dropping into the warm ranges wasn't my thing.
The 5D2 IOS sold way back was highly regarded: https://budgetlightforum.com/t/-/22306
Thanks TA for all the updates…… Looking forward to the Beamshots humidity or not!
I agree, I really like the 5A/5D tints myself. If I have to guess this one would be between a 5A and 4D. It has a hint of yellow if you turn the brightness down.
At full power the hotspot is so concentrated that it just looks like a small sun.
I can’t wait to see it at night, the warmer tints really work better in throwers. Thats why old incandescents throw so well even with so little output.
Is there where you ask to be put on the list? If so sign me up please.
Rayleigh law of light scattering.
I would like to be put on the list to buy one of these please.
This is financially irresponsible…please add me.
Wow Hovsky first post since 2013 , and you said it right !!!
Totally irresponsible but so irresistible !
Is that the first emitter you checked, on the pictures above and making 2600 lumens on 2,5A.
If so ,I am impressed with tint and performance, reminding me to XM-L2 4D Fasttech used to have couple years ago
Yes, the other one is in Giggles V2 now. It is very impressive, the highest output XHP35 HI I have tested so far IIRC.
I actually swapped my 1405 from a 3C E2 to the NW D4 and it looks WAY better now. I love it.
Can’t wait for night.
I thought the first prototype was good and ready for production, but this V2 seems to be virtually perfect. I doubt it can get even better at 111 $.
BTW, have you tried an XHP 70.2 in the BLF GT?
Not an xhp70.2 yet, still waiting get my hands on one.
There may or may not be an old xhp70 in close proximity to the V2 prototype though. Although I have a feeling it will have a donut hole, so the xhp70.2 would be needed for best performance.
Thanks for the cw and nw detailed explanation. I was going to get a TN-42 but once I saw your light was better I got in on it. I did a lot of research because Thrunite gave you an option. CW or NW, I was wondering why you guys chose NW. It’s good you explained to everyone why you think its better. Looking forward to trying it out. Never had a NW light before.
Once you go NW you never go back.
You then move forward into high CRI NW.
I am rather picky, neutral white is no longer good enough, I need high CRI and will gladly give up lumens to reach it in many cases. It just look so much better and you can actually see what you are looking at.
I figure I will repost my story of what turned me onto NW again in condensed form.
I had both a thorfire S70 with the CW stock emitter and a convoy L6 with the NW 3A emitter. I modded both of them with a TA driver and they were both making around 6k lumens. The thorfire was about 10% higher in both lumens and throw when tested on the meter.
I took them out with the family and was testing them on a bridge over a creek. First I turned on the S70 and it was an impressive beam, lit up everything bright and we thought it was really impressive.
That is until I turned on the L6, instantly everyone unanimously liked it more by a wide margin. The beam was more pleasing to look at, the colors were far more life like and what really shocked me was that it actually seemed both brighter and it easily threw further. I expected exactly the oppisote result so it shocked me.
With the S70 we could just make out the far bank of the creek.
With the L6 we could easily see the rocks, bushes and even the frogs jumping into the water.
I was so shocked that as soon as I got home I checked the batteries in both of them and re-tested both lights. Sure enough same results as before, the batteries were about the same voltage and the S70 still was about 10% higher on the meter then the L6.
After that I ditched CW altogether and looked at lumens completely differently. Ever since I have been focusing on high CRI NW LES’s even if I don’t get as many lumens and never looked back.
People that see my lights always comment on how good everything looks and wounder what kind of light it is since they are used to seeing CW LED flashlights.
The moral to the store is that paper numbers don’t tell the whole story but then that is the case for many things.
I would like to be added for 1 unit. Am I too late?
It is never too late for an overkill thrower flashlight.
