[POLL] Does your recent UT01 have ON / OFF problems?
84 posts / 0 new
Jerommel
Jerommel's picture
Last seen: 4 months 1 week ago
NO, it's fine.
52% (33 votes)
YES, it doesn't switch on after switching off.
48% (31 votes)
Total votes: 64
2Q19
Edited by: Jerommel on 11/10/2017 - 11:41
Jerommel
Jerommel's picture
A poll about the recent batch of Utorch UT01 many of us have bought.
Many of them won’t switch ON after switching OFF, unless you loosen and tighten the tail cap first (breaking the circuit).
It doesn’t seem to be a switch problem, but an electronic problem.
2Q19
Pete7874
Pete7874's picture
Last seen: 8 hours 19 min ago
Just FYI, it seems that for some people the issue only manifests itself when using Li-Ion/14500 cells but not when using NiMH/AA cells, so please check operation on both cell types.
Tumbleweed48
Last seen: 21 hours 6 min ago
So far I’ve had one malfunctioning out of three, and the bad one is constantly getting better. It now works almost as flawlessly as the first two. I think mine has (had) crud in the switch – maybe a tiny shard of plastic or manufacturing residue that’s wearing away.
FWIW, and maybe a clue here, the drivers in mine are tight. I’ve picked at them with needle nose tweezers and a stout dental pick and I can’t get them to budge.
Streamer
Streamer's picture
Last seen: 2 hours 24 min ago
I have an earlier one…no problems at all… with any battery..
jf_smm
Last seen: 18 hours 13 min ago
I have 2 one does one doesn’t
ggf31416
Last seen: 2 hours 5 min ago
Mine, from previous group-buy, had a few occasional problems (for example it didn’t work for a bit after attempting to measure current with a DMM and once stopped working with 14500 and worked only with eneloops for about 15 minutes the fixed itself and sometimes needs a few tries while running), but mostly works. It’s an useful light but not one I would carry when I need reliability.
Sukoi
Last seen: 8 months 3 weeks ago
Yeah, I got a lemon…
DENGOH
DENGOH's picture
Last seen: 2 days 18 hours ago
Only happened to mine first day i got it. After, don’t encounter this issue anymore.
I bought it one month ago.
cool i'll see you when you get there
nydude
Last seen: 3 hours 52 min ago
I’ve got one on the way to me and one I ordered as a gift being delivered to the person. Guess we’ll see. :(.
Uname
Uname's picture
Well shoot, I ordered a few for stocking stuffers. I hope they aren’t lemons :/
kramer5150
kramer5150's picture
Last seen: 6 months 1 week ago
I bought my UT-01 Dec 5, 1216… is that recent enough for me to vote in the poll?
It has the condition described in the OP.
LightRider
LightRider's picture
The switchs contacts ware in when used for a while. This changes the denouncing needed for the firmware to recognize a button press. This supports my theory posted in the review thread:
LightRider wrote:
Just a note: the problems with this light are not because of loose driver, bad contacts, or a bad switch. The switch however, is what manifests the problem. The problem is how firmware decodes the signal from the switch. When the light is off, something in the firmware tightens up the parameters that determine whether the button was pressed or not. Reason for this is unknown but I’ve wondered if it more “picky” with the handling of the signal from the switch to limit accidental turn ons. The firmware may not be broken through as it verywell may have worked with the switch used in testing(which may have not been actual physical switch at all). I say this because the light works fine with some switches and does not turn on at all with others. All my testing was done with the driver outside of the light so all other theories of mechanical problem from the host can be dismissed. Of course there is the normal one or two lights out there where this could be the problem.
I’ve read about all reported issues and all of them can be explained by my theory. Someone claimed my theory is in correct because their light started working when they straightened a twisted driver. However aligning the switch and pressing the button from a better direct angle changes the signal profile of the button press. It gives a better clean click so the driver reads the presses correctly.
Another claimed the problem is with the type of battery or because of different charge levels. These observations are probably correct but it doesn’t disprove my claims. Different voltages will also mess with the way the firmware views the signal from the switch. Either the voltage from the switch or the internal reference voltages of the MCU can be affected by different input voltages. This was confirmed by using a power supply to test the driver. Different voltages did affect the chance of the light turning on. Though, there wasn’t a general rule that deterermined what voltages did what. Each switch was different.
So, changing the switch may help defective drivers but not because the origional switch was “bad” it was instead not compatible with the firmware.
Good firmware design should take these factors into consideration. In fact, the designers of this light would have had to concider these things to some extent or the light wouldn’t work at all. The designers, however, must not have been thorough enough to acount for hardware variations.
This is my theory atleast. I admit, I am not fully qualified to make these statements. So maybe someone with a scope and a better understanding of firmware and switch press debouncing will test this theory further.
pc_light
pc_light's picture
Last seen: 1 day 23 hours ago
Mine did act up using NiMH cell (only.)
After the UT01 sits in the draw unsed for a couple of days, it would not turn on no matter how much I tightened or loosened the battery cap or wiggled the switch. But once I changed to 14500 cell it would work immediately. Then when I went back to the same/previous NiMH it would work normally again.
So now to avoid the issue entirely I simple leave 14500 in the light and never worry anymore.
Seeking the light.
DENGOH
DENGOH's picture
I suspect it is battery length compatibility problem. Tighten up too much might cause switch contact problem.
I don’t think it is wear and tear of switch, since my light is new. And this poll is about recent UT01, not old one.
Swampus
LightRider wrote:
…The problem is how firmware decodes the signal from the switch. When the light is off, something in the firmware tightens up the parameters that determine whether the button was pressed or not. Reason for this is unknown but I’ve wondered if it more “picky” with the handling of the signal from the switch to limit accidental turn ons….
Interesting. I wonder if the reason could be to limit the probability that static electricity will be interpreted as a signal input? I have a couple of older flashlights that are susceptible to this in the winter. Get them near a flannel shirt and they suddenly want to throw a disco flashlight rave party.
T-boon
mine is a bad one too, so what could we do about it?
Tumbleweed48
My fourth (and final) one arrived a couple of days ago, and it works fine. So far I’m “3 good & 1 not quite so good”.
The one that’s a bit quirky seems to be working pretty well, although this morning I swapped out a lithium primary and put in a freshly charged Eneloop. Nothing. Deader than John Cleese’ parrot.. Tightened/loosened a few times, nothing.
Swapped out the Eneloop and put in an Imedion NimH – worked perfectly. All modes. Lotsa light. Both are the exact same length, and both were recently off the charger. Go figure.
Swapped in a fresh (Costco/Kirkland) alkaline, and got L/M/H/H. Doesn’t surprise me, though, as I doubt the alky could surrender enough juice to feed the highest setting.
I have no 14500s to test them with; it’s just not a battery format that ever appealed to me.
I’ve figured out enough about its quirks that I’m still using it with pleasure. Kind of like me, it sort of works, and it works reliably for the duration of whatever cell is in it. When you change cells is when it acts up. I guess the three ‘perfect’ ones will go as gifts and the balky one will stay in my pocket.
To the guys that have bad ones, try this – when you put in a cell, wait 5 or 10 seconds, then try a slow press. Once mine starts working, it’s away to the races, and that trick has worked for me almost every time. Don’t ask me why! YMMV, of course.
O.K., this is a couple of hours later, and I have an addenda. I’ve been running the light on an Imedion NimH, steady on ‘low’, just to see how long it would run. Suddenly it just stopped cold.
No response to inputs, no ‘sag’ or dimming or flutter – just out.
Tested the Imedion at 1.21 v.
Put in a partially used lithium primary (Energizer Ultimate) and again it works perfectly.
I’m a patient man who likes a challenge as much as anybody, but……I’m stumped.
Jerommel
Jerommel's picture
I don’t know…
I guess buyers should open a ticket on Gearbest.
2Q19
T-boon
i just did that,
i dont know how they will react…
but what i do know is, i dont trust there reviwes, they never post my “bad” reviwes, only the goods.
btw, dose any one got the negative side of the eneloop damge from the spring?
like the battery tube is too short, and the spring is pressing too hard on the baterry.
Pete7874
Pete7874's picture
I am not seeing any damage on my NiMH cells, including one Eneloop.
What does your tail cap look like? Mine seems to have two springs, the inner one is kind of crooked… not sure if that’s normal…
Jerommel
Jerommel's picture
Yes, the batt. tube is very short.
Only AA and unprotected flat top 14500 fits actually…
2Q19
kramer5150
No fit problems with my 2000mah eneloops or efest IMRs
westcoast
Mine hasn’t arrived yet ( ordered Oct 25 ) but have been following the threads about this so will chime in when it does arrive! Unfortunately my 14500’s are protected so probably will only be able test Eneloops and Alkalines.
DENGOH
DENGOH's picture
Protected will be very tight. Don’t force it.
pieman7
pieman7's picture
My UT01 switch has issues, but not exactly as what you described. Mine probably just needs a cleaning as I need to hit the button just right. Doesn’t matter if using AA or 14500.
Speadge
Speadge's picture
Last seen: 1 day 2 hours ago
I got my first UT01 today and I experienced exactly the same thing as you described.
At first I put in black eneloop NiMH cell. No matter what I did, it didn’t turn on. Then I tryed 14500 pkcell and voila, it works! Then I swapped this cell again with previously non working NiMH cell and now … it works!
Strange.
eas
eas's picture
Last seen: 1 month 1 week ago
As noted elsewhere, my first UT01 only works well with AA NiMH, with an unprotected 14500 it needs to be power cycled after being turned on once. I just got a second, in the hope it would work with a 14500. It arrived a couple of days ago, and so far, so good!
Still, I’m gun-shy about ordering another, even though I’d like a CW.
Tumbleweed48
Just throwing this out here as a wild guess……do you suppose these things have some sort of capacitor on the driver that has to ‘pre-charge’ a bit when a battery is first installed after a period of being empty?
One of mine wouldn’t work right out of the box, but after sitting with a battery in it for a half hour or so, began to work and has worked properly ever since. Another works 100% reliably with a lithium primary, but doesn’t with a NimH unless it sits for a while – then it also comes to life until the voltage gets down to about 1.2 volts, where it just plain quits with no warning whatever. (I don’t have any 14500s).
Another thing I’ve noticed; I have other 1xAA lights with EOSLAMP drivers in them, as well as a couple of stock 4Sevens Minis. When a Lithium primary is playing out, I’ll see ‘high’ and ‘medium’ at the same level for a while, then eventually ‘low’ on all three settings, then a few minutes of fluttering and ‘wavering’ until it finally gives up the ghost on a totally empty cell. The UT01 just quits. When it’s done, it’s done, and it’s lights out with no period of sag.
Weird little lights, but when they work right, they’re a real gem! I figure if I can get three out of four that work, I’m still getting a bargain. The emitter alone is worth most of the ten bucks.
SubSailorVet
SubSailorVet's picture
Last seen: 2 weeks 3 days ago
I have a recent Haikelite SC01 that has an on issue.It will just flash after clicking 3 times, taking off tailap and replacing let’s me turn it on after clicking 3 times. Currently looking for fixes related to this light. Another two Haikelite HT35 lights have switch or electronic issues. They will come on only if there is an exact amount of pressure from the tail cap to the battery. Gently pulling back on the cap as I tighten allows the light to come in. I’ve got another Haikelite MT01 that works okay but it is somewhere in the house that I cannot find it. Lol!! Ridiculous issues with Haikelite!
Best regards,
Matthew
Lexel
Lexel's picture
Last seen: 1 hour 59 min ago
replacing the switch with a good one from Mouser fixed the issue
definitely the original switch produces a bounce or other thing the firmware does not detect as a click
Too bad I threw away the faulty switch without measuring its continuity or resistance
