Well that first one is a complicated example. That's >9A at 12V even. not quite sure I'd say it "exists" either. Nobody made it yet as far as I know. But just the basic stock Q8 driver does 20A at 4.2V.
Not sure what's with the guy grumping about driver design being uneccessary on a forum where people design drivers.
NightHike before you get a 6G toaster driver, maybe you can try to fit code to regulate output of low voltage emitters that works on people's existing attiny25 boards so they can use the latest LED's without frying them. Is that too easy for you or too Oracle?
@Jensen, so yeah, the MP3431 is the boost IC. You don't run firmware on it. It has an MCU controller, the qfn attiny25 in this case, and yeah, bistro-HD runs on that, with a trial configuration for that board ready.
It doesn’t need a diode if you get the right LDO. I have the TPS706, which has a lower reverse current than some diodes (10nA out of IN pin, 100nA flowing into OUT pin). Here’s the datasheet: Datasheet TPS706
And for the current per via, there are some websites, just google it. I used roughly 1A per 10mil via on the plus side.
Yeah, you have to check diode current when hot, not the quick-spec sheet, as it can be wildly different (exponential with temperature). The plots look like about 2uA. That should be good.
The OTSM-LDO-fetonly hex should work for your driver, although with no real moon mode solution yet (I'd prefer the hardware two-PWM channel solution to some PWM hack, but we'll see). I guess I should compile an OTSM-debug hex for you too, but we can see how it goes.
Yes, 20mm and 22mm are sizes I use a lot. 17mm doesn’t interest me much anymore as aside from my P60 drop ins almost everything has now been bored out to accept 20mm.
I could use a bigger one with attiny85-sized SOIC8 or flashing pads/vias for development purposes… doesn’t have to be used in an actual light, but convenient reflashing would help a lot with adding support for the hardware.
Oh, um, probably also large pads for an e-switch. Small pads break off easily when the driver is air-wired and gets moved around a lot. Again, for development purposes only.
So you mean some kind of development board? So doesn’t even need to be round? I would make one with bigger pads, vias (or pads as well) for flashing, some “wire loops” (don’t know the name) to get an oscilloscope connected. Maybe there’s a way for two ATTinys, 85 and 25v, and just with a switch (or a few) you could switch between the most used MCUs for different firmware. Or some kind of breakout board (like on Arduino) with one of the MCUs on it, and you could swap them.
With older driver designs, a dev board wasn’t relevant because it had plainly exposed pins with room for a clip. It’s only on newer denser boards that it matters. But yeah, a dev version would probably help with getting code support.
Once the hardware is understood well, development for this boost driver can be done on a one channel fet driver. It's just for testing the low modes and making sure that voltage control works out where the real thing could help initially as I see it.
I’m contemplating tweaking my Q8 with XHP35 HI.
I’d like something that can sustain as many candelas and as many lumens as possible, so I need efficiency.
I don’t have the skills for such mod yet, but it doesn’t stop me from seeking options.
2s~~12V boost with XHP35 seems like a natural choice. Or even 4s>24V. Buck 4s12V could work as well, just like boost 1s~~>12V.
Is there anything that would work well in such setting?
I guess BLF GT, but it won’t give good current to 4 LEDs, will it?
Something else?
The BLF GT driver in stock form would be able to drive them at around 1.25A each, maybe a bit higher. If you upgraded some components it could do around 2A each.
