Hi all, I’m looking for recommendations or if there’s anything new lately with built in charging. (Been away from blf & flashlights for about 3-4 months) This will be for a gift.
Looking for “off the shelf” (no building/modding)
Single 18650 size preferably one with a larger size head/reflector 35-45mm (not the “tube” light type) and under $30.00 USD Would prefer programmable modes.
Thanks that a really cool light with the rotating variable tail, thanks for posting the link and deal details, I want one for myself!
I may even consider it for the gift but I forgot to say the light I’m looking for is preferably one with a larger size head/reflector (not the “tube” light type) I’ll update my op.
Thanks for the ideas & links, I like the Convoy BD01 but would prefer an 18650 size tube over the fatter 26650 size.
Went a bit further checking Convoy and found the new BD02 in Simon’s store, should be around $25.00 after BLF discount. Same as BD01 but with 18650 size tube, plus it’s programmable with the Biscotti firmware! Fits the bill perfectly - EXACTLY what I’m looking for!!
Convoy BD series are pretty neat. I have the 26650 BD06 on the way. It should actually have Biscotti installed if it gets picked from stock correctly. Coming from GB. It still got the 7135’s for stacking and no micro USB port on the driver to break. I have the ThorFire version of the BD04 18650 zoomie. Did the 4X stack on it. I use it around the house a lot for the no spot flood. That one needs the battery in backward, just a heads up, as our minds are already programmed opposite. Yeah it took me a while to get it working out of the box
My BD06 will prolly have the EU pins on the charger too, but I have adapters or a phone charger works too.
I agree the YAGE is tempting for 7 bucks, I really like that SMD illuminated bezel, it appears pretty bright on high for good a Flood mode, excellent idea, I’m probably going to grab one too. Pretty crazy ratcheting sound with the rotating zoom function, (I watched the video) the female talking in the background is hilarious!
_
I see in your sig you have some Nebo lights, are they decent quality? I’ve been strongly considering the Nebo Redline RC with Mag Dock for this gift, because I really wanted a light with the convenience of a magnetic docking base.
Only issue it appears the strobe is part of the mode sequence, one of the reasons I wanted a programmable UI, or at least a hidden strobe mode. Do you think its UI is similar to your other Nebo lights, do you have to scroll through 3 modes AND the blinkie every time you use it?
There aren’t many 18650 size lights with the magnetic docking base (besides the Olight S30R, which was quite over budget)
The only other one I found was this iprotect 500lm at Home Depo, which looks suspiciously like a Nebo, and like Nebo they’re also calling the docking system “Mag Dock”, looks like it has the same modes too. It’s rated a higher output (500lm vs 320lm) and appears longer than the Nebo. However it’s kind of pricy, and got a few bad reviews too.
Thanks for the post, didn’t know about the BD06 or the BD04, so it appears the BD06 is a slightly smaller version of the BD01.
And the BD04 a smaller version of the BD02, however it has a tail switch instead of the side switch. (I guess why the backwards battery?) it’s not showing the Biscotti UI diagram but it shows: “NEW BD04, now we install new firmware in the flashlight” I guess that means it will have Biscotti now?
And these all come with the EU plugs only? I’m surprised they don’t have option for a US plug, shouldn’t be a big deal I guess, like you said just use a phone charger.
I’m kind of liking the smaller size of the BD04, and the tail switch would be easier to find in total darkness, plus the lower price. I’m going to have to see what other differences between that one and the BD02… BD04 is at the top of my list now!
Just checked and my TF BD04 plug is US. I never did see a Convoy BD series picture with a US plug though. Thought I would mention it, just in case. Ask Simon if you buy direct. I’m not a zoomie fan but I do use it a lot indoors. But again, if you are modding or testing the driver, the spring is NEG.
No magnet. Clips on like a Snap and a button pops up like a plunger to release it. I think it’s more durable than a micro USB on the driver. The snap part is replaceable and has the micro port. Standard micro to USB cable. Charger is 5V 1A out so if you got Android all you need to carry is the tiny Snap part. Maybe get a spare from Simon.
