I sent a PM to SB asking if there’s a way to download the whole thread (rather than one page at a time) to edit the content down and leave only the info on accessories to repost.
With a pointer to the first suggestion about this above.
Not volunteering, mind ya. But I’ve wondered before about this.
They do that anyway, once you take them out of the dark. Once dark they hibernate after a few days, still keeping time, for a year or more. Then wake up back where they were, with some light. If capable they then re-lock onto RF time signals, but not important, my two run for a year and are still within 30 seconds. Great devices.
Coated lens is an odd one, I didn’t think I had one, but looked vary carefully. I do, but it is in upside down, seemingly single-side coated, not a concern. May turn it around the proper way to try to see any difference, but frankly not bothered.
CS screws are only in first batch AFAIK.
Since the torch is currently sold out, perhaps batch 3 is on the way, that might trigger more excitement depending whether any more changes are coming. I hope they are, continuous product improvement is in my blood, not stasis.
Well, I thought I liked neutral. I have some T6, color bin 4C I think, or that's what fastech said, xm-l2. As I recall that bin has a minimum cri of around 80% maybe. I must say I much prefer them to the Q8, which is significantly "cooler", but that's not so much the issue as it just seems colors are slightly flat in comparison. As LED's go the Q8 is pretty good still, far better than cool whites, but not as nice as my T6's. Probably more lumens though. Considering replacing with a warm xp-l2 if I ever feel like blowing the cash on them.
So just checked, and those fasttech xm-l2 T6-4Cs are 4200-4500 where the Q8 is XP-L 4750-5000, so yeah a little cooler. The bin datasheets from cree show that both of those should be minimum 70 cri/typical 75. I definitely prefer the T6. Whatever the reason it feels more natural to me.
To those that have lights lost in the mail, contact bandgood and they will make it right. DHL managed to loose mine (tracking even shows it). They have a replacement on its way. It will take a few extra days but at least it is coming.
Haha, well normal people probably don't modify flashlights, but as for the led's those t6 4c's are pretty popular from comments I've seen, and have 28 reviews on fasttech, a lot more than any xm-l2 in any or all 3-bin's, including U2 3c or 3b, and the U2 1-bins have a whole 1 review.
Hah, Flintrock may be weird, but not because of that. Lots of people prefer 4300K-ish tints over 4800K-ish tints. The 4000K Nichia is particularly popular around here.
IIRC, the XM-L2 also might have somewhat less variation across the beam, which would make it look better, but I don’t recall for sure. XM-L2 has a full and smooth dome, while the uneven XP-L dome got shaved on the edges to make it fit an XP-sized pad. It’s great that it fits the smaller pad, and it’s easier to do mods with an XP footprint, but the emitter itself was originally designed for a different dome.
My last one did not/is not coming by FedEx SmartPost… it is USPS all the way once it hits the USA.
This may not help, but if your Tracking Number starts & ends with letters like this… LS03@@@@@48CN …… plug it in here…… https://tools.usps.com/go/TrackConfirmAction_input …. and see if you get any results.
You may have done this already, but if you haven’t it can’t hurt to try.
I just want to mention that I placed my order last month on 22/10 using the GB code provided to me by “The Miller” in early September that supposedly expires end of Sept, and it still worked for me last month. Assuming the code is unique, perhaps those who did not end up placing an order can still try it out?
EDIT: I opted for FREE SHIPPING. The order was dispatched on 24/10, and surprisingly I received it in Australia right on 2 weeks on 07/11.
I notice the BLF Q8 is on pre-order now at Banggood. I’m wondering if the next batch of BLF Q8 might have other issues that the first batch seem to experience. Also, is there any updated firmware (I saw mentions of NarsilM v1.1 or 1.2, not sure what are the differences) for the BLF Q8 — what firmware is the latest currently installed (or scheduled for next batch release)?
Another question, it’s mentioned that true flat-tops may not work (eg. original Samsung INR18650-30Q), but raised flat-tops like the LG HG2 might work. How about plain Panasonic NCR18650B? It looks like I may not be able to order any more 18650s — all the previous online shops, including the ones from AliExpress) that formerly ship to our country, now indicate “cannot deliver to the Philippines”.
Also wondering, what’s the difference of the BLF Q8’s light output compared to say 4xBLF A6 3D-tint (eg. tie up 4 of these in a square pattern), and let’s say put the 4xBLF A6 into Turbo mode — compare it with BLF Q8 at Turbo mode — will they have similar light output using same batteries (perhaps the beam pattern will differ)? The BLF A6 3D-tint uses the same emitter as the BLF Q8, isn’t it?
I know many here put solder blobs on their flat top batteries. If I choose not to do this, does anyone have any links to recommended magnet slabs to use?
Remember that in the Q8, unlike devices with single battery or battery carriers, the top of the batteries will be rotating around the contact ring, ie there will be a lot of sideways friction on the positive pole as the battery tube is screwed in. This could dislodge a magnet, potentially causing a short. It may be a bit risky going the magnet route.
