It’s now in promotion for $27.95 100% copper built, 1A, 3D, 5A tints available up to 1300-1400lm (spring bypass may be required), A17DD-L FET+1xAMC driver (same as BLF A6/Astrolux S1).
Preorder has ended and price went up to $29.99 but if you use above link price will drop to $19.95 . This will work for about a week.
This is tried design based on prevalent C8 host with XP-L HI LED (1A and 3B tints available) and BLF A6 FET + 1xAMC driver.
This means this light will offer best throw from any C8 host as in turbo mode it’s essentially direct driven - so use high drain battery like Samsung 30Q above for maximum light output (stated 1300lm, spring bypass may be needed).
And of course same great UI as BLF A6 :+1:
It’s now in flash sale for $7.69
This is the younger member of the family. It’s smaller/more compact than Xanes 175A - meaning less runtime and most probably less brightness but on the other hand price is also lower Offer expired in 5 days and 10 hours.
It’s now in flash sale for $5.95 ($8.99) Offer exires in 5 days and 10 hours.
For those how do not know: those are GTLS (Gaseous Tritium Light Source) and do not need light exposure for “recharging” like photoluminescent markers.
Tritium is hydrogen isotope undergoing radioactive decay which produce small amount of electrons that light up the phosphor that covers inside of the vial.
It is completely safe as radiation do not even have enough power to penetrate human skin.
You can read more about that here: [wikipedia] Tritium radioluminescence
