Discreet APA102 or SK9822?
hello
i’ve purchased some hi-watt RGB LED’s, similar to these:
https://www.ebay.com/itm/100W-100Watt-RGB-Red-Green-Blue-High-Power-LED-Light-Lamp-Panel-Chip-DIY/401361314623
i want to make an addressable string of 50 of these big guys, preferably using 4-wire protocol (with clock wire).
How? I don’t mind if it’s a chip or a whole module. Also don’t mind if it uses some other protocol— does not have to be a standard.
I cannot find a discreet APA102 or SK9822— those chips seem only to be available with an on-board LED.
Could any of these work?
https://www.ebay.com/itm/PCA9685-16-Channel-PWM-Servo-RGB-LED-Driver-I2C-12-Bit-For-Arduino-BS1/262847153393
https://www.ebay.com/itm/RGB-LED-Light-Modulator-Programmable-PWM-Controller-for-Arduino/362113940268
https://www.ebay.com/itm/PCA9685-16-Channel-PWM-Servo-RGB-LED-Driver-I2C-12-bit-Part-for-Arduino-Hot/382170803578
https://www.ebay.com/itm/9-channels-RGB-bi-color-LED-driver-w-256-level-PWM-TM1809-arduino-RGB-LED-strip/121039360751
thx
I really have no clue, but what driver are you considering for each LED?
Driver may limit your choices on what to do or how. DMX stage lighting controlers?
The P9813 looks like it can do the job for you.
I didn’t do a full analysis but in the worst case you could use it as a simple PWM generator.
