an Idea for using DTP Boards with OSRAM LEDs
71 posts / 0 new
thulfiqar
thulfiqar's picture
Last seen: 3 months 39 min ago
Since Osram LEDs have the anode and the center pad connected together , it is not easy to use them with DTP Boards in a flashlight
so I though of making a driver for Osram leds where the polarities are reversed , The outer ring of the driver is positive and the center of the driver is negative
(the battery needs to be inserted in the flashlight upside down)
by doing that the body of the flashlight will become postive and that will enable using Direct Thermal path with osram leds
then you can push the led harder and get MORE power while keeping the LED cool
What do you think my friends ? Big Smile
ImA4Wheelr
Last seen: 6 hours 45 min ago
Seems like a great idea.  Many handheld laser units are positive to the body.  I don't know why flashlights went negative to the body.  Maybe it was for safety.  Cells seem to all have negative charged cases.  If the body is positive and there is a short from the cell case to the flashlight body, the cell will be direct shorted when the switch is clicked on.
Lexel
Lexel's picture
Last seen: 7 hours 36 min ago
You would need to rewire the full driver, the AMCs dont like positive on the ground fin
But using kapton tape on the bottom of the star should be enough
Or a host with anodized shelf
Lexel
Lexel's picture
In fact with protected cell the risk of a short to the battery gets lower, as the thin metal strip from the minus gets on most to the top
Unprotected cells I double or triple heat shrink so they fit better
https://oshpark.com/shared_projects/MscpbYDW
djozz
djozz's picture
Last seen: 1 hour 23 min ago
Hey, that is really nice, Lexel Cool , this type of board could make me use the Black Flat again. Is an inverted BLF-A6 driver possible as well?, and if a LFPAK56-FET does not fit, a LFPAK33-FET may? (only if you like doing it of course).
link to djozz tests
“I used to think that top environmental problems were biodiversity loss, ecosystem collapse and climate change. I thought that thirty years of good science could address these problems. I was wrong. The top environmental problems are selfishness, greed and apathy, and to deal with these we need a cultural and spiritual transformation. And we scientists don’t know how to do that.”   (Gus Speth)
Lexel
Lexel's picture
I am not sure if the 6 AMCs on back side will fit a pills retaining wing, maybe some grinding is needed or soldering the driver to it
I did it as Triple channel Bistro/Narsil
LFPAK33 driver
https://oshpark.com/shared_projects/QqGEvoTS
djozz
djozz's picture
That is very quick Lexel, thanks! Are all 8 7135 chips in parallel or is this a triple channel driver with one 7135 with its own channel? It is relevant because I would like to simply transfer the components (except the FET) of a BLF-A6 driver to this board and make that work directly (I can not do anything related to flashing firmware myself).
link to djozz tests
Lexel
Lexel's picture
I made the board for Tripledown layout
the first I posted had the pins not as the A6
djozz
djozz's picture
Ok, then I will have to find me someone to add firmware.
link to djozz tests
thulfiqar
thulfiqar's picture
Thank you Soooo much Lexel, you saved me alot of time and effort because I was learning to use Eagle in the past 2 days
so far this is my progress FacepalmCrying
I have many Nanjg 105D Drivers, like this one
Can I install their Components on your Driver ?
if not, Could you share the Needed Components for the Driver Please, or even a Nanjg 105D .sch file would be Greatly Appreciated
Thanks Smile
DavidEF
DavidEF's picture
Last seen: 2 hours 38 min ago
I’m subbin’ this one! CrownThumbs Up
Reason is not automatic. Those who deny it cannot be conquered by it. Do not count on them. Leave them alone.
-Ayn Rand
Lexel
Lexel's picture
Thanks Smile
105D driver should work with Tripledown layout, same pin for the 7x AMCs
R5, C1 and C2 are to filter voltage spikes from the MCU, at least R5 you have to bridge or equip with 4.7Ohm resistor
I made a Fet+ n 7135 one, should be pin compatible to A6
Pin 4 FET pin 5 AMCs
https://oshpark.com/shared_projects/MSr9VRbY
djozz
djozz's picture
That is wonderful Lexel, if built up one-sided I can even use 2 chips and have up to 700mA regulated (mode spacing with A6-firmware should not be too bad)! I ordered 3, will check them out, and report here.
I’m not sure if I’m a rare exception: can solder very well but can’t do computer stuff. For this board I can just rob all components off a common BLF-A6 board (or BLF X5/X6 board) and that is all there is to it. Smile
link to djozz tests
Lexel
Lexel's picture
I just realized that the Fet +n has wrong pinout compared to A6
thulfiqar
thulfiqar's picture
it happens .
we will wait your fixed Version
Thanks for the Updates Lexel
Lexel
Lexel's picture
I fixed the Fet+ n 7135 one, should be pin compatible to A6 now
Pin 6 FET pin 5 AMCs
thulfiqar
thulfiqar's picture
Many thanks lexel, helpful as always Thumbs UpSmile
djozz
djozz's picture
Good that you noticed the mistake, ordered again Smile
Luckily Oshpark is dead cheap for these little boards…
link to djozz tests
thulfiqar
thulfiqar's picture
will the OSRAM 4715AS handle a reversed BLF a6 Driver (Like lexel’s) on a DTP Board ?
djozz
djozz's picture
Not sure, I guess it is safer to go for the 8×7135 version above without FET.
link to djozz tests
thulfiqar
thulfiqar's picture
I started with 2000ma , Then 3000ma , Now FET
GREED LOL
djozz
djozz's picture
GREED LOL
In that case:go for it! Party
link to djozz tests
Lexel
Lexel's picture
4715AS wont survive a FET, this is a IR LED with a forward voltage way below our white LEDs
2-3A on DTP should be possible, but FET would go >10A and boom
Black flats should work with FET
Lexel
Lexel's picture
djozz wrote:
Good that you noticed the mistake, ordered again Smile Luckily Oshpark is dead cheap for these little boards…
you could still cut one trace and do 2 thin wires to rewire PWM pins
djozz
djozz's picture
A quick look on the datasheet mentions a Vf well above 3V, so this may be one of those 2xseries-die leds?
link to djozz tests
Lexel
Lexel's picture
datasheet shows 3A at 3.8V this may work, but could still fry the tiny 1mm² emitter that has 9K/W thermal resistance
even our white XPL LEDs don’t like to be driven at much higher than double rated current
thulfiqar
thulfiqar's picture
Gea2427
Last seen: 1 hour 4 min ago
Has anyone received and put one of these together yet? Looking to use an osram flat black just wondering if anybody has done this combo with one of these boards yet
djozz
djozz's picture
I have ordered them but have not received them yet. Perhaps folks in the US have them sooner than me?
link to djozz tests
Gea2427
So does anyone know if this is this an inverted copy of a blf a6 driver? Can I just remove all components from the a6 driver and put them on this board?
Lexel
Lexel's picture
The board uses another FET size
The AMC only one is compatible to Convoy or 105 drivers
