JasonWW
(JasonWW)
November 4, 2017, 12:15am
11
Yeah, so about 2,000 lumen and not the rated 2700 listed on the Aliexpress website.
Also not 1697 meters. Maybe 1400m?
Still, this is pretty good for the price. I kind of knew tho specs were not going to be met.
BTW, BG shows a Nov 15 ship date for the Astrolux version.
Nicolicous
(Nicolicous)
November 4, 2017, 12:00am
12
Highly doubtful this light can throw 1400m.
Acebeam K70 have bigger reflector and it pump 2000lumen (2A to LED) which throw about 1km.
No way astrolux MF02 can beat K70 if it drive 2A to LED
Hardusvd70
(Hardusvd70)
November 9, 2017, 5:48am
13
Is the Astrolux MF02 head diameter still 84mm? What I’m understand from freeme is this light is capable to throw 530,000cd/1456m with 2.6A. Then it’s actually not bad for the price.
JasonWW
(JasonWW)
November 9, 2017, 6:46am
14
There was talk of Astrolux thinning the stainless bezel a little and increasing the reflector diameter 2mm. Changing the head diameter was too big of a change.
Now we just need to wait until someone can test the Astrolux version and verify all this. It’s supposed to start selling in less than a week.
Maybe we should talk about the Astrolux version on the Astrolux thread?
JasonWW
(JasonWW)
November 9, 2017, 6:45am
15
Oops, it’s been changed from Nov 15 to Nov 30.
JasonWW
(JasonWW)
November 14, 2017, 3:24pm
17
Wow, those beamshots are practically the same.
If all you care about is performance, the MT35 is equal to the K70, but at half the price. Impressive.
more two pictures… :sunglasses:
MT-35
K70
stfc69
(stfc69)
November 14, 2017, 4:09pm
19
There is a slight difference but not enough to justify the extra price of the K70.
The Mt35 does look warmer than the K70.
Rusty_Joe
(Rusty Joe)
November 14, 2017, 8:39pm
21
But the MT35 steps down and the K70 does not! :sunglasses:
JasonWW
(JasonWW)
November 15, 2017, 2:20am
22
Does it?
Maybe that’s a reason to spend double the money?
Thanks for the review.
What are the LONGEST cells that will fit in the carrier?
I want to use either MJ1 or Panny/Sanyo GA’S. It will be modded and he states: Protected cells Only
GA Dimensions: Dimensions (including button): 69.7mm length (±0.2mm) x 18.55 mm diameter (+0.1 / –0.3 mm)
MJ1 Dimensions:Dimensions: 69.6mm length (±0.3mm) x 18.6 mm diameter (+0.1 / –0.3 mm)
Thanks
Hardusvd70
(Hardusvd70)
November 19, 2017, 1:24pm
24
The last two pictures is the K70 definitely a better thrower. But yes for the price it’s worth it.
wolfdog1226:
Thanks
I enjoyed it but there was nothing mentioned in the EXTENSIVE review about maximum battery size.
,Thanks
JasonWW
(JasonWW)
November 19, 2017, 10:35pm
26
The last 2 pictures don’t look right. The MT35 doesn’t seem to be on its highest setting or the camera settings are not the same. All the other pictures show the same brightness.
JasonWW
(JasonWW)
November 19, 2017, 10:38pm
27
Since it uses the same battery carrier as the MF01, did you check that thread about what size protected cells fit?
lusan_senna
(lusan_senna)
November 20, 2017, 12:18am
28
No,I did not know that. I will check now. I am not up on all these budget lights!!! ,even though that is the title of this forum. lol!
Thanks Jason.
I will talk to the guy who modded the light because PROTECTED CELLS [Acebeam 3100mah] fit in the carrier.Maybe he modified the carrier or the MF01 carrier is not exactly like the MT35 carrier.
