There was talk of Astrolux thinning the stainless bezel a little and increasing the reflector diameter 2mm. Changing the head diameter was too big of a change.
Now we just need to wait until someone can test the Astrolux version and verify all this. It’s supposed to start selling in less than a week.
Maybe we should talk about the Astrolux version on the Astrolux thread?
The last 2 pictures don’t look right. The MT35 doesn’t seem to be on its highest setting or the camera settings are not the same. All the other pictures show the same brightness.
I will talk to the guy who modded the light because PROTECTED CELLS [Acebeam 3100mah] fit in the carrier.Maybe he modified the carrier or the MF01 carrier is not exactly like the MT35 carrier.
The Mateminco MT35 and MT18 are very similar to the Astrolux MF01 and MF02. The heads and battery tubes are all interchangeable and the battery carriers are all the same. Saves money.
When Lexel reviewed the mf01 he said protected cells won’t fit. Then Charles BridgTec did a review of a production version and said protected cells do fit. It’s possible the battery carriers were lengthed just a little so both will work.
