If you double click to turbo and then hold the button for just a second it will drop back to the ramp max.
Although for about $5 you can get the parts you need to re-flash the driver and you could then setup the driver with whatever max you wanted. If it was asked I bet Tom could even make a pre-made hex file with a lower turbo output.
You are absolutely right. If I need only one cell for another flashlight, I will always take a different one…
All should be used the same amount of time…
And before using them together again in one light, I will fully top them up all together in the same charger.
All should have the same level of wear especially in a 4S1P light!
And none must have been over discharged, otherwise the danger of a mismatch is high.
If they are no longer perfectly matched, you can still use them together in a 1S4P light (the BLF Q8 for example).
In a 4P configuration, if your have a cell that delivers less power, the others will take over.
Here you just have to ensure, that the others can deliver a higher current in such a case.
(Your have to know the specs of the cells)
But if all 4 cells are always used together in the same light, you most probably needn’t care for all those things…
I almost can’t believe that we’re getting this groundbreaking light for such a reasonable price, as a result of volunteer enthusiasts taking the initiative to create and drive the idea, and partner with a manufacturer to make it happen for so many other enthusiasts. I can’t think of any other hobby I’ve had where this type of community participation happens.
I offer my sincere thanks and appreciation to everyone involved.
It sounds like I discovered this at just the right time. Those of you that have been waiting since page 1 must be so pumped. It’s pretty exciting to see this come together!
If an absolute nube to the discussion, forum and product can be added to the purchase list, I would most humbly appreciate said consideration. Thanks to all involved w product evolution to market!
Of course you can be added as a novice. Every single flashlight enthusiast here, reguardless
Of current skill and knowledge level, all started as a novice trying to learn. Welcome to the BLF. The Miller will add you to the list at his next update. Probably within 2-3 days
