Need your help guys.
What is optimal recess for button top 18650 mechanical protection? I mean height diffrerence between positive contact plate and plane where negative side will stop.
PM sent about specifics for this:Mag D kit with soldered XHP50 and 2A buck driver – $30
Will it work with a cut stock reflector(? lumens) and what are the voltages and currents needed.
Thanks I would like to purchase one
I don’t have the answer, but whenever you have those mechanical protections for the Q8 make a sales thread, you will probably get tons of orders, I want one myself!
Not sure, I guess it depends on how much can a negative side of the battery wiggle while inserted backwards… Someone made lexan plastic rings that looked great
