Filling out the form, im Keen!
samsung-35e-datasheet-inr18650-35e.pdf
442.91 KB
Signed!!
I previously filled out the form only, I am not sure if I needed to post as well…. So yes, I am interested.
no need to post here - but its helpful for new users to see my deals can be trusted as long known users participate
so - thanks guys!
more than 200sets wanted makes it mu h easier to make the deal happen ;)
Hello Martin, fill out the form, I’m interested if you send to Argentina, greetings!
Put me on the list
Interested. Submitted form.
Hi,
i’m interested… where can I subscribe and pay for the BLF GT ?
Regards
Patt
Go here for BLF GT thread.There you can get to the interest for the GT and later get paying instruction by PM when the shipping and paying time comes.
BLF GT thread
Hi, sorry for my noob question, but could you please tell the Full Specifications of the batterues?
I don't know them and would really appreciate that tech info.
Thank you!
hope that includes NZ!
In if this ships to Finland?
G'Day PVCC,
Look here (HKJ's review):
Test/Review of Samsung INR18650-35E 3500mAh (Pink) | BudgetLightForum
https://budgetlightforum.com/t/-/38563
Best Regards,
George
How about a test on these cells… “Here”:Test of Samsung INR18650-35E 3500mAh (Pink)
@MtnDon,
The website http://lygte-info.dk belongs to BLF's HKJ
The link for that review on his website is:
http://lygte-info.dk/review/batteries2012/Samsung%20INR18650-35E%203500mAh%20%28Pink%29%20UK.html
Your link doesn't seem to work (so I fixed it in my quote).
Best Regards,
George
Thanks George… I did not notice I messed up the copy of the link. :person_facepalming:
Samsung 35E specs here (not sure if this specsheet is the latest revision, as it’s not from Samsung website themselves)
442.91 KB
HKJ tested and reviewed them here:
Samsung INR18650-35E 3500mAh (Pink) [image] Official specifications: Nominal capacity: 3500mAh Minimum capacity: 3350mAh Nominal voltage: 3,6V - 3,7V Charging voltage: 4,2V Discharge current: 8A Maximum discharge current: 13A Charge current: 0,6C 2000mA Discharge end voltage: 2,65V Pluspol: FlatTop Chemistry: LiNiCoAlO2 Diameter: 18,55mm ± 0,1 Height: 65,25mm ± 0,15 Weight: 48g ± 1 [image] This is one of the new high capacity cells. [image…
Note however, that this offer is the button-top version (original Samsung has only flat-top version), so most likely, the reseller added a ‘button-top’ to make them compatible with some flashlights that only work with button-top cells.
Interesting note is that the specsheet specifically indicates ‘for cycle life’, it has to be charged at 1.02A only; and if charged at 2.0A, then it is ‘not for cycle life’ (it’s detrimental to cycle life?)
Discharged to 2.65v cut-off voltage (I notice for many >3000mAh branded 18650s, the cut-off voltage is rated at 2.50v)
PVCC: M4D M4X:no need to post here - but its helpful for new users to see my deals can be trusted as long known users participate
so - thanks guys!
Thank you!
G'Day PVCC,
Best Regards,
George
Thanks!
But are you sure that those are the cells?
Because they don't have Top Button as M4D M4X said...
Interested, filled the email address.
Hoping that shipping to Finland isn’t a deal breaker.
we let them be made for us (adding button top to use in the GT)
seems sets are limited to a few hundred atm
