Please see my post above regarding Sky Lumen. Thank you.
Please see my bead blasted and polished L2 SST-40 at 8.8amps and it didn’t cost $100.00 bucks to do!
Thank you so much. Amazing.
It’s running TK’s Cresendo push button ramping, I like it better, it’s pretty cool! :+1:
So if I could run a 6V emitter out of a single cell, what would be that driver, could you name or link such driver…?
In the other hand, is XHP35 a 3V emitter? in that case, could it work for the L2 single cell config…!?
By the way, those two L6 and L2 look amazing…!
XHP35 is a 12v emitter. Your best bet is to run the SST-40 FETDD driver for the out put you seek, 2500lms. I have another L2 running 2S 26650 and a XHP50 @ 9amps, that is really sweet! Nice blend of throw and flood and nice tint a XHP50 J4-1D.
Have you checked out the L2/L6 modding thread.might get some info that will help….Convoy L2/L6 modding thread
Thanks for your feedback, really appreciate it.
Dont quite know what a FETDD driver is or where to find it, could you please explain or link me one. Also, if you know a good place to buy leds on their PCBs or the SST-40 in Neutral white 4000-4500k would be amazing.
Thanks again for the info…!
Yep, one stop shopping here…http://www.mtnelectronics.com/
Also these very really smart members are working on something you might be interested in LED drivers and Accessories you want, but don’t exist might want to inquire there about a 20mm 6v single cell boost driver! Your L2 is the newer model with the 20mm driver correct?
Kaidomain H2-C 22mm “12V” Boost driver if that fits.
For modding it, check This thread.
Oh nice, I was looking for that thread too, thanks!
Cool Thanks, Ill check the site…!!
Ok, so if XHP50 6V emitter cant run out of a single 26650, could you guys explain how Klarus G20L runs a XHP70 out of a single cell…? I don’t understand.
That was the example I took for my process of thought to convert the L2 at a higher output.
Here ya go, check this out, it will explain a lot of things for you….
A long time ago I promised I would do a topic to explain to the interested layman the difference between Linear, Buck, Boost and Direct Drive drivers. Well, here it is. Direct Drive [image] This is the simplest and cheapest design. As its name implies, it is a direct path to the LED, just like old incandescent flashlights. Sometimes there is a control chip and transistor to create modes (High, Low, Strobe, etc.) by rapidly switching ON and OFF the LED. That’s called PWM. This is used by peop…
Looking around at commercial and community-designed drivers, there’s one for just about everything. Want a direct-drive FET with a sub-lumen moonlight? No problem. Constant current buck for a 3V emitter with multiple cells in series? Easy. Run an XP-L off a AAA? No problem. Run an XHP50 from a single 18650? Keep an XP-L regulated for the whole life of the battery? Crickets…. Zebralight, Armytek and the Noctigon Meteor do this, so it’s obviously not a technical limitation. I know they’re a littl…
XHP70 have a 6V option too as the XHP50 depending on the Mcpcb (both have 12V option too).
But XHP35 and XHP35 Hi only comes in 12V option.
The xm-l, xm-l2, XP-l, XP-l hi, xp-l2, Sst-40 is a 3v emitter.
And whatever you choose you need the right driver to power them.
Not many drivers for 1 cell powered xhp35 and XHP35 hi tho.
One single cell driver is Kaidomain H2-C 22mm “12V” Boost driver.
It can power the xhp35 Hi, xhp50 (12V version), XHP70 (12V version) with a single battery. (If the driver fits the L2)
If you want a FET direct drive driver and add a de-domed/shawed Sst-40 or an XP-l Hi (I guess you want throw (long range)) you could use a 17mm BLF A6 A17DD-L FET+1 driver but I’m guessing you need a 17mm to 20mm driver adaptor.
I don’t know where you live but mtnelectronics have a nice selection of drivers.
Link http://www.mtnelectronics.com/index.php?route=product/category&path=67
I’m guessing you want a long range flashlight. I think you should go for a Direct Drive FET driver with de-domed/shawed Sst-40 or a XP-L Hi or if you can find a good 12V driver that’s fits then go for a XHP35 Hi.
I don’t know what size of the driver the L2 have so just guessing here.
Hey Thanks, that was really explanatory…!!!
I live in the UK, and yeah, I’m looking for a thrower but I thought I could give it more output. The XPL HI works fine but could always do with more light isn’t it…?
Of course I could use the second battery on the L2 but for that matter I would have gotten the L6… I like the small profile thrower…!!
Cool guys thanks for the output…!!
I have an L2 running a xhp35 hi with a mtn buck driver that gets 2480 lumens and 280 kcd with 4 26350 in it. I’ve been thinking about getting one of those kaidomain boost drivers in it and see how it does with 2 26350’s
Btw. If you are going for a DD FET driver make sure your emitter sits on a DTP (direct thermal path) Mcpcb and put on some good thermal paste under it like the Arctic Cooling MX-4 Thermal Compound so it can transfer the heat properly to the flashlight host.
Same if you use the xhp35 Hi.
Convoy L2 + FX-6 + XHP50.2 J4-3A + tailcap reverse click switch
Hey johnkey68 nice set up…!!
Yeah, something like that is what Im after. Is that single cell light?
Do you know estimate output… does it throw reasonably well…?
Thanks for sharing…!!
Hey interesting approach…!! would like to know how that turns out…!
