You can do this by combining tubes from a SK68 clone and a “3W Police” flashlight (see the lego thread)
I’ve still got a Brinkmann 3AA tube light in the “do something with this someday” bin.
Google finds a lot of other 3AA flashlights (limiting search with /Tools/verbatim, and then choosing /Images)
I’d like to see a djozz-inspired 3AA BLF light myself.
(I’m waiting for the flashlight design where you click the button and the light head extends little propellers and flies over to hover and illuminate your target, while you control it from the battery tube)
I’m not sure it would be cheap, I can imagine it being 30 dollar, structurally it is not unlike the Q8, 4 high power leds, and a battery tube for 3 cells (bored out for 3 cells with a rotating tailboard, my preference, or with battery carrier). One advantage: with 1A per led a DTP board is not needed.
1+ on the BLF headlamp but I’m guessing that Zebralight headlamp of yours is one of those tiny ones that don’t have big heatsink or cooling fins?
Btw there are plenty of those small ones.
The ones that doesn’t exist (what I know of) is a good big headlamp with a battery compartment at the back.
Mike C was looking for a good headlamp host in This thread.
I been searching too but I just ended up disappointed.
I like this idea. Is there an advantage to using a battery carrier over a drop in battery tube? I personally favor the simplicity and easier in the field battery swap of the battery tube.
Most people prefer a thicker light than a super long one.
When you need the cells in series, a battery carrier is the simplest and cheapest option compared to having a special rotating PCB and alignment pins.
The other options is to have all the cells in parallel and use a boost driver, but those are harder to make, rarer, and often less efficient than buck or DD.
I like the idea of the Q16, but with 4 xhp70.2 in it instead of 4 xhp35.
I put a xhp70 in a C8 sized OP reflector and really like the beam. It’s a bit throwy, but has great spill.
Puting the 70.2 in the SMO reflector of the Q8 should work well.
Currently you can get 10k lumen from the Q8 with SST40 emitters. We should aim higher than that even though we use the same 4 18650 cells. Maybe go for 5 amp each emitter at 4k lumen. That’s 20 amps at 6 volt (very doable) and 16k lumen.
I would be in for sure! As long as we design in good heat management (like the Q8) so we can run on high for a while I would love to have this light. I love the 26,000 lumen from my Acebeam X45vn, but even though it was 15 degrees F. last night I had to shut it down after 2 minutes. That is a little frustrating.
Has BLF ever built a single 26650 light” My all time favorite out with the dog/trail hiking/general use light is my Supbeam K40Mvn. It has a super wide beam that transitions nicely into a very usable spill with a nice MTG2 tint.
I would love to have a nice single 26650 or double 26350 light with a beam profile like the K40m. I would not expect it to give me 3,200 lumen and 90k lux, just have a similar beam and I would be thrilled. Maybe similar in size to the Manker U21.
I am a big fan of single 26650 lights. They are a nice comfortable size to hold and carry in a pocket and the new 5500mA Shockli is getting close to two 18650’s. And when I need even more run time I carry an extra cell in a pocket. That is the great thing about a single cell light; it is so easy to quickly change cells in the field. Even in the dark! That is actually my pet peave with the K40m, battery carriers are so much more difficult to fumble with in the field.
