My personal recommendation would be to stick to OEM batteries as well. I paid $60 for a spare OEM one for my Nikon.
However, I’ve read a lot of positive feedback about durability and life of Watson’s batteries, which seems to put them a cut above all the other no-name alternatives out there. So, if you are really in a pinch, that might be a viable alternative.
I second that. Been using one for about 6 months and it’s fine. Arrived about 50% charged. Both sony batteries arrived depleted. Wasabi brand of batteries is also good.
I am using Wasabi batteries for my sony a6000, i feel that the run time is longer(didnt measure)
3 fully charged batteries is enough for one day shotting
a6000 also has the overheat problem especially in warm weather (see this Sony forum )
The entire alpha line is known to be prone to overheating (see this article ). a6000 is not as bad as the newer 4k models, but it will still get hot if you try and shoot a long video. No worries for stills though.
Must be only some cases then, because there are also people saying that they’ve recorded with it for 30+ minutes in direct sunlight.
The a6300 is the one that overheats in like 10-15 minutes in any conditions.
If you’re not in direct hot sunlight, you won’t have any problems with the a6000.
Sunlight can heat objects up to like 60C+ regardless of it recording or not.
And, if you have a black camera, it can heat up to even more.
So yeah, “it heats up in sunlight” is a pretty trivial argument.
If you plan to do continuous recording for that long you probably would have bought a different camera though in the first place.
If I read that dpreview forum correctly, the person that got 30+ minutes actually took his camera apart and made some internal modifications to get better thermal conductivity. Hmmm… sound familiar?
Did he say he did the mod?
All I saw is that he posted a link to a video he found.
Other people are saying 22 minutes and 28 minutes, which is not really a big issue.
“I found simply pulling the screen out from the body solved my issues.”
“when I added another lens it seemed to have solved the problem”
From what it seems like, most of the people having overheating issues are in really hot climates, I doubt I will have an issue here in Canada.
Honestly the A6000 is one of the best 1080p cameras.
If it’s for youtube, there is pretty much no difference between recording in 1080p and 4k due to compression.
What does help is rendering and uploading the video in 4k, regardless of it being shot in 1080p or 4k, since that gives the “4k” option on the player which allows for increased bitrate during playback.
If you can afford it and want the flexibility in post, then the a6300/6500 is great for both 4k and 1080p.
The overheating happens most often when recording at 4k, I think you get like 5-15 minutes before it overheats unless you’re outdoors in cold weather.
I have the a5000; also using Wasabi batteries (these ). Haven’t recorded numbers of shots on each battery, but they seem about the same as the stock battery - which is to say, not all that impressive. All of them seem to self-discharge relatively rapidly, and to deplete after relatively few (100-200?) camera shots. So definitely charge before you head out, and take spare batteries! At the price of the Wasabi’s, though, at least spares aren’t expensive.
Other than the battery life, I’ve been extremely happy with the camera! I primarily use it with the 20mm/f2.8 lens, which is nice and compact, and seems a little faster and a little sharper than the kit lens. Previously I used a Canon XSi, which of course works well, but now feels monstrous compared to the Sony. Hoping to get Sony’s 55-210mm zoom lens for Christmas - once that’s in my kit, I don’t think I’ll have much reason to reach for the Canon any more!
Want to get this out asap before reading the rest of the thread.
Crutchfield has the A6000 for 499bux, but with 2 huge bennies.
First, no sales tax. Bam! 45bux more in your pocket, right there.
Second, I think they still have a referral program, ie, you use my customer number and get something like 20bux off, and I get the same in points for referring you. Win-win.
Lemme know if you’re interested, I can PM you my customer-number (gimme a heads-up so I can find it or even call to get it) and you can ask about it. I only did that once like 10yrs ago, so I don’t even know if it still exists, but it’s worth a try. 20bux off is 20bux off…
Pretty fast shipping, best customer service I’ve experienced, pretty much ever. Their “open-box” stuff is often indistinguishable from brand new, and I’ve even gotten some “scratch’n’dent” stuff which might be missing a cable (so they include an aftermarket one anyway, so you’re never missing any parts, ever). Only place I’m comfortable with by doing that.
I’ve been getting my car-audio stuff from them since the late ’80s, I think, and now pretty much all my camera stuff.
If/When they ever get that 500mm Nikon/Nikkor traffic-cone lens I’ve been itching for, I’m getting it from them.
