Thanks
Last time I checked the rules there was no prohibition on multiple accounts @BG :smiling_imp:
DQG Tiny 26650 3th 7x XP-G2 NW 2500LM 4modes EDC LED Flashlight
Use coupon code HDQG to lower the price to $51.96 (-$12.99)
Nitecore SRT9 XHP50 2150LM Multi-LEDs Tactical LED Flashight 246M
Use coupon code HSRT9 to drop price by -$51.98 (from $129.95 to $77.97)
AMUTORCH AM30 XHP-70 4000Lumens Brightness USB Magnetic Charging LED Flashlight
Use coupon code HAM30 to lower the price to $62.12 (-$14.57, best offer ATM)
Revtronic PT20 XP-L HI 960Lumens 5Modes Tactical EDC LED Flashlight 18650
Use coupon code HPT20 to lower price to $15.36 (-$6.59/-30%)
BLF A6 XPL 1600Lumens 7/4modes EDC LED Flashlight 18650
It’s now in promotion for $17.99.
Offer expires on November 25.
All tints available: cool (1A), neutral (3D) and warm (5A).
Fitorch P20R XP-L2 1180Lumens Rechargeable Tactical Mini LED Flashlight
New working coupon code: YP20R lowers the price to $35.19
- Cree XP-L2 LED
- micro USB Rechargeable
- can recharge mobile devices (powerbank function)
- dual switch (side + tail)
- 18650/2xCR123A power supply
- max output: 1180lm ANSI
- button integrated charge indicator LED
- holster, keyring, spare oring, spare tailcap, USB cable and USB OTG kit included
XANES LTL01 Bicycle 4 LED Light 2 Lasers Night Safety Warning 180 ° Viewing Angle Bicycle Rear Light
It’s now in preorder. First 150 pcs price is $4.99, then it will rise to $5.49 and $6.49 over 400pcs.
2 laser lines can be projected on both sides of the bike to denote safe passing distance.
Nitecore T Series Tube 45LM USB Rechargeable LED Light Keychain
It’s now in flash sale for $5.95
Offer expires in 5 days and 11 hours.
Eagle Eye X2R XM-L2 U3 670Lumens USB Rechargeable Tactical LED Flashlight 18650
Finally one of most popular rechargeable lights is available @BG. Very good value, quality/cost ratio.
Use coupon code HEX2R to lower the price to $14.20/$14.60
Cool white(1A) and neutral white (3C) LED tints available in both grey and black finish.
Astrolux MF02 XHP35 HI 2700Lumens Long Range Searching LED Flashlight 1697M
It’s now in preorder for $84.95
4 days 5 hours left.
HaikeLite SC01 XHP35 HI CW 26650 2000LM LED Flashlight
using coupon code HSC01 price drops to $35.70 (-$23.80)
Offer expires on November 25th and pieces are limited.
Nitecore TIP SS Stainless Steel XP-G2 S3 360LM Metallic USB Rechargeable LED Keychain Light
Use coupon code HTIPSS to lower the price to $19.92 (-$15.03)
- Stainless steel construction
- 3 colors: black, tropical (rainbow multicolor), silver
- Titanium PVD coating (black and tropical, silver one is polished SS)
- 6 modes (4 constant + location beacon and strobe )
- min mode: 1 lm
- max mode: 360lm
- max runtime: 46 hours
- weight: 32g (1.1 oz) /for comparison: Alu version is 23.5g (0.83 oz)
- micro USB rechargeable
- clip and belt loop clasp included
- ATR (Advanced Temperature Regulation) prevents overheating
AMUTORCH JM70 XHP-70 3500Lumens 5Modes Brightness Searching LED Flashlight
Use coupon code HJM70 to lower the price to $48.99 (-$21.00)
BlitzWolf PowerStorm BW-PF2 10000mAh 18W QC3.0 Type-C Power Bank with Fast Charging Input and Output
It’s now in preorder for $19.99 (first 100 pcs), after that price will rise to $21.99 (up to 2000pcs), then $24.99. Normal price is set at $29.99
- 10000mAh/37Wh capacity
- QC 3.0, USB Type-C input & output + standard USB type A
- uses LG Li-Ion cells (3x 3350 mAh 18650s)
- up to 18W of input and output power
- QC2.0/QC3.0, FCP, AFC, BC1.2, Apple,MTK PE2.0 fast charge support
- 2 in 1 USB A to C and USB C to C Charging Cable included
- black anodized aluminium case
IMALENT DX80 8x XHP70 2nd Generation 32000LM Outdooors Search LED Flashlight 806M
Use coupon code HDX8 to lower the price by -$170.98 to $208.97
Limited pieces. Offer expires on November 25th.
Rofis R1 XM-L2 U2 900Lumens Magnetic Tail Magnetic Rechargeable EDC LED Angel Flashlight Headlamp
Use coupon code HROR1 to lower the price to $45.47 (-$24.48)
On The Road U16 XP-L V6 1A 1020LM USB Rechargeable Mini EDC LED Flashlight
Use coupon code HU16 to lower the price to $26.40 (-$6.59)
XANES KT XP-G3+UV 350LM 3Modes Rechargeable Mini LED Keychain Flashlight
Use coupon code HXKT to lower the price to $14.85 (-$9.10)
